Question about Mission MS8 Subwoofer
No power on subwoofer mission v6as ch - Mission MS8 Subwoofer
Where can i buy replacement mid drivers for mission 782
Mission parts available from missionparts@hotmail.com
Dec 06, 2012 | Mission 782 Main / Stereo Speaker
Hi, I have a Mission M5AS Sub and for some reason it has just stopped working. The power light is on, but it doesn't become active when music is played. Simple to resolve or a job for Mission? Any...
Hi, yes there is a rather simple method for testing the actual subwoofer unit, simply plug in a known good rca cord into the input-make sure if there is a switch for level input that it is on the back make sure it is switched to line and not level, next plug in rca cord, turn on unit-stick tip of finger on tip of rca cable. This should gernerate a"HUMM" in the subwoofer if everything is working correctly. Thanks for choosing FixYa, I hope this was of some help,good luck Prodzilla.
Apr 13, 2011 | Mission M5AS Subwoofer
My Mission MS10 subwoofer keeps blowing it's fuse. Possible problems?
Anything in the power supply will cause it, look for damage or burnt parts, anything on heatsink. A transistor with a short circuit. For instance if you put an ohm meter probe to the leg of one and the other probe on to another leg, it will be read on the meter as if you had put your probes on the same leg.
Jan 11, 2010 | Mission MS8 Subwoofer
Can i purchase a replacement subwoofer for a mission fs2
try a professinal repair sound store, they help you.
Dec 22, 2009 | Mission FS2-AV System
Blown fuse in mission 700as subwoofer
if you have access to a multimeter, you should test you impedance (ohms) Ω, check to make sure the speakers reads higher than the amplifier needs; this will result in less strain on your amp and diminishement of sound...For example: if you connect two 4Ω
speakers in series it results an 8Ω circuit (least strain). and if you'd take the same two speakers and connect them in parralelle it would result in a 2Ω circuit (most strain).
Jul 24, 2009 | Mission 700 Main / Stereo Speaker
Subwoofer blowing internal fuse as soon as you power up
check your bridge rectifier if no short,audio stage is blown
Jul 15, 2009 | Mission M-CUBE System
Mission ms8/ms10
Silly question but did you check the fuse and if so is the sub pluged into the sub out put on your amp and not the sub six channel input as this will result in no sound.
hope this helps.
CABLE GUY.
Jun 29, 2008 | Mission MS8 Subwoofer
Mission MS8 Subwoofer Logo
194 people viewed this question
Top Mission Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mission Audio Player and Recorder Expert? Answer questions, earn points and help others
