Question about Nelson Sprinkler: Traveling Tractor
After 5 minutes the sprinkler stops,bleed presure off,then she runs for awhile?
  • 4 Answers
Is your stop button on bottom pulled all the way out?
Posted on Aug 03, 2010
Shows station 2 and 3 on screen but watering does not commence. Have reset numerous times same result.
bad solenoids or valves. also check and bleed air out of sysyem. bleed screws are on top of valve
Dec 12, 2015 | Orbit Irrigation 57856 6 Station Easy Dial...
All six zones run but cannot get one of the zones to completely shut off so I get a substantial leak so I turned of the system what should I look for
Hi Michael:
The solenoid for the leaking zone will probably have some debris in it. You could try to dismantle and clean it, otherwise, replace and you should be OK.
Cheerfuls.
Sep 14, 2015 | Rainbird Rain Bird Simple Set 6-station...
How do I stop water from coming out of sprinkler heads after the pump cuts off
There will be water come out of the heads for a few min after they shut off to bleed the pressure off there is no way to stop it you might turn your system timer down a little
Sep 14, 2014 | Garden
Run times for 22sa sprinklers
If it is a rotating glorified streamer nozzle designed to conserve water. Double the run time. Not sure what your watering plants or lawn. if it's a lawn 20 min should work.
Mar 20, 2014 | Rainbird Rain Bird 22SA-Q 6-Inch 17 to...
Rainbird RC-Bi timer issue
Copy following link to identify sprinkler & irrigation timers on market, and buy another one.
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Install heavy-duty mechanical timer.
http://waterheatertimer.org/How-to-wire-Intermatic-sprinkler-timers.html
Replace sprinkler head
Check that voltage is at least 80% amount that shows on rating plate of timer. ie: 80% x 125V = 100Volts
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 29, 2013 | Rain Bird Hardware & Accessories
Brand new nelson tractor sprinkler runs for about 20 minutes and then stops. water pressure is fine
Too heavy a hose can cause this (after 20 minutes, there's just too much hose behind the sprinkler to drag any further).
If the unit shuts off entirely, the sprinkler could be hitting the top of the hose (wheels digging into soft soil) and tripping the auto shutoff under the unit. (Mine does this every once in a while).
Apr 11, 2012 | Nelson Sprinkler: Traveling Tractor
I have a 2004 dodge ram 5.7 liter . O have difficulty starting my truck. Some times it starts fine but other rimes I have to pump the gas and wen it starts a small amount of smoke comes out.truck runs...
I have seen two different problems with symptoms like this. 1. A leaking injector. If one of the injectors is leaking a small amount through the pintle on the end of the injector it will bleed the fuel system presure off and dribble fuel into the cylinder, fouling that cylinder. When you try to start it the fuel that has pooled into the manifold will create smoke when it does start. And since the fuel pressure has bleed off to zero PSI in the fuel supply lines it will need time for the fuel pump to recover the system up to normal operating presure. Presure testing (bench test) of the injectors is needed to verify this. 2. A bad fuel pump, relief valve, or bleed-back check valve will bleed the fuel system presure off while it is sitting. To find out if this may be the problem a fuel presure guage set needs to be installed and then run the engine, verify the operating presure is normal, and then shut the engine down and watch the fuel pressure for exessive drop.
The leaking injector is more apt to create the smoke when it fires up, but both can cause this. I would start with check #2 first. Of course there are many other things that can cause symtoms like this but these 2 are the most likely causes.
Hope this helps, if you have any further questions just ask!
Mar 31, 2011 | 2004 Dodge Ram 1500
I have a 1991 Mustang GT, and it runs awhile but goes dead,I have replaced the fuel filter and that did not stop the problem. The car runs about 5 or 6 minutes but shut down and will not restart, but will...
test the fuel pressure first. use a guage and watch it till engine dies. also the guage has a bleed off hose, run a small amount of gas into a cup and check for water
Apr 06, 2009 | 1999 Ford Mustang Cobra
Geo Metro 1994, diagnose no fuel presure problem.
Quite a few things can cause a car to die after idling for awhile, but if you have verified that the fuel pressure is actually dropping when the motor dies, the likely culprits are:
1) Electric fuel pump in the gas tank is bad
2) The fuel pressure regulator (on the throttle body) is bad
3) An electrical problem in the power to the fuel pump (like a bad fuel pump relay or lose ground wire to the relay's circuit)
Apr 04, 2009 | 2006 Geo Metro
Nelson Sprinkler:  Traveling Tractor Logo
131 people viewed this question
Top Nelson Garden Experts
Dennis
Mike Squire
Phil Walker
Phil Walker
Are you a Nelson Garden Expert? Answer questions, earn points and help others
