Question about Compaq FP 7020 17" Flat Panel LCD Monitor
Removing the case for a Compaq 7020 17 in LCD monitor
I'm trying to remove the cover for a Compaq 7020 17 in monitor. I have removed all the screws, but something is holding it together on each side about half way between the top and bottom. How does the case split apart?
The case has 2 plastic snaps en each side as well as 3 snaps at the top
Use a flat-head screwdriver in the **** between the gray and black plastic. Twist the gray plastic away from the black plastic, and this will snap the part appart
Posted on May 30, 2008
Hi, I have a laptop compaq presario cq 60 .When I switch on the computer the fan start working but the screen is black doesn't start .What could be the problem? Thank you
If you see power lights but nothing appears on the screen, it could be a "POST" (Power-on Self Test) problem or simply LCD problem.
Here are some steps that you can try. One of these may work on your case.
1. Remove the battery and the ac adapter then press the power button for at least 20 seconds to drain electric charges left on the system. (You may need to repeat this step to get it work.)
2. If above step doesn't work, try to plug in an external monitor and see if you get display from the external monitor.
3. If you get display from the external monitor, I'm sure your having problem with the LCD components. In this case, check and replace faulty LCD backlight, LCD cable or LCD inverter. The LCD inverter is often a culprit.
4. Try to reinsert the memory module/s (RAM) of the unit, try using one RAM at a time to see if it works. A faulty RAM will cause the laptop not to POST.
5. If reinserting the RAM doesn't help, most likely your motherboard needs to be replaced.
Hope this helps.
Jul 17, 2011 | Compaq Presario CQ60-212US Notebook
Sony vaio desktop all in one back light not working
To fix your problem please follow the below given steps
Step1
Power on your computer and wait until there should be an image displaying on your LCD monitor. Look directly into the monitor from a distance of about 1 inch way. Cup your hands around your face to block out the light in the room and get a clearer view of the LCD screen. Check to see if there is a faint light visible in the screen, which will indicate that the cold cathode backlight has gone out, or no image at all, which will indicate a different problem.
Step 2 Check the manual that came with your desktopmag-glass_10x10.gif LCD monitor or navigate to the manufacturer's website and find the model of cold cathode bulb that the monitor uses as a backlight. Purchase a corresponding replacement bulb
Step3 Power off your computer and then remove the monitor cable from the port on the back of the computer case. Disconnect the monitor stand from the monitor either by pulling out the plastic latches or by removing the screws holding it to the monitor's casing.
Step4 Lay the monitor face down onto a stable work surface such as a desk or table. Take out the screws along the edges of the monitor's casing and set them aside. Lift the back side of the monitor case off of the monitor and set it aside. Check to see if your model of LCD monitor has the back light directly exposed on the lower end of the monitor or if it is hidden behind another plastic or metal piece.
Step5
Remove the screws holding the plastic or metal piece over the bulb if there is one present and set the piece aside. Check to see if your model of monitor keeps the bulb in a plastic casing or if it is soldered directly to the metal. Use a soldering tool to remove the solder or instead use a rotary cutting tool to cut into the clear plastic casing around the bulb if it is inside a case.
Step6
Slide the new bulb into the open spot on the monitor and either solder it in place or use a piece of tape to cover over the opening you made on the plastic casing with the rotary cutting tool. Place the metal or plastic cover back on if there was one and reattach the screws. Set the casing back onto the monitor and place the screws back in.
Step7 Put the stand back on the monitor and then reconnect it to your desktop computer. Power the computer on and wait for an image to appear on the screen to make sure the back light bulb was installed correctly.
Please rate me if this solution works for you
Thanks......Have a great time.
  • Step 2 Check the manual that came with your desktopmag-glass_10x10.gif LCD monitor or navigate to the manufacturer's website and find the model of cold cathode bulb that the monitor uses as a backlight. Purchase a corresponding replacement bulb.
  • Step 3 Power off your computer and then remove the monitor cable from the port on the back of the computer case. Disconnect the monitor stand from the monitor either by pulling out the plastic latches or by removing the screws holding it to the monitor's casing.
  • Step 4 Lay the monitor face down onto a stable work surface such as a desk or table. Take out the screws along the edges of the monitor's casing and set them aside. Lift the back side of the monitor case off of the monitor and set it aside. Check to see if your model of LCD monitor has the backlight directly exposed on the lower end of the monitor or if it is hidden behind another plastic or metal piece.
  • Step 5 Remove the screws holding the plastic or metal piece over the bulb if there is one present and set the piece aside. Check to see if your model of monitor keeps the bulb in a plastic casing or if it is soldered directly to the metal. Use a soldering tool to remove the solder or instead use a rotary cutting tool to cut into the clear plastic casing around the bulb if it is inside a case.
  • Step 6 Slide the new bulb into the open spot on the monitor and either solder it in place or use a piece of tape to cover over the opening you made on the plastic casing with the rotary cutting tool. Place the metal or plastic cover back on if there was one and reattach the screws. Set the casing back onto the monitor and place the screws back in.
  • Step 7 Put the stand back on the monitor and then reconnect it to your desktop computer. Power the computer on and wait for an image to appear on the screen to make sure the backlight bulb was installed correctly.
