Question about Remington Polesaw Wizard
I have a Remington pole saw Model 108526-01 Type LNT-2 10" BAR-097567-01/CHAIN -091371S It works very well but the chain does not cut anymore. Where can I get the replacement. I do not have the # of the item.. Thanks for any help you can offer.
    President:
  • 2,220 Answers
3 choices for a chain can be found on the link. Your current chain is likely the green one. Any local chain outlet given your chain as a sample can fabricate a new chain in 5 - 10 Minutes.
Oregon Bar & Chain Selector
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
Remington, LNT-2, 10", All, All, All
Oregon does not offer a replacement bar. I think yours is solid nose bar and may be difficult to find outside of RemingtonPower.
RemingtonPower is no longer in production. The name was purchased by MTD, they are providing some parts here.
PartsFor.com
http://www.partsfor.com/
They have taken down to link to the Illustrated Parts Breakdowns for RemingtonPower and the part numbers you provided do not cross to anything at the new parts provider. Sorry I could be of more help. There is a phone number at the new parts supplier. They may be able to supply a current part number.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Jul 31, 2010
Chain saw electric #097567-0 I want a chain for a model 106890-02
Hi delgadojoser,
Copy and paste this entire web address into your browser and the page with a choice of chains for your pole saw will open up: http://www.discountonlineparts.com/chainsaws/search.php?saw_mf=31&saw_mdl=106890-02&saw_l=10&saw_p=&saw_g=
The 1st one is the low profile chain which is the standard chain.
Hope this helps. If it does, I'd appreciate your vote.
Thanks,
Handie Andie
Jul 25, 2011 | Remington Polesaw Wizard
Doesthis thing need oil or some other liquid type
The bar and chain require bar oil (only) to be placed in the capped tank. The motor itself is air cooled, and should be blown out with compressed air often to remove the accumulated sawdust. Make sure the chain is tightened just enough to prevent the lower part of the chain from drooping from the bar and can be turned by hand. Make sure to keep the chain teeth sharp by properly filing for best cutting. Test the chain oil pump operation by running the saw with the chain tip near a piece of cardboard--it should throw off a thin line of oil after a moment or two of running. Hope this helps!
Apr 05, 2010 | Remington Electric Chain Saw
How do I get a replacement chain for my Remington 8'' Pole Saw (Part No 104301-S)
That is not a valid part number (also 8SC NLA Remington & Master). If the pole saw is an RPS96 (LNT-2) with the original or equivilent 8" bar, YOU can make an informed decision based on the following:
"Remington; LNT-2; 8"; All; All; All". You are presented with 3 choices on the following table.
The above results are for an original or equivalent (34 drive link chain to fit) 8" bar. Only YOU can determine your level of expertise, how much risk you are willing to assume and choose one of part numbers listed. Once you make your choice it can be found on the Internet or through local merchants. If your local outlet does not handle Oregon your choice can easily be converted to other chain manufacturers part numbers. I suggest a few phone calls to save you time and gasoline. Given the Oregon part number and your assurance of a purchase, if my store, your chain would be waiting when you walked in the door.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 22, 2010 | Remington Electric Pole Saw
Where can I find a bar & chain for a remington
You provide no model number for your saw. What is pictured is a RPS96.
Remington.com
http://www.desaparts.com/index.htm
  • Type "YourModelNo" (RPS96) into the "Model #:" window, then click search.
  • Click the YourModelNo - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Breakdown" link.
There are 8, 10, 12 and 14" chains on the IPB depending on the actual model pole saw. RemingtonPower is no longer in production, and parts are often difficuilt to find. All 4 chains listed are available and range form $12.92 to 15.95 plus shipping and handling. You can take your saw (or just the chain) to a local saw outlet and have one fabricated in about 5 minutes. It is rarely more expensive at a local outlete and you save shipping and handling fees. HTH
Lou
Jan 25, 2010 | Remington Polesaw Wizard
REMINGTON POLE CHAIN SAW
The chain has to be tensioned when replaced. You lift the chain away from the bar about halfway and the tangs that run in the bar should just almost come out of the groove. There is a screw that extends the bar near where it attaches near the sprocket. adjust that with the bar mounting nuts not quite tight till the chain is tensioned correctely.
Sep 28, 2009 | Remington Electric Pole Saw
Need a bar for a 10ich Remington pole saw
www.masterparts.net/remingtonelectricchainsaw. USE THIS SITE AND FIND YOUR CHAIN SAW MODLE YOUR BAR IS IN THERE. I BOUGHT A REMINGTON ELECTRIC SAW 2 YEARS AGE AND THE THING CUTS BETTER THEN MY GAS SAWS, LOVE THAT THING
Aug 10, 2009 | Remington Electric Chain Saw
What type of oil do I use for a Remington Electric Pole Saw?
While Bar Chain oil will probably work, the owners manual (sitting in front of me) on page 9 says to "use SAE #30 motor oil". This is the owners manual for Models: M12510US, M15012US, M15014US, M15014AS, M30016US, M30016AS, M30016AW, M35016UW, M35016AW. Remington Electric Chain Saw
Mar 13, 2009 | Remington 16" Electric Chain Saw
Remington Pole Saw
Here is a link to the model # 104316-04... http://12.153.20.74/manuals/107990-01G.pdf, You should be able to locate the part number you need. You then can call 800-446-1446 to order your part.
Jun 22, 2008 | Remington Polesaw Wizard
Remington Polesaw Wizard Logo
330 people viewed this question
Top Remington Garden Experts
roeb
Phil Walker
Phil Walker
Joseph Mueller
Joseph Mueller
Are you a Remington Garden Expert? Answer questions, earn points and help others
