Question about White Sewing 1418 Mechanical Sewing Machine
Teeth do not move material forward when sewing
I'm having an issue w/my daughter-in-laws sewing machine. It will operate but the teeth do not move the material - so it sews over and over in the same spot. Any solutions?
  • White Sewing Master
  • 7,365 Answers
The problem is the feed dog is in the wrong position,, in the operation manual it should tell where the feed dog is on that sewing machine, & what position it's suppose to be in to sew normally
Posted on Aug 01, 2010
Bernina 440
The jagged teeth on sewing plate are not moving to move the material forward. U will have to look under the machine to check out the mechanism that is supposed to move them and find the part that is the cause of no transmission of power to the teeth assembly.
Feb 15, 2016 | Bernina Sewing Machines
How do I stop my needle from breaking and how to I see to it that the machine is self feeding the material forward instead of me having to pull it towards me to get the stitches into the material?
The needle may be bent, but surely the material should feed away from you not towards? Is the bobbin in correctly? If you have inadvertently left the feed dogs down the material will not be gripped and stay in the same place instead of moving. Check.
Mar 27, 2015 | Sewing Machines
Material does not move forward and thread knots at back
make certain that your feeddogs are coming up above the needleplate. a viking dealer should be able to help you. .what model machine do you have.
Apr 09, 2014 | Husqvarna Huskystar 215 Sewing Machine
How can I get the material to move forward when machine operating?
the feed dogs are not working, they hold the fabric against the
presser foot, so the fabric is moved forward,they are in the needle
plate, they should be seen & felt in the center of the needle plate.
Sep 04, 2012 | Sewing Machines
The teeth on sewing machine have droped down and material will not move
you have to turn the knob for the teeth to go back up to sew
Aug 09, 2010 | Sewing Machines
Material will not move forward
Make sure the presser foot is coming all the way down. Check your stitch length setting too.
Mar 01, 2009 | Brother XR-65t Mechanical Sewing Machine
How do i get the teeth to come up to move the material
There is a hidden lever that disables the feet from raising. Remove the extension table (http://sewandserge.com/machimages/MechanicalSewDia2.jpg) and and you'll see a lever recessed into to the left hand edge of the table. Move lever towards operator so it extends and feet will re-enable.
Nov 24, 2008 | White Sewing 2037 Mechanical Sewing...
Very old Necchi sewing machine - sews in place
sounds like the feed dogs may be down or not working. Watch to see if the little teeth are moving under the pressure foot when you stitch( try to run unthreaded and with foot up no fabricto check) May be a button to turn up the feed dogs.
Oct 27, 2008 | Necchi 3101 Mechanical Sewing Machine
Material will not feed across pressure plate of my new home model sx 2122 sewing machine
This machine has a pressure regulator on the left side.You should look to see that it is not loosened. When you lift up on the presser foot it should have resistance.
Then look at the feed dogs to see that they are moving, Set the stitch length at 4 and turn the hand wheel. The teeth should move towards the back of the machine. They should also be slightly above the needle plate as they go back and below the surface of the plate as they come forward.
If they don't rise above the plate , remove the needle plate and clean between the slots of the teeth.
sewman7
Jul 01, 2008 | New Home 2014LE Mechanical Sewing Machine
White Sewing 1418 Mechanical Sewing Machine Logo
364 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
