Question about Toshiba Televison & Video
When I put the DVD into my machine it says, "Region Code Error" Is there a way to break the code so I can play it on my machine?
My dvd recorder say this disk is unrecordable and i get a error
e 15 2a037304.
Posted on Aug 01, 2010
4 Suggested Answers
nandosnut
  • 112 Answers
SOURCE: region free code needed
Sadly, no: you need to buy a chipped remote. You can find these on eBay for around £12 Sterling. Look for the multishot devices (eight uses) rather than single shot, as they can work out a lot cheaper if you (and friends/family) have more than one unit to unlock. Some dealers will even offer a £5 rebate on return of the remote if you do not wish to keep it as a spare.
Note that doing this without express authority from Panasonic will render your warranty void!
If you're still having problems, let me know and I can sell you my half-used remote!
Posted on Apr 21, 2009
SOURCE: Daewoo DHR-8414 DVD Recorder : Breaking region code
Instructions for changing the region:
  • Press the SETUP button
  • Select SYSTEM INFO
  • Using the remote, press 1 1 0 1
  • When the region shows, press 0
  • Press the SETUP button to exit
Posted on Nov 15, 2009
ekmoetweet
  • 124 Answers
SOURCE: Yamaha DVD S1700 player multi-region unlock code
see if this works
  1. Power on
  2. Press PLAY
  3. Enter 2, 7, 4
  4. Enter 222 222 005 255
  5. Press PLAY
  6. Power off
Posted on May 11, 2011
Incorrect disc region code
Look at the region code of the DVD that plays on the vehicle DVD if it is the same of the others that do play it's not a region code issue. If the others are a different region to the DVD that plays or the disc says it is region free. Then you might have a problem with the region code settings on the machine. You can look up the model number of that player to see if you can change the region code.
Otherwise check out the player to see if it needs cleaning or is faulty.
Aug 14, 2016 | Televison & Video
Bought a new dvd it will not play, its giving me a regions code error. what is the code, and how do i put it in the dvd player?
A regions code error means that the player is not compatible to play a DVD from a different region than what it was designed to play. For example, if you purchased your player in the U.S. or Canada then it is a region 1 player and therefore will play DVD's from region 1.
Here is a region map http://www.mvps.org/marksxp/WindowsXP/dvd/regions/regions.php
There are however, ways around this as some manufacturers of players have made a way to be able to allow the end user to unlock the software codecs that are for different regions. You will have to search for an online source that has a download or a procedure to follow to unlock your player.
Nov 01, 2010 | Emerson EWR20V4 DVD Recorder/VCR
Region not supported
Other people's machines may be hacked. Most machines lock into a region code after 5 plays of any one region. But some machines are hacked to allow all regions.
May 07, 2010 | HP Televison & Video
I'm getting an error message ''Check Regional Code''. How do I get rid of this.
The player has been set to play DVD from one region, so if you put in a DVD from another region it will flag it up as it can't play it. You can find out which region the player is by looking on the back it will have a number. That's the region it is set to. For example if it says 2 then you won't be able to play any disc other than region 2 ones.
However you can hack into it, by typing the model number of the DVD Player into google and the words "region code". You should get the instructions to change the code to 0 (zero) then it will play all discs.
Dec 15, 2009 | JVC Televison & Video
My samsung dvd-hr753 comes up with a message saying ''this disc can neither be played or recorded'' when i put in some pre-recorded dvds... what is causing this? how can i fix it? I thought that the...
use the procedure in the link
http://www.videohelp.com/dvdhacks?dv...HR-753&hits=50
You have to enter a code specifc your region.
Using the Remote:
Make sure there is no DVD in it.
Make sure it's in DVD mode.
Turn it off.
Turn it on.
Wait for it to start up (showing DVD mode in the display)
Press Repeat (for a half a second?).
Enter the code for your region
Region 1 use 2,9,3,3,4,9
Region 2 use 5,7,5,3,8,9
Region 3 use 5,6,7,3,2,9
Region 4 use 7,6,8,8,4,9 <----- try this for region free setting
Region 5 use 5,3,8,1,4,9
Region 6 use 2,4,4,6,2,9
When you get to the second to last digit you *may* see your current region.
When you see "9" appear you have entered the code correctly.
Now be quick and eject and close the DVD drive before it vanishes.
Use the buttons on the machine to open/close the drive.
You have to be confident and quick with your button presses; it's very sensitive to pauses etc. If it does not work the first time keep trying.
Good Luck.
Nov 01, 2009 | Televison & Video
Our Sony DVD player will not playimported DVDs from the UStates
1) those DVDs are coded in Region 1(Canada, United States; U.S. territories; Bermuda)
you will have to change the region code on the dvd-rom to region 1
2) if you bought the stand alone DVD player in the U.S. it will play region 1 dvds and nothing else(some dvd players will play region code 1-6)
3) to change the code in windows vista you'll have to go under the drive property's in the device manager go to the dvd region tab and set it to what ever the number on the back of the dvd is WARNING you only get 4 changes before the drive locks you out permanently then your stuck with what ever number you put in on the 4th try you've been warned
windows xp/2000/98/me
you'll have to change the region code from your software player again your limited on how many times you can change the region code before you have to reinstall the dvd player software
Feb 02, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
Code error country
insert the dvd disc from other region then the region code error will flash on the tv screen, then press the on screen button on your remote twice, then search search for the clock and set it to 0:00:00 and enter and it will automatically play.
Jan 09, 2009 | JVC XV-N320 DVD Player
see if this works
  1. Power on
  2. Press PLAY
  3. Enter 2, 7, 4
  5. Press PLAY
  6. Power off
Nov 18, 2007 | Televison & Video
Televison & Video Logo
283 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
