Question about Craftsman Garden
I need a diagram of the layout for a craftsman mower deck
Im looking for a diagram that shows where all the springs go on my craftsman mower deck,the model # is 917.255821,its slipping belts.
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
  • 6 Answers
SOURCE: Craftsman riding mower loose belts need tighting
http://www.disruptit.com/manuals/L0403195.pdf
Here ya go.
  • 5 Answers
SOURCE: i need belt diagram for 42 in deck
You can go to the Sears website an download a free owners manual that shows what you need.
Posted on Apr 25, 2009
  • 246 Answers
SOURCE: Replace V belt on mastercraft 38 inch 12 hp lawn tractor
Hello
The Breakdown of the Unit Usually Shows the Belt Routing.
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
  • 376 Answers
SOURCE: belt diagram craftsman 917 2733100
Assuming your model number is 917.273100, go to ... http://www.searspartsdirect.com/partsdirect/index.action Enter the model number, hit search then scroll down to Ground Drive
Posted on Jul 29, 2009
No, Need to see a diagram of the springs that are on the deck of riding mower Model #247-288851
Hope this helps. Craftsman Tractor model #247288851 Deck and Belt Diagram
Apr 11, 2015 | Garden
Need diagram installation. A drive belt.
If you have a Craftsman, under the seat is the model number. Go Here to get the operators manual. The manual will have all the belt diagrams. Water Filters Lawn Garden Appliance Parts
Oct 14, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Fix a motion drive belt squeals on a Craftsman 24 hp 42 in. Deck Lawn Tractor - CA Model
If I understand the issue correctly, the belt that drives the machine's transmission squeals. When does it squeal? When engaging the clutch? When in motion?
Typically it's the condition of the belt. It's likely slipping due to stretch, wear or from an oil leak causing it to slip, or simply due to a loose idler pulley, worn idler pulley bearing, broken spring. Look for all that stuff. Look at the drive belt and inspect for wear, cracks, fraying, missing rubber, etc. Replace it if any of those conditions are found.
Jul 09, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
How do i troubleshoot 42 inch craftsman lawn tractor on which the mower deck quit engageing
Most likeley is a spring on the top of the deck or the cable that goes from said spring to the lever. if you could provide the model number I can look up the manual and diagram and show you.
Jun 29, 2014 | Craftsman Garden
I posted the below problem last night with the request for additional information reply sent 2 hours ago. I need to use this mower today. I need to have an answer. THanks Problem with the...
Thought I posted a solution earlier on this, but it was my first post and I don't see it here so I'll try again.
Google search on your model shows the drive belt diagram on page 27 of the manual.
link below:
http://www.mytractorforum.com/images/reference/dgs6500.pdf
Looks like mine.
basically need to remove front pulley by loosening center bottom bolt while holding the center nut on top of motor.
Slip belt over the rear pulley first and then straight toward the front, slip belt on front pulley and then slide pulley back onto shaft.
Then wind through the rest of the pulleys etc..as seen in the diagram.
Jun 08, 2011 | Craftsman 24 Hp 48" Deck Yard Tractor
Need belt configuration for 46" deck of craftsman mower
there will be a sticker showing the belt routing, on the back of the deck [rear] in the middle, or on the left, top side of the deck
Aug 30, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman lawn tractor mower, automatic,917.273621, transmission will not pull mower up a slight hill. richard swint drive/motion belt seems normal,
The belt is probably slipping because it is not tight enough. look by the belt, inside there is a little spring, you may half to tighten it.
Jun 13, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Craftsman LT1000 mower
In the Google search box type belt and pulley diagram craftsman lt 1000.....then Search images. The first 4 images feature "springs" however, you can clearly see the motion belt diagram. Hope this information is helpful.
Rox.
May 24, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Missing springs on deck pullies need diagram of deck for springs
Go to www.managemyhome.com and download the owners manual.
After that I would go to www.searspartsdirect.com and look at the pictures of your mower deck (again you need the model #). Once you figure out what you  need then all you have to do is order then from sears.
May 20, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I need belt diagram for 42 in deck
Apr 23, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
108 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
