Question about Kodak Esp 3250 Allinone Multifunction ( C InkJet Printer
How do I replace ink? The print head does not
How do I replace ink? The print head does not more so I can get at it.
    Brigadier General:
  • 10,406 Answers
Turn the printer on.
Lift the lid that covers the print-head.
Wait a few seconds, and the print-head will move to a position where the ink-cartridges can be removed.
Posted on Aug 01, 2010
  • nicolasgr946 Apr 23, 2011
    i HAVE THE SAME PROBLEM - NO MATTER HOW LONG YOU LEAVE THE TOP UP THE PRINTHEAD STAYS OVER ON THE LEFT AND IS IN ACCESSIBLE
  • Tirion2005 Jul 09, 2011
    Absolutely brilliant, just as you said. A1 information.
Cleaning head and nozzles
Cleaning the Print Head
r_bullet.gifUsing the Head Cleaning utility
r_bullet.gifUsing the control panel buttons
If you find that the printout is unexpectedly faint or some dots are missing, you may be able to solve these problems by cleaning the print head, which ensures that the nozzles are delivering ink properly.
You can clean the print head from your computer using the Head Cleaning utility in the printer software or from this product itself by using the control panel buttons.
  • Print head cleaning uses both color and black inks. To avoid wasting ink, clean the print head only if the copy quality drops (for example, blurred printout, incorrect or missing color.)
  • Use the nozzle check first to confirm that the print head needs to be cleaned. This saves ink.
  • When the Error light is on and a message appears on the LCD panel to prompt you to replace the ink cartridge or to indicate the ink is low, you cannot clean the print head. In this case, replace the appropriate ink cartridge first.
Refer to the appropriate section below to use the Head Cleaning utility.
For Windows
Follow the steps below to clean the print head using the Head Cleaning utility.
r_1.gifMake sure that A4 or Letter size paper is loaded in the sheet feeder.
r_2.gifMake sure that this product is on and the ! Error light is off.
r_3.gifAccess the printer software.r_arrow2.gifAccessing the Printer Software for Windows
r_4.gifClick the Maintenance tab, then click the Head Cleaning button.
r_5.gifFollow the on-screen instructions.
Head cleaning... appears on the LCD panel while this product performs the cleaning cycle.
r_space.gifr_caut.gifCaution:r_space.gifr_space.gifNever turn off this product while Head cleaning... appears on the LCD panel. Doing so may damage this product.
r_6.gifWhen Head cleaning... disappears from the LCD panel, click Print Nozzle Check Pattern in the Head Cleaning dialog box to confirm that the print head is clean.
Good: print head does not need to be cleaned yet.
Not Good: print head needs to be cleaned.
If the nozzle check page does not print satisfactorily, you may need to repeat the head cleaning and print the nozzle check pattern again. See Cleaning the Print Head.
  • If the copy quality has not improved after repeating this procedure four or five times, turn this product off and leave it alone overnight. Then, perform the nozzle check again and repeat the head cleaning if necessary.
  • If the copy quality still has not improved, one or both of your ink cartridges may be old or damaged and may need to be replaced. To replace an ink cartridge before it is empty, see Replacing an Ink Cartridge. If the copy quality remains a problem after replacing the ink cartridges, contact your dealer.
  • To maintain good copy quality, we recommend copying a few pages at least once every month.
Apr 14, 2013 | Epson Stylus CX6400 All-In-One InkJet...
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
I have tried replacing all ink cartridges with brand new ones but it keeps saying Error U052 ? I am not really sure why it won't recognize the ink cartridges especially because they are from Canon
The error code indicated, the print head is defective, so it will not get solve by replacing any number of cartridges. Just follow the steps below to reseat the print head, if that does not help, then replace the print head.
  1. Confirm that the printer is powered on and press the <Open> button. (The paper output tray will open.)
    *MP800R shown
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    Note: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  3. Open the inner cover.
  4. Remove the ink tanks by pressing the tab of each tank.
    Caution: Handle the ink tanks with care so that your clothes and surrounding area do not get soiled. Make sure to remove the ink tanks one by one.
  5. Raise the print head lock lever.
  6. Tilt the print head slightly towards the front of the machine and lift out gently.
    Caution: Do not touch the print head nozzles <1> , electrical contacts <2>, or ink supply ports <3>. Doing so may cause printing problems.
