Question about Sport & Outdoor - Others
Have been working on a 1995 700 waveraider thinks i am not adjusting carburators correctly any ideas on how to set them
    Top Expert:
  • 81,400 Answers
Do u have a carb balancing tool? if not u can't get them set right,it is absolutely essential. You can buy a generic tool online for about $20 with shipping, it is very basic but it works, it comes with instructions and also very good instructions are avail if u just google the question. 1st site is the place to buy the basic tool u need. next site is an article on doing the synchronization of multiple carbs and making up your own tool, it is a PDF file so give it time to load..
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC-C10-7115
http://www.zivney.net/library/carbsync.pdf
Posted on Jul 31, 2010
Hi i have a 4stroke 125cc pit bike it wont start tried bump start sorted turned over but when i reved it didnt respond then died any ideas
Tryd go to auto shop and check the carburator of your motor and clean your air filter adjust air setting in carburator and put a new fuel pump check fuel setting in carburator
Jan 18, 2014 | Motorcycles
1995 Yamaha Waveraider revs up on its own
Posted by accident in wrong area--this is for air conditioner questions--try to repost a new question in the correct area if you still need help.
Jun 14, 2012 | Yamaha Wave Raider 700 760 1100 Waveraider...
Adjust carburator on homlite chain saw
Hi
If its an old Homelite you should have 3 screw on the carburator.
First bigger screw for adjust idle on the butterfly.
The 2 other for the mixture. One screw is ''L'' for low rpm mixture an other screw is ''H'' for high rpm mixture.
First the idle screw. It should just open a little bit the carburator butterfly.
Second full close both ''L'' and ''H'' screws (turn clockwise).
After open both ''L'' and ''H'' screws 1/2 to 3/4 turn (conterclockwise)
Normally the saw should start. Tune the ''L'' screw to have the motor running at idle if idle is to fast at this point is not important. After motor is running by itself at idle tune the ''H'' screw.
Full throttle tune the ''H'' screw to be able to pass from low rpm to high rpm with no lag.
Than at full throttle open again a little bit the ''H'' screw to make the high rmp mixture more rich.
Becarful if ''H'' screw is not adjust correctly the mixture will be to poor and motor damage can occur.
It may be necessary to re-tune a very little bit the ''L'' screw and idle screw after the correct setting of the ''H'' screw.
If it still not working carburator kit may be needed,
On some newer model there is no adjusting screws in this case see if a carburator kit is available for your model.
Feb 07, 2011 | Garden
1987 dodge ram 50 sport bogging at 55mph
The carburator needs to be retuned under a load to correct the problem. Take the truck back to the place were the carburator was worked on, and have them to check the carburator out for correct adjustments. Hope this will help you !!
May 11, 2010 | 1987 Dodge Ram 50
It is a 1997 husqvarna 51 idle is to high when i start it then warms up and wont idle at all
The carburator may need adjusting. If this doesn't correct the problem check the air filter then clean or replace it. If this doesn't correct the problem inspect the diaphragm for holes or if it has become hard. If so replace it. Otherwise the carburator may require rebuilding or replacing.
Mar 22, 2010 | Husqvarna Chain Saw 20" Bar
What are the adjustments for the high and low mixture screws on the carbureator? the carbureator is from an echo 500vl chainsaw.
Echo thinks your actual model number is CS-550EVL. Page 14 lists the starting points for carburetor adjustment here:
http://www.echo-usa.com/pdf/documentation/CS550evle_010186.pdf
Additional manuals for you saw can be found here:
EchoUSA
http://www.echo-usa.com/documentation.asp
More choices can be found by typing CS in the model: window then clicking “Search”.
Once initialized this is the best procedure I have found.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too. HTH
Lou
Feb 13, 2010 | Garden
New carburator and it runs worse
Check your fuel pump,it sounds as if you have excessive fuel pressure.
May 05, 2009 | 1984 Ford F 250
How do i begin adjusting the carbs?
1st-clean air filter and oil,fresh plugs,good fuel,valves adjusted correctly,check for tears or cracks in intake boots,fire in all cylininders;minimum compression & w/in10% of each other in all cylinders, and no exhaust gasket leaks. once these components are w/in specs. and operable the carburators can be adjusted, as long as they are internally clean and operating as designed.1st- set high idle, then set idle rpm, now synchronize vacuum on carburator set,now readjust idle rpm.
Feb 19, 2009 | 1980 Yamaha XS 400
Sport & Outdoor - Others Logo
26 people viewed this question
Top Sport & Outdoor - Others Experts
Marvin
Marvin
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
