Question about Crosley CE35100AA Electric Kitchen Range
Crosley oven worked yesterday but today I have no
Crosley range model# CE38600AAW worked yesterday but today I have no heat to burners or oven The only thing that works is the clock. Flipped the breaker and nothing happened, still just the clock works. Do the electric ranges have fuses or is that just the gas ranges?
  • 166 Answers
Check the receptacle for 220 volts. also check the connections where the cord goes into the back of the range - make sure you have 220 volts there also.. it sounds like you have only 110volts going to the range. there are no fuses that I am aware of.
you could also have a burned wire somewhere.
Posted on Aug 01, 2010
Crosley elect. range Model # CRE3880GWWB
Have you checked the breaker? The parts for that model are no longer available.
Feb 14, 2013 | Kitchen Ranges
USED THE BURNER YESTERDAY AND IT WORKED FINE. TODAY IT DON'T HEAT AT All.
I was not aware there is a burner in a microwave oven. Please clarify your problem and include make and model with problem.
Thank you.
Jan 01, 2011 | Microwave Ovens
How do I utilize the self cleaning part? Do I just press ''clean
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
GE Profile Gas Range oven light doesn't work even after changing
Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven does not heat. Broiler and stove work. NO gas smell.
could be the oven thermostat, get a plumber/heating engineer out, but make sure you can trust him, cause he could try and say u need a new cooker when it MIGHT only be a new oven thermostat.
Feb 02, 2009 | GE Ovens
My ge range will not work. it worked fine yesterday, but today only the clock works. when i try to turn on any burners or the oven only the lights work, no burners or oven.
sound like an electiral issue with the range, only getting 120 volts instead of 240. check for loose connnections at the range or the receptical
Apr 16, 2008 | Kitchen Ranges
Crosley gas oven will not heat up
That's my mom!!! Go Sheila!!! Hehe.. -RET-
Aug 08, 2007 | Maytag CWG3100A Gas Single Oven
Crosley CE35100AA Electric Kitchen Range Logo
298 people viewed this question
Top Crosley Kitchen Ranges Experts
Vitaliy Gins
Vitaliy Gins
Oloyede Monsuru
Andrew Taylor
Andrew Taylor
Are you a Crosley Kitchen Range Expert? Answer questions, earn points and help others
