Question about Sharp AR-157E Copier
L1 ERROR - Sharp AR-157E Copier
  • Sharp Expert
  • 316 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The scanner does not complete feeding in the specified time
Posted on Aug 01, 2010
What does error code L1 mean on my chigo air conditioner unit
When posting hardware questions, it is useful to post brand and model number. There are a number of Chigo air conditioners. I have examined an error code page for the brand and the error L1 is not listed. However, on page 25 of the following manual, L1 is identified as a current transformator of which there can be a No-voltage for over-c
urrent detection circuit. See 4) Electric control panel detection sub-number 3 on that page.
http://www.investliving.se/upload/images/Produkter/Luft-Luft/New%20Basic/Service%20Manual%20New%20Basic.pdf
Dec 18, 2017 | Heating & Cooling
Error stat
Are the data in L1 and l2 in any way related? If they are (being x-values and y-values of some data set) then you need to do regression analysis (2-var stats)
If they are not related (connected) you can calculate the mean of each group separately.
Do 1-var stat by specifying the L1 list first (may be the default), get your average of the values in L1. Then you can do 1-var stat on the data in L2 by specifying the list L2 on the command line.
1-var L2 ENTER
Note: What I am describing here is valid for the TI 83 Plus/TI84 Plus, but I suspect the steps are similar to the TI 82.
Oct 08, 2013 | Texas Instruments TI-82 Calculator
Janome error code L1
do you have a buttonhole lever? if you do then it will have to be pulled down before starting the buttonhole
Mar 25, 2012 | Sewing Machines
We have a Sharp AL 165 1CS Copier and an error is showing. Cannot locate our manual. Error is: [L1-00]
L1; Mirror base feed trouble.
cause:-
Mirror unit defect
Mirror home position sensor defect
Check the scanning operation with
SIM 1-1.
Dec 20, 2010 | Sharp Office Equipment & Supplies
Error code on the display
dear sir,L1 code is for scan unit.if scan cannot move ,this problem occures.
Jun 14, 2010 | Sharp Office Equipment & Supplies
Printer ar168D Error L1-00
The L1-00\r\n error indicates the scanner didn't return to it's home position or is locked and can't leave the home position. There is a lock switch (designed to lock scanner into place for safe transport) located to the left of the copier and just under the scanner. It's a plastic dial that needs to be turned to the "unlock" position. Once done, your problem should be fixed.
Nov 12, 2009 | Sharp AR-168D Copier
Error code L1
YOU EITHER HAVE THE SCANNER LOCKED OR THE SCANNER RAIL [SILVER BAR UNDER GLASS NEEDS TO BE LUBRICATED.
Dec 30, 2008 | Sharp AR-5316 Advanced Digital Imager...
Flashing "L1" error
A letter "L"  and a number "1"  appear alternately = The scan head locking switch is locked. Unlock the scan head locking switch.
Hope this helps. Good luck.
Jul 29, 2008 | Sharp AL-1217 Copier
Coolpix L1 Lens error.
Seem like the AF system doesn't reach the home position, therefore the zoom is not closing. Or may be has been smashed and the zoom block is jammed.
Anyway you need professional help. Problem will be solved after a major srip down.
R. Calla C.
Oct 22, 2007 | Nikon Coolpix L1 Digital Camera
Sharp AR-157E Copier Logo
100 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