  7. Place the print head in the print head holder and lower the print head lock lever carefully until you hear a click.
  8. Insert ink tanks into the print head.
  9. Press the mark <PUSH> on the ink tank firmly until you hear a click.
  10. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    <7> The ink tanks are installed properly.
    <8> The ink tanks are not installed properly.
    Note: Click for Ink Tank Lamp indications.
  11. Close the inner cover and the scanning unit (printer cover).
    Caution: When closing the scanning unit (printer cover), be careful not to jam fingers.
    N
    ote: The next printing begins, the print head cleaning will begin automatically.
You can check the status of each ink tank according to the way its lamp flashes.
- On: The printer is ready to print.
- Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
- Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
- Off: An error has occurred and the printer is not ready to print.
Aug 28, 2012 | Canon PIXMA MP530 All-In-One InkJet...
Problems with my black ink
The lack print head may have blocked ink nozzels.
Inkjet printers need to be used frequently to prevent inkdrying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Jun 15, 2012 | HP PhotoSmart Office Equipment & Supplies
Replaced ink cartridges, printer goes through all the motions, but paper comes out blank. I have done all the maintenance steps. What gives?
Cannon ink cartridges go into a print head. This is normally a removable box the ink cartridge sits in.
First remove the head and the cartridges from it. Now try this to clean the old ink off the print head, rub/soak the print head in alcohol. Make sure the print head is complete dry and place the ink back in it and return to the printer. Try to print a page, if you have the same results you need to replace the print head.
Jul 21, 2011 | Canon PIXMA MP780 All-In-One InkJet...
Print is faded. I just replaced the ink jets.
You said you just replaced the ink jets. Did you clean the print heads? Here is Link on Web. If you find this helpful pls rate me. Thanks
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_210C_420CN_EN_286.PDF
How to improve print quality
Cleaning the print head
To ensure good print quality, the MFC will regularly clean the print
head. You can start the cleaning process manually if needed.
Clean the print head and ink cartridges if you get a horizontal line in
the text or graphics on your printed pages. You can clean Black only
or three colors at a time (Cyan/Yellow/Magenta), or all four colors at
once.
Cleaning the print head consumes ink. Cleaning too often uses ink
unnecessarily.
Caution
Do NOT touch the print head. Touching the print head may cause
permanent damage and may void the print head’s warranty.
1 Press Ink.
2 Press or to select Cleaning.
Press Menu/Set.
3 Press or to select Black, Color or All.
Press Menu/Set.
The MFC will clean the print head. When cleaning is finished,
the MFC will go back to standby mode automatically.
If you clean the print head at least five times and the print has
not improved, call Brother Customer Service (see Brother
numbers on page i).
Jan 11, 2010 | Brother MFC 210C All-In-One InkJet Printer
The colour is faint, a new catridge was installed
When printing becomes faint or colors are incorrect, even if ink remains in the ink tanks, the print head nozzles are probably clogged. Follow the procedures below to clean the nozzles.
Step 1 : Printing the Nozzle Check Pattern.
If white stripes are noticeable
Step 2 : "Aligning the Print Head"
If print quality is poor
Step 2 : "Print Head Cleaning"
if the problem remains
Step 3 : Print Head Deep Cleaning"
if the problem still remains
Step 4 : Replacing Ink Tanks.
Note : * If the ink tank replacement does not resolve the problem, contact the Customer Care Center.
* You will be alerted if low ink warning is enabled.
* When the Maintenace button on the operation panel is pressed, the maintenance mode is shown. Numbers and functions that can be selected on the maintenance mode as follows :
01 : Printing the Nozzle Check Pattern
02 : Print Head Cleaning
03 : Print Head Deep Cleaning
04 : Aligning the Print Head
05 : Reset the ink counter.
06 : "Display" or "Not Display" remaining ink volume.
07 : Date and order setting.
Printing the Nozzle Check Pattern : Print the nozzle check patterb to determine whether the ink ejects properly from the print head nozzles and to verify print head alignment. Use this function when printed results are blurred or the color is incorrect,
1) With the printer on, load a sheet of Letter paper in the printer.
2) Print the Nozzle Check Pattern.
a) Press the Maintenance button,
b) The Maintenance icon and 01 appear on the LCD.
c) Press the OK button. The nozzle check pattern is printed.
