Question about Dishwashers
I just bought a Kitchen Aid KUDS30IUBL4 Dishwasher and it came with come sound insulation inside the dishwasher. On the insulation it says to read instructions for installation, but I cannot find such instructions. Can you help? Chuck
  • Dishwashers Master
  • 2,005 Answers
Drape the insulation over the top of the DW to insulate it from the countertop.
Posted on Jul 31, 2010
How do I remove the suds after having used regular dishsoap instead of dishwasher soap?Kitchen aid dishwasher
you will just need to run it a few times. I know of no way to kill bubbles except to dilute them.
Oct 13, 2014 | KitchenAid Kitchen Aid - KUDS30FXBL...
I have a new kitchen aide dishwasher. Does any of the insulation padding come off before installation
No. It is supposed to remain on the dishwasher. It helps cushion the machine noise from vibrating through your counter.
May 26, 2012 | KitchenAid Kitchen Aid - KUDC10FXSS...
CHANGE COLOR OF KITCHEN AID DISHWASHER
Go to www.applianceart.com
They have many options available for changing the color of your Kitchen Aid dishwasher. They also have designs, textures and stainless steel.
Apr 10, 2011 | KitchenAid 24 in. KUDI01FL - Multiple...
Not getting any water into the kitchen aid dishwasher
it could be the water inlet valve. that is definitely a DIY job. but first i would check out the float inside the machine. if it is stuck in the up position, no water will enter the machine. it will assume that it is already full of water. look for a small hat or cone on the bottom. make sure that it slides freely up and down. if it was stuck up, you will have just freed it and solved your problem. good luck
Nov 04, 2009 | KitchenAid Dishwashers
Also have no manual for this dishwasher
Hi
Thanks for using FixYa. You can download the user manual for Kitchen Aid Dishwasher KUDR01TJ from the following link---
Kitchen Aid Dishwasher KUDR01TJ User Manual
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 04, 2009 | KitchenAid KUDR01TJ Dishwasher
Kitchen Aid dishwasher is not cleaning like it use to
Check the following to address this issue further.
1. No water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there.
Jun 21, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
Nov 25, 2008 | Dishwashers
Kitchen Aid dishwasher Child lock light on and dishwasher will not start.
if your unable to unlock the "childlock" by holding down the button, then it woud seem that theres a problem with the user interface itself
Oct 19, 2008 | KitchenAid 24 in. KUDS25 Built-in...
Dishwashers Logo
132 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
