Question about Thetford Norcold RV Cooler/Freezer
I have a Norcold DE828 refrigerator/freezer on my boat. The freezer works fine, but the refrigerator does not cool. Looks to me like the compressor is working.
catriver
  • 878 Answers
SOURCE: Refrigerator won't cool. Freezer works fine!
Pierce, there was a service bullitin put out on this model. TDR-0010A-B. Had to do with normal freezer, warm fresh food compartment. Maytag issued a kit that included a new thermostat and damper assy. to solve this problem. Bullitin came out in 2002. If you are not having a defrost issue and all fans are running normal, I would call Maytag and inquire about the above posted bullitin, It may be covered. Catriver...post back.
Posted on Sep 04, 2006
  • 116 Answers
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Posted on Mar 11, 2007
  • 51 Answers
SOURCE: norcold rv refrigerator freezer
Make sure the thermister is attached firmly to the fins in the back. The boards on a Norcold can be reset a service center familiar with this process is your best bet. It takes disconecting the board and then shorting it out best to leave it to some one who is familiar.
Posted on Sep 08, 2008
  • 171 Answers
SOURCE: DE0061 draws power when not cooling
Hi captstu,
I'm Harvey th Master Plumber.
Your question is: Can you install an auxiliary thermostat on the DC power feed to stop the power draw when cooling is not required?
I understand your frustration. I live on a boat. Since the fridge thermostat is reducing the amp draw when the compressor is off, just remember to turn off the curcuit when you leave the boat and emptying the fridge. You are probly doing this already. Since any modification to a new unit voids the warranty I wouldn't go down that path. The unit should have been tested before installation. Water under the bridge. I agree with the manufacturer. I would tear it out and get a warranty replacement. Sorry, Norcold is right, this is the least painfull way out. It is beter than the cost of repair.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
Techsim
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
Norcold de828 dual compressor
Thermistor on starter winding could be faulty Re: Jeff
Nov 07, 2013 | Refrigerators
I have a Norcold DE-828 Dual voltage referigerator and need a new thermostat. Any idea how I could get one or what I could use to rig up something. I would like to use the dual (AC and DC) but would be...
So the Norcold DE828 along with DE704C, DE728, DE400C, DE251D, DE250F, DE254, DC230, MRFT615B, MRFT630B, MRFT640B, MRFT660, SRBD630, TRBD630, SCQT6406, SCQR6800, and V200 utilize a mechanical thermostat that were made obsolete by Norcold many years ago. Fortunately, I found that third party manufacturer made a fit in replacement for these series of models. That said the new device actually has two controls (one for DC and another for AC) which I actually like more over the original as I can set different temperatures for both. For while I'm on DC I actually like to have a slightly higher average temperature to use less power. That said the new part can be found at https://snip-the-tip.com/DE828.htm or https://snip-the-tip.com/DE828.htm
May 10, 2011 | Refrigerators
Norcold DE 828 on my boat. Haven't been able to replace door seals as no one makes them anymore. Compressor was always loud and always coming on. Recently, no compressor noise only a buzzing or...
Hi Macias
Norcold still should have door seal parts available for this, the parts manual available at this link
http://www.thetford.com/HOME/PARTS/NorcoldIncRefrigerators/DE828EV828Series/tabid/499/Default.aspx
If the compressor is working then the condenser at the back should feel warm while the compressor is running, some of these have a single compressor and some two compressors, the units are fitted with independant power supplies so I would check these first. If you need any further info please come back to me
Regards
Gordon
May 05, 2011 | Refrigerators
I have a Norcold 611 and the freezer works fine, but the refridgerator wont get cold. Any answers?
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 25, 2010 | Thetford Norcold RV Cooler/Freezer
Norcold n621 fridge not freezing or cooling .no fault codes,have 110 ac power,control panel on front works fine.lp burner works fine
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 13, 2010 | Refrigerators
RV freezer cools, but fridge section doesn't
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 09, 2009 | Thetford Norcold RV Cooler/Freezer
My Norcold DE0051 I have to keep defrosting every 2 weeks
Occasional defrosting is needed on these units. 2 weeks isn't that bad considering the environment that it is in (your boat). Every time that you open the door, moist air enters the fridge, and the moisture eventually collects on the freezer plate, and freezes. Putting foods into the freezer that are uncovered also contribute to this a great deal, as do putting in warm / hot foods before giving chance to cool down.
These freezers do not have automatic defrosters. The target environment typically has limited power available. Automatic defrosters would easily double the power requirements.
You can also check the door seals on your fridge as well. If they are not sealing properly, they can also let in humid air which then causes moisture to collect on freezer plate.
Aug 10, 2009 | Thetford Norcold DE0051 Refrigerator
Hi captstu,
Thank you,
Sep 10, 2008 | Thetford Norcold DE0051 Refrigerator
Norcold rv refrigerator freezer
Aug 16, 2008 | Dometic NDR 1292 Refrigerator
Refer Norcold DE 0051 not getting cold
Your cooling unit is shot, I suggest. Most likely, you've lost the R341 refrigerant. Norcold, so they can sell you another cooling unit at $500+, does not make these little fridges with a service port so you can recharge the system. Same with Dometic. Solution is to spend, again, $500+ for a new sealed unit that will fail in relatively short order (I'm on my second in five years) or buy a better refrigerator. I'm opting for a new fridge this go around (Vitrifrigo). Vitrifrigo has the needed service port.
Dec 28, 2007 | Thetford Norcold DE0051 Refrigerator
Thetford Norcold RV Cooler/Freezer Logo
79 people viewed this question
Top Thetford Refrigerators Experts
John Tripp
John Tripp
christian nielsen
tom wright
tom wright
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
