Question about Panasonic PT-47WX49 47" Rear Projection Television
PT-47WXC43G Im having a problem with the picture having blue edges aroung the picture. I know it is the convergence Ic's but the question I have is could a PS3 game unit have caused this to happen?
  • Panasonic Master
  • 8,617 Answers
No the ICs wear out the PS3 could contribute a little. But you will need to replace both STK392-110 Convergence ICs. You can get them at this link with free instalation instructions with pictures so you can do the repair yourself. Here is the link
Posted on Apr 27, 2008
When lining up convergance, green lines up in the center, red lines up perfectly with that but the blue is way off. on the single cross and even more off on the multiple cross but mostly on just the right...
hello the problem is down to the convergance ic, there are 2 big black chip that sit on metal frame called a heatsink they are usually located behind the tuner board on the right side of the tv,stk-110 may be the part number, also in front of the ic are some resistors and 2 capacitor at either end these will need to be tested ,
you have to desolder 1 end of the resistor so you get a proper reading on the mulitmeter, it's lot of work but if you can do it yourself it would cost about 40 to 60 pound good luck
Sep 09, 2010 | Panasonic Televison & Video
Panasonic PT-47WXC43G green ONLY is bowed on bottom and top
It still convergence chip problem, check big resistors nearby these chips that would be open or devalued and causing problem, specially in green convergence area, your green tube/ gun is just fine and just not getting convergence output signal to show correct image.
I would suggest to download service manual copy of this tv for small fee from any website and fix the issue with schematics help.
May 02, 2010 | Panasonic PT-47WXC43 47" Rear Projection...
PT-47WXC43G green convergence no longer in alignment...
you can get the following repair kit at the following link. which contains the parts and the CD which has the instructions on how to do the repair. The kit you need is called the PT-53WX53G, PT-56WX53G, PT-
47WX53G, PT-47wx33G, PT-47WXC43G
and PT4743G. Convergence repair kit its at the following link.
Jul 15, 2009 | Televison & Video
PT-47WXC43G-Red and blue look blured picture. Blue looks like sideways hourglass. Red is double image on the sides.
Convergence ICs you need two of them STK392-110 you can get replacement ICs at the following link with free instalation instructions with pictures so you can do the job yourself. Here's the link.
Jun 26, 2008 | Televison & Video
TNP2AH046 board
Yes. let me know to contact you
May 20, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT -47WXC43G 42 inch TV
replace the convergence amp ICs both of them. They cost about 15.00 each
Mar 09, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Convergence chips 110 installed but unsuccessful
check the resisters or send the board in to
if you find bad resisters chances are you blew the ic too
Feb 26, 2008 | Panasonic PT-47WXC43 47" Rear Projection...
PT-47WX53 blue convergence PROBLEM
Sounds like you have a blue foldover in the convergence. Since tv has been worked on it could be bad ic, maybe not original, generic. I would say if you can open set and look in, look for the blue it should be marked. look for a loose connection. If you can have someone to gently tap around that blue amp and see if it moves are go away, it might be a simple loose connection and needs soldering. If not then my have to change ic again. Becareful cause set would need to be on to really check. Hope this helps.
Aug 15, 2007 | Panasonic PT-47WX53 47" Rear Projection...
you will need to change or have the convergence IC's replaced I'm afraid. Good Luck
Panasonic PT-47WX49 47" Rear Projection Television Logo
56 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
