Question about Toshiba Satellite M35X-S114 Notebook
Hi; The problem I have with my Toshiba is that it was running on battery only; and after the battery died the computer shut down. After I connected to the power I could hear that the computer is turning on but the screen stays black. And nothing happen with the computer.
  • Toshiba Master
  • 4,924 Answers
The issue is that the computer shutdown improper ...just like when you unplug it from the power source ..try to remove the battery for good...and after that put it back on ...and insert the plug for the ac adapter ..and try to power it again ..Sometimes they remain in a strange stand by mode..and only if you remove the power for good they get back on ..
Posted on Jul 31, 2010
Toshiba laptop is shutting down message but does not caanot use the laptop
If the computer functions when plugged in with or without the power cell, you ok. Just replace the battery. Many times the power plug is at fault. This happens over time because the power cord may accidently be pulled out, (like if someone trips on the cord and pulls it from the laptop). The end of the power cord may become loose, and if so it will not make 100% direct contact between the power transformer and the line in to the computer. You cannot let the power cell (Battery) die. Some computer require a healthy Cell be operational in order to start up and function normally.
Jan 14, 2018 | Toshiba Computers & Internet
My Toshiba nb505 netbook run with the AC adapter, but will not run on the battery. The battery shows that it is charging but the charging percentage does not increase. Any advice?
I own the Toshiba NB505 netbook and the very same thing was happening to me. Here is what I did to fix my issue:
Step 1: Shut down the computer and remove the battery. Then turn it on but now with the battery out. It should say "battery not detected".
Step 2: Open control panel and open the "device manager". Under "batteries" (the first one), uninstall the one that says "Microsoft ACPI Compliant Control Method Battery". This is the battery driver.
(Don't worry. The computer will automatically re-install it)
Uninstall the driver and shut down the computer.
Then reinsert the battery and power on the computer. The driver should have re-installed itself. Check to see if the battery is now charging.
(It will take awhile for it to fully charge to 100% Best to shut it down and let it charge. The far left indicator light on the front of the Netbook will turn green when it is fully charged)
Hope this helps. Yeah I had to figure this one out on my own. Toshiba support staff over the phone were useless!
Good luck!!
Sep 24, 2012 | Toshiba Turquoise 10.1" NB505-N508TQ...
I have a Satellite L300 running Windows 7. I can charge the battery up using the OEM charger that came with the laptop. However, the computer will not operate if the charger is plugged in. I can do...
right off the bat, i would suspect a bad power adapter for the computer. or perhaps a faulty computer. your best bet is to call toshiba and talk to them directly.
Sep 06, 2011 | Toshiba Satellite Pro L300 Notebook
My Toshiba Tecra R10-112 keeps suddenly completely dying on me. The whole computer suddenly shuts down for no apparent reason. What's wrong and how do I fix it?!
This could be a problem with the battery, if you have a spare try using it and see if this fixes the problem. Best Wishes!
Mar 28, 2011 | Toshiba Computers & Internet
Hi,lost my CD for my Toshiba PDR-3320 any where I can download it for free? Old laptop died and I need to re-install the software so I can post photos.Thank you!Kev
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Oct 09, 2010 | Toshiba PDR-3320 Digital Camera
Battery died
once you connect the cord to a socket yes its automatically switches, could be a bad cord (the cord with the black box on it) and they are not cheap best bet get it on ebay. Hope that helps =)
May 20, 2009 | Toshiba Satellite 1800-S207 Notebook
Toshiba Satellite A205 unable to fully shut down
possible setting issue.
If you Go to,
start, control panel, power options, (classic view)
have a look in the power options there, set as needed. there is a few, check them all out.
use disc cleanup,defragmenter, delete temp internet files, in tools on menu bar , delete history,
update the Operating system at Microsoft.
update virus protection and run a full scan.
you should be good if no hardware problems.
Regards.
Apr 16, 2009 | Toshiba Satellite A205-S4639 Notebook
Toshiba a30 laptop over heating problems
It is obvious that your computer shutdown because it is overheating. try to get a chill mat to place it under computer. you said that it does not shut down when is on battery??? do you play games when is on battery?....computers normally overheat during large processing tasks such us playing video games. Try to fans clear do not place your laptop ontop of your bed or anything that will obstruct the fan under computer.
See if that works
best luck
Apr 10, 2009 | Toshiba Satellite Pro A30 Notebook
Shutting down
Does it cut out on battery?
How often does it cut off?
Does it just die (no lights or anything) or reboot?
Jan 14, 2008 | Toshiba (K000006610) for Satellite P25...
Toshiba Satellite M35X-S114 Notebook Logo
15 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
