Question about Cisco Linksys WET610N WirelessN Bridge Network Bridges
I have it hooked up to my directv HD DVR settop box and Sharp Aquos tv and Directv OnDemand is working so I know I have a connection to my wireless home network. However, I can not get Netflix to find the network (a button on the Sharp remote turns it on) and I already ordered the two week Netflix trial that came with the Sharp tv. I also, can't get a connection to the "AquosNet" internet. I get a message that there is no Ethernet set up. Can anyone help with this?
Need helping hooking up to my existing directv box
About 409,000 results (0.52 seconds) Search Results
    DIRECTV Genie® WiFi Setup & Connection ' DIRECTV ...
    https://support.directv.com/.../directv-genie%26reg%3B-wifi-set...
    DirecTVWatch this video to learn how to connect your Genie® HD DVR model HR44 to the Internet. Follow the simple ... No, my router does NOT have WPS or I want to configuremy router manually. Image .... Order DIRECTV Existing... Still need help?
    Do I need additional equipment to connect more than one TV
    https://support.directv.com/app/answers/detail/a_id/3945
    DirecTVYou need one Genie Mini or Wireless Genie Mini for each additional TV. ... So in a Genie Whole-Home HD DVR setup, one of your TVs is directly ... which allowsDIRECTV Ready TVs to be connected to the Genie HD DVR as additional TVs in your setup without a Genie Mini. ... Order DIRECTV Existing. ... Still need help?
    How to Connect DIRECTV Receiver to TV ' DIRECTV Support
    https://support.directv.com/.../how-to-connect-directv-receiver-t...
    DirecTVHow do I connect my DIRECTV receiver or Genie Mini to my TV? ... This will help you determine what cable to use. .... To download and print them, you'll need.
    My equipment was shipped to me. How do I install it ...
    https://support.directv.com/app/answers/detail/a_id/4267
    DirecTV
Feb 08, 2016 | Televison & Video
Does the Sanyo multimedia prod-III connect to direct tv
What are the DIRECTV TV Apps and how do I access them ...
https://support.directv.com/.../what-are-the-directv-tv-apps-and-...
DirecTVDIRECTV's FREE HD TV Apps are interactive features that let you do all of the below without missing ... How do I connect my Genie® or HD DVR to the Internet?Missing: sanyo ‎multimedia
Media Share - DirecTV
www.directv.com/DTVAPP/content/directv/.../mediashare
DirecTVYou can quickly browse thumbnail images or create a slideshow. ... Set up Media Share by connecting your DIRECTV Plus® HD DVR to your computer.Missing: sanyo
[PDF]Programming a DIRECTV Remote to Work With Your TV
manuals.solidsignal.com/directvrc64forweb.pdf
Jan 20, 2016 | Sanyo Office Equipment & Supplies
How do I setup my dvd to mt tv, i use direct tv
How to Program DIRECTV Remote Control ' DIRECTV ...
https://support.directv.com/.../how-to-program-directv-remote...
DIRECTVTo do this, press and hold the MUTE and ENTER buttons while pointing at your Genie HD DVR, Genie Mini, or Wireless Genie Mini. The screen will display Applying IR/RFsetup. To program your remote to control a regular HDTV (not a DIRECTV Ready TV) or audio devices, follow these steps: Press MENU on your remote.
https://support.directv.com/.../how-to-connect-directv-receiver...
DIRECTVHow do I connect my DIRECTV receiver to my TV? Print. Email ... This will help you determine what cable to use to connect your receiver directly to your TV. ... For example, a DIRECTV receiver, DVD player, Blu-ray™ Disc player, o... How to ...
Remote Control Code Lookup - DirecTV
Dec 10, 2015 | Supersonic Televison & Video
Why can't i see 1080p programs on my directv hd dvr? The test on the hdr says my receiver doesn't receive 1080p. My tv is a Sharp LC-62C42U which is suppose to receive 1080p!
Your DVR can't detect whether your TV can do HD or not. If the message is stating that your receiver (which is your DVR) can't receive 1080P, then you'll need to contact DirecTV for assistance. You may need to replace your DVR.
Mar 01, 2011 | Sharp LC-62C42U 42 in. LCD TV
Have magnavox dvd recorder record direcTV DVR programs w/ hdtv
I am unfamiliar with this unit.
If you have scart connecters on both, connect av2 on the tv to av in on the recorder. set the recorder to record from av source.
You should now record a program, I think the static is the fact that composite is out from the dvd only, not an input, and in on the tv, not an output.
Sep 04, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Linksys switch question
You certainly can. In a real network you have one router and x amount of switches or hubs. Because whats going to happen is your equipment will automatically will ask the switch which will bounce to the router and your router will issue the address to that device.
Jul 20, 2009 | Linksys EtherFast EZXS55W 5x10/100 Mbps...
I have a Samsung HLP5063wx xaa and I am getting a HDMI not supported when I hook up my HD-DVR, any help on how to resolve this, PLEASE!!!
I fixed it, if anyone is having this problem, you will have to tell your Directv box to only accept 720p resolution, I only have one line hooked up to my Hd-DVR right now and I had to tell the Directv box that it was on a Single tuner not Dual, I re-booted the directv box and everything works. I hope this helps anyone w/ an older model DLP, It took me hours on the internet to find the answers I needed.
Jun 17, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
I just had directv hooked up, I have a dvr receiver, I was told I did not have enough hook ups on the back of my tv, so therefore, I went and bought a switch or combiner. Now, how do I need to run the...
Newer directv hd receivers must connect to the av input (yellow,red, white) connections on the back/front/side of your tv. If your tv only has one of these av inputs then you will need an RF modulator for your dvd player. You will connect the (yellow,red, white) connections from the dvd player to the rf modulator and then connect the tv out on the rf modulator to the tv rf jack ( the silver threaded barrel on the back of the tv) Tune your tv to channel 3 to watch a dvd and then back to the av input channel for the directv receiver.
Apr 14, 2009 | Directv D11 DTV Receiver
Sharp 37" LCD/TV will not remain programmed with DirectV. DirectV technicians have come out to re-program the Sharp TV. They simply say over and over again that it is a Sharp problem. They keep telling me...
First of all any make or model tv will work with any directv receiver as long as it is connected properly. In my expierence Sharp TVs are compatible with all directv recievers. Is the directv remote not functionly properly with your sharp tv or do you have a black or snowy display. Your tv has to be on correct input in which the technician should of educated you on this instead of suggesting the purchase of a sony branded tv. Black or snowy display indicates the wrong input. Using the tv remote find a button labeled source or av or input and try pressing that button until you see a picture. otherwise call directv tech support at 800-347-3288 and demand that this issue is resolved immediately.
Mar 09, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Off Air?
The Scientific Atlanta box was a cable box and recieved CATV signals. The Direct TV box is satellite only. You might check if it has a built in ATSC tuner for off air digital signals. Direct TV in most locations offers the major networks in HD format.
Jan 04, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Cisco Linksys WET610N WirelessN Bridge Network Bridges Logo
75 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
