Question about Amana ARB2257CSR Bottom Freezer Refrigerator
Refridge is warm inside - Amana ARB2257CSR Bottom Freezer Refrigerator
  • Amana Master
  • 43,501 Answers
Read these tips... they will help you...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigeratorrefridge is warm inside - 2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on Jul 31, 2010
Frigidaire refrigerator - Model #FRT21BHscW2 manfuactured in 2004 has stopped cooling - freezer unit works - icemaker works - fan is running and compressor is warm - unit is clear of dust and particles. ...
Hello
There is a plastic duct work leading from the freezer to the refridge.Check that there is nothing blocking this ductwork.Also check fan in freezer for operation.
Have a look a refridge door seal also make sure it has no cracks or is not coming off.
Jun 13, 2011 | Frigidaire Refrigerators
Refridge is warm, freezer is working fine. There is a damper controlled by a small motor behind the meat drawer or top drawer. Pulled out drawer, and hole that gets air from freezer was blocked with a...
This is known as the CZT or Climate Zone Technology fan and if you direct wire it and it does not run, replace.
This is the cold zone fan which supplies cold air to the meat and crisper drawers.
Feb 07, 2011 | Maytag MSD2758GEW
Refridge. light went out. Bulb is good. Indicator
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 25, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My stainless steel subzero refridge wont get cool. What could be the problem?
First you have to know if the compressor is running even if plug it in the power supply... if it is not running and the compressor is warm or hot... try to change the compressor relay or overload protector... if it is running normally but not cooling... charge it with gas.. if it is running and some noise inside compressor.. you to replace the compressor... try to check also your thermostat control before anything else...
Mar 15, 2010 | Refrigerators
REFRIDGE TO WARM WATER DRIPPING FROM ICE BUILD UP
You will have to remove/melt the ice inside your freezer by removing the inside panels, should be just a few screws to remove. Once you clear the ice out, there is a drain tube that is plugged. you will have to either let it set for a day unplugged, or you can use a hair dryer to speed the process up. Once that drain tube is cleared, you should be ok.
Nov 02, 2009 | Refrigerators
2000 chevy tahoe air conditioning blowing warm air
probably a leak.
what are your high and low side pressures?
Aug 01, 2009 | 1996 Chevrolet Tahoe
FREEZER WORKS BUT REFRIGERATOR SIDE IS WARM
check if fan that blows air to the refridge is working or vent clogged
Jul 24, 2009 | Magic Chef CTB1821AR Top Freezer...
Kenmore refrigerator model 106 will not cool fridge or freezer
is your refridge leveled if not level it and stable. Try turn it off for a couples of hours and then put it back. does the refridge move a lot when u open it fix this refridge doesn't has to be moving when opening when on and moving this agitates the freon creates more pressure so it has a pressure switch and turns off the compressor to protect it from over or under pressure
Jul 24, 2009 | Kenmore Refrigerators
Open Questions:
Amana ARB2257CSR Bottom Freezer Refrigerator Logo
104 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
