Question about Nespresso Le Cube
When I hit the Americano button, it comes out like an espresso, not enough water comes through. I've just descaled. How to fix?
The amount of water is programmed by holding in the button. Put your cup below, and press the button. Keep holding until you are happy with the amount of water that came out - and then let go.
Next time you use it, you just need to do the normal short press on the buttom.
(Both the Espresso and the Lungo button can be programmed.)
Posted on Oct 04, 2010
The light dont com on
Posted on Apr 09, 2011
My Keurig does not dispense enough water for any of the settings. Is there something I an doing wrong or that I can fix. Thanks
Hello Gajaxson,
I understand that your coffee maker/Espresso machine is not putting out enough water when you are brewing. This is a common occurrence when the machine needs to be descaled.
There are many different ways to descale coffee/espresso machines and some have cycles built in that you have to add the solution and push a button. Would please post me a model I will check with and see if the manufacture has any suggestions on how to descale your machine. Also if you still have the owners manual it will show you how to descale your machine.
It is recommended that you descale your machine at-least once every six months for moderate use and once every three months for heavy use.
Thank you for choosing FixYa.com
Justin
Mar 13, 2011 | Keurig Coffee Makers & Espresso Machines
Descale button not lit, but the machine has been in use for 2 years and manual says to descale. All steps have been followed: solution is in machine water tank. Program is set to FILTER NO/HOLD. ...
You've done it all correct but before you add the solution (making sure to remove the filter), try holding the descale button down for over three seconds. As long as the FILTER NO is your filter setting, this should work. You may want to try to descale more often in the future but hopefully this helps you get started NOW. Best of luck!
Feb 22, 2011 | Bosch Benvenuto B30 Espresso/Coffee Maker
Our titanium gaggia machine is displaying decalcify, what do we need to do?
If you have a display that says "Decalicify machine" mdo this. To automatically descale your machine, press the scoop button and hold it down until you enter the menu. Use the arrows on the left to scroll down until you come to Descale. Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don't have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. It must be large enough to catch all the water in the tank. To start the descaling process, simply turn the steam knob. When the process is over your machine will say "Descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and start the descaling process over again to rinse your machine. Go back into your menu and scroll up or down 1 to signal descale and enter. Choose "Yes" and push enter so the machine will tell you when you need to descale again.
Sep 24, 2010 | Gaggia Titanium Espresso Machine
I have lost manual so i am trying to find out how i descale my machine
Hi
To descale your Magic Comfort +, enter the menu and scroll to descale. Push the menu button to descale. Mix your solution in your water tank. Use warm water and dissolve all the solution. Place the water tank on your machine. With a container under the steam wand that is large enough to catch all the water in the tank, you are ready to begin. To start the descaling process, open the steam knob. The machine will automatically start the descaling process and when it is finished, it will shut off and tell you that it needs to be rinsed. Remove the water tank and rinse with fresh water. Refill the water tank and place it on the machine. Turn off the machine, wait a moment, and then turn it back on. Press the hot water button to start pumping fresh water through the boiler. Pump out about 16 oz. of water and then turn off the hot water button and open the steam knob to rinse the steam boiler. When it starts to go to steam, turn off and turn on the hot water button again. Pump out another 16 oz. Repeat this process with the steam knob until you have emptied the water tank. Descaling is complete. Go to your menu and scroll to "reset descale", push the enter button and chose "Yes" and push the enter button. Now it will tell you we next to be descaled.
Jun 18, 2010 | Saeco Magic Comfort Plus Espresso Machine
Magic Comfort Plus Espresso Machine: how to descale saeco magic comfort...
  • The first thing you need to do is go to your menu. Scroll down to water hardness and push the enter button. Use your up arrow and move the number to 4 if it is not already there. Push the enter button. Once it is on 4, then scroll up to descale machine and push enter. Have your solution (NOT VINEGAR) Citric Acid dissolved in solution and put into water tank. Now open the knob for steam and let the machine do its thing. When it is all done it will say "Finished descaling". Rinse out the water tank and put in fresh water. Close the knob and then reopen it again. When it finished rinsing scroll down to "Reset Descale" Push enter and choose "Yes" with the arrow and push enter. This will bring up a message when it needs to be descaled again. You can also see how many coffee’s you have made. It’s just above the Descale Machine in your menu. Descale more often than Not Enough will keep your machine working well into the future.
May 07, 2010 | Saeco Magic Comfort Plus Espresso Machine
Please help
The Magic Comfort Plus machine has a selection for the temp through the menu for the three sizes of coffees buttons. Using the menu button, scroll through until you come to temp section, then select the coffee size button and and change the temp, example-- Select maximum. Press the menu button to set it.
If that does not help, when a machine gets full of calcium (needs descaling) that also will lower the temp. You might have to descale it three-four times.
And remember, when you descale, run the solution through the steam/hot water wand and also the espresso/coffee dispensing nozzle. Only doing it through the steam wand (like the manual says) will only do 1/2 of the machines water sections!!! I usually run 1 cup of solution through the steam wand and 3-4 cups through the espresso dispenser.
Dec 23, 2008 | Saeco Magic Comfort Plus Espresso Machine
Descaling?
With the selector buttons find Descaling and press OK
This process takes about 35 minutes
1. Empty the water tank, drip tray and grounds container.
2. Insert tray and grounds container, refill tank with with 0.5 Lt. of water and add descaling agent (not the pill or powder used for clean cycle) to tank. Make sure its completely dissolved.
3. Place a container or cup under the steam wand large enough to hold 0.5 lt.
Display says Descaling and press OK
4. Press the water button
Display says Descaling in Progress
after the descaling agent is exhausted
Display says Empty Drip Tray and Spent Grounds
5 Also remove rinse and refill the water tank to Max line
6. Press the water button again
after the machine stops
7. Empty the drip tray and spent. ground container and replace
Display says Rinse Press OK
Display says Appliance Ready
In essence go to Descaling Press OK and follow the directions as they are displayed.
Sep 07, 2008 | Krups Orchestro Dialog FNF2 Espresso...
Descale
Aug 02, 2008 | Krups Orchestro Dialog FNF2 Espresso...
Steam blowing out of group head
Were you using cleancaf to descale? If so, it is not a strong enough descaler. Use Dezcal. or a Dezcal cleancaf mixture. The two work great together.
Make sure you get some descaler in the solenoid area by turning on and off the coffee button.
Hope it works out for you.
Espresso Parts and Cleaning Supplies
www.CeriniCoffee.com
Nov 12, 2007 | Rancilio Silvia Espresso Machine
Nespresso Le Cube Logo
1,171 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
