Question about Vacuums
Motor works, but no suction! what do you think?
    President:
  • 1,673 Answers
No suction usually means a clog somewhere or bad filters. The hose and/or the dirt inlet by the brush roll may be coulded. The belt may have stretched enough to not turn the brush roll under load and that can seem like no suction. The worst is the motor is running at full speed, which would mean replacing the motor.
Posted on Apr 24, 2008
Hoover S3639 Suction Failure/Turns itself off and restarts later
If you did all this already the motor is not having power, must be replaced.
Sep 06, 2008 | Hoover S3639 WindTunnel Bagged Canister...
Dyson dc17 No suction
i have the same problem and none of these solutions help. they are all for if suction works but brush doesn't. that isn't what she is saying. brush motor works fine. It's the Suction motor that never kicks on. Mine is doing it now and I would love a fix for it. Resetting suction motor. Not brush....
Jan 02, 2012 | Dyson DC17 Animal Bagless Upright Cyclonic...
My miele titan is not turning on when plugged in. i think it might be some sort of clog? but the electric head is working... help!
Wow!, that's not typical of a Miele, especially a new model like the Titan which has been on the market for less than 2 years. If I read this correctly, your power nozzle (electric head) is working, but the main suction motor is not. Thta's usually a sign that the carbon brushes in your suction motor are stuck or too short. Again, not a common problem with Miele. A clog could cause your machine to run hot from reduced airflow and then shut down until it cools, but it would shut the whole machine down, not just the suction motor.
Is your power dial, (located just forward of the main switch and cord retractor buttons) set to minimum? If so, you just might not be getting enough suction. If, after turning the dial to maximum, you still get no suction, then you should definitely take it back to the dealer you bought it from. You have a 7 year motor warranty and a 1 year warranty on all non-wearing components. If you bought your vacuum on the internet then you can go to www.mieleusa.com and search for a local dealer. There is a 'Dealer Locator' link on the left side menu.
May 18, 2010 | Vacuums
Lack of suction
Do not think its motor .......Yoy need to see thats its not Cloged if so clean.......
Feb 21, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Motor makes loud growling noise, no suction on model 270 i Miele canister style vacuum
Hi there SmartAlec from NelsonVacuums.com.au here. Unfortunately that normally means the motor has shot its bearings and/or its carbon brushes. I think it is time to purchase a new one. On the bright side there are some rreally great vacuums out there! If you want any help choosing a new machine send me a message. Happy Vacuuming :)
Sep 04, 2009 | Vacuums
NO SUCTION
If you have no suction, there are only a couple of things that could cause it. As you have checked for blockage, and changed your filters, you may have a vacuum motor with bad bearings, or broken fan blades (inside/on the vacuum motor). Either symptom points towards a vacuum motor being bad and needing replaced.
Jan 21, 2009 | Electrolux Central Vacuum
Series 6500 motor shuts off, vacuum continues to run, not suction
It's tripping the temperature overload in the motor. The most common cause for this is a clogged hose. Take the hose loose and attach it to the exhaust port under the back cover. You should be able to see if it's clogged and unclog it. I might also suggest taking it to your dealer. I don't think that machine's power nozzle should run if the overload is tripped. It sounds like the wiring may have been modified for some reason, but I can't swear to it. Good Luck!!
Nov 25, 2008 | Electrolux Epic 6500 Vacuum
Hoover Windtunnel
Either the hose has a clog, or the inlet down by the belt is clogged. Is there suction at the end of the hose, if not then it is clogged. If there is suction, then it has to be clogged down below by the brush roll, check that inlet. There also is a filter at the bottom where the dirt cup (and bag) is, check it also.
Dec 28, 2007 | Vacuums
Hoover Windtunnel
Mine does the same thing. There is no suction. I found that there is a door that opens when you tilt the handle in the down possition. I think there should be a spring in place so it can open. Until I find a replacement spring I have to open the door manually throught the opening under the light.
Oct 15, 2006 | Hoover U6630-900 WindTunnel Bagless...
Vacuums Logo
184 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
