Having a problem recording to the CD - Audio Players & Recorders
Reinstall cd burner or you have no cd burner and the correct cd-r
Posted on Apr 25, 2008
Tascam cd-rw750 - while recording from another CD player (using digital coax connection), machine records for some time and then just "jumps out of record mode" and goes back to the beginning like nothing...
1. First problem: "like nothing is recorded". IS something recorded or has it been left in Pause Mode so long (instead of Recording) that it just got impatient and time out?
2. Get yourself a couple of CD-RW Digital Audio discs to play with until you're past this learning curve/problem scenario. That way you can always erase them and start over without having to discard the disc.
3. Dropouts on playback. Are they repeatable - always at the same place, even on different CD players? If so, the data is bad on the disc. If not, the data is probably marginal.
4. If you have a DVD player, try to play the failed recordings in it. Some DVD players can play back unfinalized CDR's. You may be able to recover the data by copying it back to the CD Recorder from the DVD player. Just be advised that an unfinalized CD-RW may not have 'silence' following the last recorded track due to old data remaining from a previous session, so be ready to pause or stop the recorder when the last track finishes.
5. "Scratches near the outside of the CD". Were these NOT present prior to entering the CD Recorder? Do they seem to coincide with about where the recording may have failed?
6. 20 vs 19 tracks: Is this a constant problem or only when there is a failure during CD creation? If the latter, it would make sense as the last track in isn't technically completed.
Apr 09, 2010 | Tascam CD-RW750 CD Recorder
Can't read blank disk in record drive?
Well, yeah, it's blank, right?
Or do you mean it won't accept a blank CD-R for recording?
You have to use blank CD-R Audio or CD-R Music CD's in a home CD recorder. It will not record on data disc media but it will play almost any CD with CD Audio music on it.
Feb 18, 2010 | KLH CDR2000 2-Disc CD Recorder
Philips CD recorder CDR870 not recording
Consumer CD recorders require CD-Audio or CD-Music blank CD's to record.
May 16, 2009 | Philips CDR870 CD Recorder
Live recording
do some one have a solution to my problem
Nov 27, 2008 | JVC XL-R2010 CD Recorder
Recording files to cd
make sure that you change the bit rate of the file to 16 bit cd audio, then you can write it
Nov 03, 2008 | Olympus VN-4100PC Digital Voice Recorder
Sony RDC W00
Don't know if this will work, but I have an older JVC CD recorder, and it will ONLY record on CD's marked "MUSIC". Worth a try!
Mar 23, 2008 | Sony RCD-W10 2-Disc CD Recorder
Recording
It will record any line level source (CD, MD, tape, tuner). You can only record vinyl records if you have a phono pre-amp.
The best way to use a CD recorder is to use the "tape loop" on your amp/receiver. Does your amp/receiver have a "tape in" and a "tape out"? If it does you should connect your CD recorder to these in/outputs. That way, whatever your amp or receiver is set to listen to, is what you'll be recording.
Shout if you need more help!
Sep 13, 2007 | Koss CDR200 2-Disc CD Recorder
 Grubhead
Grubhead