  • Read more: How to Diagnose & Repair Desktop LCD Backlight Problems | eHow.com http://www.ehow.com/how_5038642_diagnose-desktop-lcd-backlight-problems.html#ixzz0uJr4tmU8
    Jul 20, 2010 | Sony VAIO PCV-V200G PC Desktop
    LG1917S-BN Access to power supply - Rear cover removing
    You need to use flat thin blade screw driver to crack open the case, starting at the bottom edge of the case first, you may need two screw drivers, when it starting to come apart, leave one screw driver in the partially opening section so it not snap back together while you tackle another section of the case. Most monitors cases these day do not have small slot to show where you should crack open the case at, they just do not want you to fix it.
    Feb 23, 2010 | LG L1917S-BN 19" LCD Monitor
    How to open an LCD monitor.
    I personally haven't worked on this monitor, but most monitors are held together with plastic clips on either side of the casing.
    After removing the stand and all other screws, you will need to use a small flat-head screwdriver (or something of that nature) to pry apart the clips. Find the crease/gap in the plastic where the casing of the monitor comes together. Insert the screwdriver and gently twist and pry the casing apart. When you hear the first click/snap indicating the first clip has come apart, follow the gap with the screwdriver, prying it apart each time you reach an area of resistance. Do this all the way around the monitor.
    Keep in mind that after you open up all the clips, the LCD panel and boards may be screwed either the front casing or most likely the back casing. So you must first unscrew the mounting screws inside the monitor to remove the back cover. Also be careful unhooking ribbon or speaker cables that attach the circuit boards of the monitor to the front casing.
    Jan 12, 2010 | Gateway FPD2275W LCD Monitor
    Removing the LCD from a Compaq CQ60-215DX
    I have a CQ60-220US HP Compaq and access to the LCD screen was different than others I have disassembled and replaced the display. The bezel is snapped on, the lid does not lay back flat to access the two hinge screws, but there are 2 screws with rubber covers down by the hinges, not all the way around.
    I used a right angle phillips screw driver and was able to remove the bottom screws, popped off the bezel the remainder of the way around the screen, it is different, but don't be fooled there are a few screws just not the amount you might be used to, and then gaining access to one of the hinge screws on each side can be an issue as the lid did not lay back flat, but with a good right angle screw driver you can get it done, I did. I am not sure if the proper method is to not just remove the entire top cover and hinges, but the right angle screw driver and finding that this model had only a couple bezel screws made it much easier to tackle.
    Jun 16, 2009 | Compaq CQ60-215DX Notebook
    Stem on lcd monitor can't be removed
    Usually the stem has a plastic cover that hides the securing screws from view. You must pry up the cover to reveal the screws securing the stem to the monitor. This is most easily done with a Plastic pry bar or plastic putty knife. Hope this helps you with your problem.
    Apr 27, 2009 | Computers & Internet
    Can't remove cover of Westinghouse LCM-22w2 monitor
    Hey Ed,
    I hope I can help, It doesn't open from the back, it opens from the front.... carefully! There are four support screws, which hold the LCD screen to the desk stand,after removing all the support screws (4) on the back under the support stand cover.(which pull up to remove) (Remember! the whole case and face frame is plastic, so take your time). Work to separate the black face frame around the LCD from the silver case. Its held together by small plastic clips on the face frame to the wall on the LCD case. Start at one of the corners and slowly pry the face frame and silver case apart. (separate it inch by inch, work your way around the case carefully. If one corner doesn't give, go to another side.
    Putting back together works reverse, the face frame and the case snap back together, Carefully! And replace screws (4).
    Russell
    P.S. I have three LCD models from Westinghouse, LCM-22w2, L2210NW and the L1916HW. They all open the same way.
    Dec 07, 2008 | Westinghouse 22" Widescreen LCD Flat Panel...
    LCD Monitor
    1st remove the base cover by by squeezing to release the clips and remove the 6 base mounting screws. 2nd remove the 5 screws in the back cover. 3rd push and pry at the parting line to release the clips. 4th remove the base mount by removing the two attaching screws and sliding it down about a quarter inch. 5th remove the steel cover by removing the 4 wires, two screws from power outlet, two bolts from vga plug, and the other screw in the cover. and there you have it.
    Oct 26, 2008 | Acer AL1717 17" LCD Monitor
    Acer LCD (AL1917W)
    After removing the back cover screws that you saw, ok, there is a screw under the stand holder. Remove the cover that covers the stand holder joints. you can remove it using a flat head screw driver, it is removeable only it appeares stuck to the back cover. After you unscrew, use flat head screw driver and carefully by pushing to the side of the LCD bend. Carefull you might break the cover. Good Luck.
    Oct 03, 2008 | Acer AL1917W LCD Monitor
    Compaq presario 1200
    there are plastic covers over the hinges, which may be part of the faceplate. being a compaq the hinge screws are most likely torx head screws. compaq used to make a special tool for removing the plastic covers on their laptops. the tool was a bar with a piece of fiberglas circuit board embedded in it. you insert the circuit board into the groove between the top and bottom covers and twist. this is, of course after removing all of the cover screws. some of the cover screws on the display may be hidden under rubber bumpers.
    Jun 28, 2006 | Compaq Presario 1200XL104 Notebook
    Compaq FP 7020 17" Flat Panel LCD Monitor Logo
    425 people viewed this question
    Top Compaq Computers & Internet Experts
    Alun Cox
    Abhinandan  Patil
    Abhinandan Patil
    Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
