Question about Akai LCT3785TA 37 in. LCD HDTV
Blown SK24 and SK1 on the powersupply model# Mlt386x.
What are the replacement parts?
  • d_namiranian Aug 01, 2010
    Blown SK24 and SK1 on the power supply model# Mlt386x out of 37" SCOTT LCD TV. I would like to know what are the replacement part numbers.
  • 10,594 Answers
Complete power supply board replacement is good because component level repair is not possible because spare parts are not available.
Let me know if you want to replace complete power supply board to provide you further info.
Thanks.
Posted on Aug 01, 2010
  • 7 more comments
    you did not answer my question. Why SK24 and SK1 are blown? what are these two parts? Why the repair is impossible? How much these boards cost?
  • Shahid Electronics
    Shahid Electronics Aug 01, 2010
    Repair is not possible because there is no schematics available for this power supply.
    When drive signal of FET got disturbed for some reason, FET got shorted instantly.
    Power supply board is available for $122
    I am a Technician and I have checked the QA1, which the part number is 20N60 and it is good. Is this what you concern about?
    Yes, I was concerned about that FET
    Do you have service manual of LCT3785TA?
    No,I do not have service manual. Most of the service manuals
    are worthless. I don’t think technician
    should use service manual as long as she or he understand how the system works. I need the schematic diagram and all I need
    to know what is the SK24 and SK1 part number.
    OK, right now I do not have service manual but trying to have a copy. If you can wait for few hours then I might be able to provide you helpful info after looking into schematics.
    Thanks.
    OK!
    I will be waiting for your reply.
    thanks.
    ok, I'm waiting service manual delivery email.
    as I explained before, service manual does not have schematics for power supply section. I received service manual copy and there is no power board schematics.
  • Akai Master
  • 6,993 Answers
please can you rephrase this question so that an accurate solution can be proffered? I don't really understand the question and its not clear enough.
I look forward to your reply.
Bye for now.
  • Walesarumi
    Walesarumi Aug 01, 2010
    I just saw your comment have I have sent my first post.
    The replacement part you need to by is a complete power supply board. Replace the whole power supply board will be the best part to buy because if apart from the blown SK24 and SK1, other components as well might be defective on the power supply board. So replacing only the SK24 and SK1 might not solve the problem.
    Therefore, replace the power supply board.
    I hope the above makes sense to you.
    Good luck.
Is SK1 a fuse?
sK1 is an open-source illustration program for the Linux platform
Jun 15, 2014 | Western Digital Caviar® SE WD5000AAKB...
Power on button not working
there is something wrong in other parts of the power supply
We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Feb 01, 2014 | BenQ MS612ST 3D Projector
HP LaserJet 4200 F2 Fuse Blown
Replace the power supply. Sorry.
Jan 09, 2013 | HP LaserJet 4200dtn Printer
HOW TO FIX POWERSUPPLY PROBLEM
Replace all blown or bulge or leaked capacitors with same value. That will fix your power supply problem.
The hardest part is to disassembling your TV cover, cause you will need to pry off the snap in lock at the edge of your TV.
Power supply board should look like this. Examine the capacitors in the board
After replacing blown capacitors...it should work again.
Things you will need.
1. A plastic flat end screw or any object with flat ends....to fry off the cover
2. Soldering iron.
3. Soldering lead
4. Soldering pump.
5. Flat and Philip Screw
6. Replacement capacitors (of same value with the blown one) that you can buy to any electronics store.
Hope it helps
Mar 06, 2012 | Televison & Video
Wont turn on model # LCT 37SHA need part #MLT386X
MLT386X is available on ebay as a rebuild service or by itself.
May 01, 2011 | Scott LCT37SHA TV
MLT386X power supply
Hi wanagetdrunk, Nice handle is that a question or a statement? To test the fuse with a voltage meter you will need to test each end of the fuse and make sure the voltage is the same on both ends, in other words you want to make sure the voltage is passing through the fuse. If you have a multimeter set it to ohm's and measure across the fuse,if the fuse is good it will read 0. Let me know if this helps and please rate this solution. lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Jan 13, 2009 | Akai LCT3785TA 37 in. LCD HDTV
Mlt386x
Hi
Please go to ebay and buy your power supply board:
AKAI LCT3701AD POWER SUPPLY BOARD MLT386X
Oct 30, 2008 | Akai LCT3701AD 37 in. LCD Television
Power won't come on
Hi mitchymitch
Check if the fuse on the Powersupply Board ( the one with AC socket on it ) isn't blown.
Don't just check it with the eye , replace it ! If this doesn't solve the problem at hand then you will have to get the Powersupply Board replaced.
You will obviously have to take off the top cover of the Projector in order to get to Powersupply.
Good luck and thanks for using Fixya !
May 21, 2008 | NEC VT460 Multimedia Projector
Epson ELP-3300 powers up bulb light is green but...
Ah ok , so it doesn't start up at all.
Is there any power at all on the unit , like LED's lighting up ?
If there is then it would be your Ballast ( lamp's powersupply ) that need replacement.
If there isn't - then you should check on the Powersupply Board ( where your AC inlet sits in ) if the fuse is blown and if not , then you will have to replace the Powersupply Board.
Apr 22, 2008 | Office Equipment & Supplies
TV won't come on
Im not at home right now so I can not get the exact part number but you need the powersupply for this set. There are numerous bad capacitors on this board and you might have a blown main on here. Replacing this will repair your set back to working condition.
Josh
Feb 21, 2008 | Mitsubishi WD-52631 52" Projection HDTV
Akai LCT3785TA 37 in. LCD HDTV Logo
469 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
