Question about Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo Head CD Player
I just installed a Pioneer 12E unit in my 2001 Chevy Suburban. I used the Scosche GMDA wiring adapter. Everything works but the sound. A friend suggested that GM has an internal amp that must be excited for it to work. What's the trick?
  • 1 more comment
  • jss1960 Aug 01, 2010
    Response may have been right on the money; but not clear to me.
    I don't wish to add another amp. I want to power up the stock amp. All indications are that there is a pink wire that should be spliced into a switched pos. or the power ant wire. Problem: no pink wire in factory harness.
    Thanks, S.S.
  • jss1960 Aug 02, 2010
    Thanks,S.S.
    President:
  • 2,559 Answers
2001 Chevrolet Suburban Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: Pink
Car Stereo Amplifier Location: Front Passenger Footwell
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Posted on Aug 01, 2010
  • 3 more comments
  • Randy Hough
    Randy Hough Aug 01, 2010
    Do you have a second orange wire in the harness? If so that is the one used in place of the pink one
    I have no pink wire. the only wire i cant tell what does is purple. I spliced it into a switched pos and it still doesnt work. the 25 amp fuse is good too. Next?
    I didn't see the bottom part. I'll try the orange wire. Thanks, S.S.
  • Randy Hough
    Here is a link to the complete wiring diagram,This will help if you also have on star it's in a PDF format so you can view or save
  • Randy Hough
    The pink will only be there if you have on star and or a cd changer, Look for a second orange wire.
    President:
  • 567 Answers
When installing a car audio system, you can use one or more subwoofers with the amplifier. If you want to use a single subwooferI just installed a Pioneer - mag-glass_10x10.gif with the amplifier, you can bridge the connection to get more sound. Bridging a subwoofer with a Pioneer car audio system is the process of sending more power to the subwoofer from a single amplifier. You can do this by properly wiring the subwoofer to the Pioneer amplifier.Locate the speaker connections or terminals on the back of the Pioneer amplifier. If you have a two-channel amplifier, there are four terminals. Each channel has a positive and negative terminal.
  • Step 2.Cut 1/2 inch from both ends of a speaker wire with wire cutter. Connect one end of a speaker wire to the positive terminal, for Channel 1, on the amplifier, by pressing the tab on the positive terminal and then inserting the speaker wire into the opening.
  • Step 3.Connect the other end of the speaker wire to the positive terminal on the subwoofer. Press the tab on the positive terminal and then insert the speaker wire into the opening.
  • Posted on Aug 01, 2010
    • Hilton Bristol Aug 01, 2010
    • Cut 1/2 inch from both ends of a second speaker wire with the wire cutter. Connect one end the speaker wire to the negative terminal, for Channel 2, on the amplifier. Connect the other end of the speaker wire to the negative terminal on the subwoofer.
    • Step 5Turn on the car's ignition. Power on the car stereo and turn on the amplifier.
    • Step 6Turn on the radio or play a CD to determine if the bridged subwoofer is working with the Pioneer amplifier. If you can hear sound from the subwoofer, it is working correctly.
    • Step 7Repeat this process to bridge a second subwoofer with another amplifier.
    • Those are the steps to follow.
  • Hilton Bristol Aug 02, 2010
    Hi there you do not have to use two speakers if you don't want to.
    • 4,924 Answers
    Unplug all wires and plug them back on ...do not power it until all wires are in place ...During this ..pay attention on the exit wires for the speakers...maybe you did not plug them in the right place ..and according with the output diagram you have ...Im referring that it may have a for example in the settings a 2+1 ...and you wired a 2 stereo ...
    Posted on Jul 31, 2010
    • Catalin Turcu
      Catalin Turcu Aug 01, 2010
      I was actually suggested that the wiring for the output audio signal is not proper made...or made in a wrong way ...cause if you have access on the settings it is obvious that you did connect the power in the right way ...so the issue has to be the audio output ..
    Pioneer Radio in 95 Ford F-150 doesnt produce sound
    Maybe there is a separate amp with an open fuse.
    Dec 19, 2013 | Pioneer Car Audio & Video
    2001 chevy suburban fuel gauge stoped working
    If the sending unit was connected and grounded, I would guess the gauge in the cluster is faulty.
    Jul 09, 2012 | 2001 Chevrolet Suburban
    I bought a pioneer avic-x710bt navigation unit for my 04 suburban but I need some sort of adapters for the bose system and the onstar system can you tell me where I can get nessecary componets to install...
    try a large retail store like best buy....give them all the info on the system u have a they may have the wiring harness u need to plug ur system in...if not call pioneer an ask for a install kit for the system
    Jul 14, 2011 | 2004 Chevrolet Suburban
    Where is the fuses located in a 2001 chevy prizm? radio stopped working trying to find fuses
    open the hood.on the left side there is a fuse box and also in the lower left of the dash underneath there is a cover and fuses inside.
    your car is built by united auto works in fresno calif. and is the same as a 2001 toyota corolla if you need parts.just the body panels lights etc are different.
    Sep 14, 2009 | Scosche Industries Scosche Gm05b Wiring...
    Radio works untill i start the engine
    You need to double check the wiring. It sounds like you have the system wired incorrectly.
    Sep 01, 2009 | Pioneer DEH-P2900MP CD Receiver...
    Wiring the scosche fai-3a to a pioneer two channel amp
    the 2 left and right dont matter, it only matters when ur hooking up a 4 channel amp.
    all u do is connect one of the channels to it but it would be best o buy a stereo ull have alot of engine nose and vibration on ur speakers and a thump every time u turn on ur car but itll sound ok for now ti
    Jul 07, 2009 | Scosche Industries Scosche Slc4 Speaker...
    Unable to get sound through speakers
    Did you have a BOSE system in your Suburban from the factory? If so, they will not work with an aftermarket radio. You'll need to replace the speakers, if that is the case....
    Apr 28, 2009 | Car Audio & Video
    Can't fit subwoofer amp leads to pioneer DEH-2000MP Head unit
    pioneer head units only distribute like 200 rms or so to the speakers. you might have to find a blue maybe even blue with white striped wire and nick it just enough to tie your amp wire around it. tape it up and see if it works.
    Feb 24, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
    Installing an aftermarket head unit into a 1994 Ford Bronco
    are you using and after market harness to go from your bronco to the harness to the new radio. if so make sure all the colors are matched up (e.i. purple to purple, purple/black to purple/black). did the speakers work before the aftermarket unit. Also check the wiring at the oem speakers
    Dec 28, 2008 | Scosche Industries Scosche Slc4 Speaker...
    No sound from speakers
    did you check to make sure your vehicle didnt come with a factory amp, if it has one is it turning on? or did you remember to disconnect the negative battery cable while installing your radio, i know thats a dumb question, once i was installing a pioneer a barely crossed a couple wires and fried the radio, the radio itself worked fine and all the features etc, but it never did play sound again. i always disconnect the power now!!
    Dec 26, 2008 | Pioneer DEH-P4000UB CD Player
    Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo Head CD Player Logo
    302 people viewed this question
    Top Pioneer Car Audio & Video Experts
    Marvin
    Marvin
    Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