3) Examine the nozzle check pattern output by the printer.
a) Lines missing in this pattern indicate that the print head of black ink requires cleaning. Perform the Print Head Cleaning.
b) White stripes in this pattern indicate that the print head of color ink requires cleaning. Perform the Print Head Cleaning.
c) Uneven patterns indicate that the print head requires alignment.
Perform Aligning of Print Head.
d) Noticeable white stripes in this pattern indicate that the print head require alignment.
Print Head Cleaning : Clean the print head if you suspect that the nozles might be clogged. Cleaning the print head consumes ink, so perform print head cleaning only when necessary.
1) Ensure that the printer is on.
2) Start print head cleaning.
a) Press Maintenance button.
b) Press right arrow once to display 02 on the LCD.
Important : Do not perform any other operations until the print head cleaning finishes. This takes about 50 seconds.
Note : After the print head cleaning finishes, print the nozzle check pattern to verify that the print head nozzles are clean.
If the problem persists, perform printhead deep cleaning.
Print Head Deep Cleaning : If print quality does not improve by standard print head cleaning, try print head deep cleaning, which is more powerful process. Print head deep cleaning consumes ink, so perforn this procedure only when necessary.
2) Start Print Head Deep cleaning.
b) Press right arrow twice to display 03 on the LCD.
Important : This process takes one or two minutes to complete so simply wait until the Power lamp stops flashing.
Note : After printhead deep cleaning finishes, print the nozzle check pattern to verify that the printhead nozzles are clean.
If the printhead is still not clean after the second deep cleaning, replace the ink tank.
If ink tank replacement does not resolve the problem, the print head may be worn out. Contact the Customer Care Center.
Hope this helps.
Please rate my response.
Thanks.
Have a good day.
Dec 07, 2009 | Canon i475 InkJet Printer
After being abroad for 3 months i can home to find printer not printing correctly i replaced the 5 ink cartridges but only 2 working Black and cyan
The ink has dried in the print head. If the print head comes out, remove it and apply rubbing alcohol or water with a paper towel to the nozels to disolve the ink. Once the ink seems to be fluid, replace the print head and ink cartridges, do a head cleaning and try printing again.
If the print head cannot be removed, get a childs medicine syringe, draw in some rubbing alcohol. Remove the non printing carts and apply a couple of small drops of alcohol to each ink port on the print head. apply some more drops to the ink port of the carts and replace and try a head cleaning and print.
If this does not work, continue to ask for help. The aim is to save the print head, not buy a new printer.
May 29, 2009 | Brother DCP 115C All-In-One InkJet Printer
Service error 5600 appeared when the printer stop
Dear budg,
Error code 5600 in S200 is No Print head Error indicator. In this case, the print head of the printer is faulty so that the printer cannot detect the print head. About the print out, please check if there is enough ink in ink tank to print. If there is enough ink to print, means this bad print out caused by the faulty print head. It seems that you to replace the print head.
Regards,
Dec 02, 2008 | Canon S200X Ink-Jet InkJet Printer
A big PGBK ink cartridge problem
Call - 1-800-828-4040
Verify they are installed correctly.
Remove the print head or ink tanks properly following the procedure below.
1. Confirm that the printer is powered on and open the top cover. The print head moves to the replacement position.
Note: When the top cover is opened more than ten minutes, the print head moves to the right side. If this occurs, close the top cover, and open it again.
2. Open the paper output tray and pull down the inner cover.
3. Remove the ink tanks by pressing the tab of each tank.
Note: Handle the ink tanks with care so that your clothes and surrounding area do not get soiled. When replacing multiple ink tanks, make sure to replace one by one.
ip4200_ink_remove.gif4. When removing the print head, raise the print head lock lever first.
raisephlocklever.gif To reinstall the Print Head and Ink Tanks
1. Place the print head in the holder and lower the print head lock lever carefully until you hear a click.
putinphnlockit.gif2. Insert ink tanks into the print head.
Press the mark 'PUSH' on the ink tank firmly until you hear a click.
3. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
<1> The ink tanks are installed properly.
<2> The ink tanks are not installed properly.
Note: <Ink Tank Lamp> You can check the status of each ink tank according to the way its lamp flashes.
4. Put back the inner cover and close the top cover.
Note: When starting printing next time, the print head cleaning launches automatically.
During the print head cleaning, the Power lamp flashes green. Do not do other operations until the flashes stops.
James Mac
Sep 10, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Kodak Esp 3250 Allinone  Multifunction (  C InkJet Printer Logo
276 people viewed this question
Top Kodak Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
