Question about Hayward Sp2607x10 Super 1 Hp Swimming Pool Pump
5 yr old Hayward 1 horse power super pump. For some reason this yr it is using twice as much electricity as the 4 yrs prior. The impelor is clean and free of any blockage. The only noticable difference is the housing is extremely hot. No noticable difference in the sound. It is still cleaning the pool properly, any suggestions would be greatly appricated. Thank you........Tracy
  • 760 Answers
First I find it interesting you know the pump is using twice as much electricity. Did you measure the current with an amp meter? or are you looking at your bill. If you're reading an amp meter, then how does it compare to the Full load amps on the name plate. If it less than or equal to the full load ,then there is no problem with the pump. The motor will be hot on a hot day and running 24/7. A pump will draw more current when it does more work(pumping more water) Is it possible you have either cleaned the filter, allowing the pump to pump more water? Have you changed the discharge jets to a larger size? While any of these would drop pressure, it will increase the load on the pump. Have you selected a combination of suction from skimmer & main drain, where you previously only used one? Just a few ideas. Good Luck!
Posted on Aug 01, 2010
What's the capacitors MFD-rate on a Hayward super pump?
this depend on the pump horse power look at the cup is should have this numbers on it
Oct 04, 2013 | Hayward 1HP Super Pump II Inground Pool...
I need a seal for my 1.5 horse power SPL pool pump, but I cannot find it. The company I bought my pool pump no longer carries Jacuzzi pumps. Is there somewhere I can get it or another seal I substitute?
Any pool store in your area should have a 201 mechanical seal available. If not, try looking under pump repair for a shop in your area. It is a very common seal and is interchangeable with the Hayward super pump seal so it should not be hard to find.
John
Jun 20, 2011 | Hayward Pool Products HAYWARD 1.5 HP 2...
Just installed a hayward super pump II 1.5 horse power. It keeps kicking the breaker out. It has a 15 amp breaker, can I just change breaker to 20 amp
could be you have a bad breaker. your old motor stresed the breaker now its weak. that motor draws 9.6 amps @ 230v i wold stay with the 15 amp, just get a new one.. jay the pool pump repair guy in longwood Florida
May 31, 2011 | Hayward 1.5hp Pool Pump Motor Motor A O...
Pool pump turns off after 1/2 hour or so but I can turn on manually after it sits for a while. Timer is working fine. Hayward Super II around 5 yrs old. Do I need to replace this motor? This problem just...
Your pump is protected by a thermal device that shuts it off when over heated. Are you running 110 or 220? In my experience, your pump will run cooler on 220 ... consider coverting if appropriate.
Aug 28, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
I have a hayward pool pump that is about 12 yrs. old and I can not get it to prime this spring
If the basket in the pump and the impellar are clear I would get a "revamp" kit. O-rings for the housing, lid and diffuser. Sounds like the diffuser o-ring is bad or missing...
Jun 14, 2010 | Hayward 3/4hp Super Pump Inground Pool...
2 yr old inground pool Hayward pump louder than normal. Bearings were checked and seals replaced prior to opening this summer.
If there is air in the pump it cavitates and can make it run louder, otherwise it is the bearings in the motor.
Jul 10, 2009 | Hayward 3/4hp Super Pump Inground Pool...
My new Hayward Super Pump is over Amping
Sounds like the wire gauge (thickness) is to small
Jun 04, 2009 | Hayward Pool Products Hayward Super Pump
Hayward Super Pump not turning on
it sounds like your pump is stack it could
bee that something is stack in the pump,
try somehow to turn the motor to see what is binding
get access thrue the pump.
G
May 18, 2009 | Hayward Super Pump 1 1/2 - Hp for In...
Hayward Sp2607x10 Super 1 Hp Swimming Pool Pump Logo
96 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
