Question about Canon PIXMA MP470 All-in-One Printer
Ink is printing streaky, but this is my second brand new ink cartridge. Any suggestions?
  • 700 Answers
This symptom signals blocked printhead, you need to do bit of cleaning, not necessarily cahnge the cartridge.
follow this procedure:
1. download test page with alternative from this site black:
http://www.inkjetcartridges.com/_black-print-test.html
and colour:
http://www.inkjetcartridges.com/_color-print-test.html
2. print page each and assess the colour and streaks. if on the beginnig of the page you do have errors and on the bottom all is corrected, this meant that you just cleaned your printhead nozzles and problem is solved.
3, if problem persist, from stationery store purchase few pages of absorbent paper, weight of about 120 to 160, do not use thicker than 160 and print these colour pages again,
4. print control page again and see if any improvement was made, if there were no changes, follow this procedure:
a. remove cartridges from craddle
b. determine what is ink solvent, water, isopropyl alcohol or methylated alcohol - correct solvent will be that which do not precipitate or curdle the ink
c. touch with absorbent tissuebottom of the cartridge and check if it is leaving even print, if not, whipe once with solvent
d. put a drop of solvent on gold/silver buttons inside of the craddle, allow to sink for about a minute, whipe off with absorbent tissue
e. put again a drop of solvent on the button in the craddle and insert ink cartridge
f. print test page, page will be very weak on the top (solvent print first!) and improve as it prints down, if necessary, print again colour or black test page from 1.
this should solve your streaking head problems, if they still persist, this meant that print heads are really well blocked by caked ink and usually is cheaper to change printer than change the head in it...
if you find this advice useful, please do not hesitate to leafe your feedback and vote for me, thanx!
Posted on Aug 01, 2010
Using edible ink in a cannon IP 3500 and is printing with streaky white lines i have done all cleans including a flush of purified water. Any suggestions?
use a mixture of ammonia and water solution. Place the cartridge printhead in the solution and leave it overnight.
It will fix the print head.
Jan 25, 2011 | Canon PIXMA iP3500 Printer
I'm getting cyan blue streaks on print outs
The streaky marks can also be because of ink on other parts of the printer like the rollers etc.
It is more prominent when you use NON genuine cartridges, as these are sometimes refilled, with the internal pressure balance not perfect which results in ink just running out by itself.
I would recommend you have your printer cleaned by a professional, that will also replace the collection pads. (these pads collect excess ink from the cleaning process etc and once full can also cause lines) This service are in the order of $20-$50 depending on where and by whom.
You can do it yourself, if you are technically inclined, and repair / service kits (with new pads) can be obtained cheaply online as well as from ebay and usually includes instructions.
Feb 28, 2010 | Office Equipment & Supplies
My printer just prints in very light red
You are out of red ink, OR the print head is clogged (but that usually) produces streaky lines more so than light color.
You can try cleaning the print heads:
  1. Open the 3845 desktop assistant c00026601.gif icon on your desktop or start menu
  2. click on utilities or tools
  3. click maintenance
  4. click clean cartidges
  5. follow the on screen instructions
If that doesn't help, you're either out of ink in which case:
  1. Buy a new cartridge (or have yours refilled professionally)
or your print head is clogged beyond repair, in which case:
Happy printing.
Jan 27, 2010 | HP Deskjet 3845 InkJet Printer
Does not print correct colours and is streaky printer
ink cartridges not compatible with printer properly and these need calibration from pc.
secondly ink primer section is fill with waste ink needs cleaning
Oct 30, 2009 | HP DeskJet 5150 InkJet Printer
Quality starts out good, and then fades quickly
You probably running out of black ink. Try replacing with new black ink cartridge.
Try to run a test print.
Jul 18, 2009 | Office Equipment & Supplies
Streaky printing
At most cases of printer, especially which have done refill at cartridge, print quality is poor or streaky. Many factors influencing this printed result. To overcome print quality is poor, maybe following tips can usefull to prevent printed pages are missing lines or streaky.
First step is ordinary to be done many people when print quality is streaky that is doing cleaning. To get good printed result, sometime this facility is used more than once.
Use Ink Refill with Quality Nicely
For printer have refilled, sometime the quality of printing is also influenced by ink. If will fill your printer again, use ink which the was quality of nicely. I have tested some refill inks at cartridge which have been ascertained still nicely ( sorry: I do not want to publicize result of this attempt). In the reality result make me surprise, there ink of refill making the printed quality is crummy. To choose ink refill read following tips :
  • See viscosity of ink, every merk of ink refill have difference of viscosity. Don’t use Ink refill too jell. Difference of this viscosity is no measure reference viscosity of ink from factory maker of printer
  • Don’t fear to try some inking merks. Done this, you’d find refill ink fitt with your printer. I now only using one merk of refill ink ?.
  • This suggestion of forum, but I still not yet proved. May believe or not. Good ink aroma of soft usually.
Change Original Cartridge
This is last choice. A lot not like to do this ways, because price of original cartridge still costly. Alternative, you can use compatible cartridge which the was price of cheaper than original cartridge. At newest printer, usually there are two until four cartridge in one printer. And price four same cartridge almost at the price of printer even there are some costlier.
Let me know !
Thanks
Fame !
Apr 02, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Streaky print
defective carriage. machine is brokeded (pronounced BROKE-DEAD). part unavailable, cannot be fixed, if machine is still under warranty then either take it back where you bought it or contact HP for replacement.
Oct 02, 2008 | HP Deskjet 6940 InkJet Printer
Lexmark x93
What model printer is this? Is it an official Lexmark brand or a generic brand cartridge? If it is a generic brand it must not have been manufactured properly. Your old cartridge became streaky towards the end because of the fact that Lexmark ink tends to dry up very quickly. It needs to be used every now and then or it will start to clog the holes at the bottom of the cartridge. Also check to see if the box has some sort of expiry date. Some cartridges have a shelf life on only 2 years. It may have been on its way out.
Thanks for reading!
Hope this helps
May 01, 2008 | Lexmark 83 Color Ink Cartridge (Twin Pack)...
Canon PIXMA MP470 All-in-One Printer Logo
1,370 people viewed this question
old marine
old marine
