Question about Frigidare FGB24S5DC Gas Single Oven
Self cleaning lock not disagaging - Frigidare FGB24S5DC Gas Single Oven
  • Frigidare Master
  • 43,501 Answers
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Posted on Sep 30, 2010
Spectra oven. It was going through a self cleaning cycle and was shut off partially through that cycle. Now the door is locked and won't open up. Help!
Door lock has failed to open after cool off start oven into self clean again leave on for a 1/2 min. then cancel self clean motor for self clean should return to normal or lock switch need replaced need a model # on were lock motor is located
Jan 30, 2017 | Ovens
How do i operate the self cleaning function
Hello - Before using the self-cleaning cycle of the appliance, remove the broiler pan and any utensils stored in the appliance. Also remove any excess spillovers in the oven cavity. Allow the oven to cool before cleaning. During the self-cleaning cycle, the outside of the wall oven can become very hot to the touch.
Typically to set the controls for a self-clean the first step is to confirm that the clock shows the correct time of the day. Press CLEAN. "---" appears in the display. Press the UP ARROW or DOWN ARROW once. "3:00" appears in the display for a 3 hour cycle. To change to a 2 hour cycle press DOWN ARROW"2:00" appears in the display. As soon as the controls are set, the motor drive lock will begin to close automatically and the "LOCK" indicator light will flash. DO NOT open the oven door while the light is flashing (it takes about 15 seconds for the over door to lock). "CLn" will appear in the display during the Self-Clean cycle and the "LOCK" light will glow until the Self-Cleaning cycle is complete or cancelled and the oven temperature has cooled.
When the Self-Clean cycle has completed, the time of the day or "End" will appear in the display window and the "Clean" and "LOCK" light will continue to glow. Once the over has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. If "End" is the display and the Clean indicator light remains ON, press CLEAR/OFF. The time of the day will appear in the display.
If it becomes necessary to stop or interrupt a Self-Cleaning cycle, press CLEAR/OFF. Once the oven has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. Restart the Self-Clean cycle once all conditions have been corrected.
Oct 19, 2012 | Frigidaire GLEB27S7A Electric Single Oven
The lock on our self cleaning oven will not lock when we press the start button for self cleaning
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Aug 12, 2011 | Whirlpool Ovens
Self cleaning oven won't start self clean mode
NO IN ORDER TO ENGAGE IN SELF CLEANING THE LOCK MUST FIRST ENGAGE. DOOR LOCK ASSEMBLY FAILURE
Apr 27, 2009 | Whirlpool RBD305PD Electric Double Oven
Oven Door Locked
the oven door does lock during self clean, otherwise it will not work. however, the door is supposed to unlock after the oven has cooled. if it is still locked, turn the oven to self clean and wait about a minute and then hit cancel and see if the door unlocks. if not, there may be a probelm with the door lock mechanism. Joe
Nov 18, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire self clean electric stove 'f9' message comes on when self cleaning
I had the same problem. All I had to do was clean around the door lock. A small bit of burnt food or something had gotten into the hole around the lock and prevented it from moving all the way into position. Took a tooth pick and 30 seconds of probing to clean it out. Works fine now.
Oct 13, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Wont lock in self clean
Whirlpool Gold range: start the self cleaning but after message: cln door comes message, E1-F5- . door does not lock and cleaning can not start.
Oct 10, 2008 | Thermador C302U Electric Double Oven
Oven door remains locked after completion of self clean cycle
My oven door stays locked , when I press the clear button I get F1?
I hold the clear button for a few seconds and still nothing.
Please,
Thank You
Sep 06, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Tappan electric stove designer series
the cleaning light and the lock door light doesn't go on when I set them to self cleaning and lock the door what should I do
Nov 17, 2007 | Tappan 30IN ELEC IGNa Oven
Self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Oct 24, 2006 | Kenmore 40494 / 40495 / 40499 Electric...
Frigidare FGB24S5DC Gas Single Oven Logo
42 people viewed this question
Top Frigidare Ovens Experts
Marvin
Marvin
mburke3
Melissa Martin
Melissa Martin
Are you a Frigidare Oven Expert? Answer questions, earn points and help others
