Question about Nikon Telephoto 500mm f/4.0 P ED IF AIS Manual Focus Lens
The lens only meters at F22 at other aperture setting it displays
Bought this lens 2 years ago, it worked fantastic, what am i overlooking??
Thanks, Rob
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
That's the way it's supposed to be with all modern Nikon bodies. Keep the aperture ring at f/22. Adjust the aperture by turning one of the command dials on the body.
If that doesn't work it, please append a comment to this post specifying the body or bodies you're using with this lens.
Posted on Aug 01, 2010
Testimonial: "Hello, Thank you for your response, i had it figured out after i posted the problem Rob"
DSLR says lens not attached
Hey there,
It sounds like your problem is related to the aperture setting on your lens. The aperture ring should be set to the smallest aperture usually f22 when attaching these older lens. Most lens aperture rings will provide a locking mechanism for that ring on the lens.
The aperture would be then set through the camera, not on the lens. Also some nikons have a lens preset on their menu, where you can inform the camera which lens is attached. Most of the older lens lack any terminal points for communicating with the camera automatically, therefore you will have to fill in the data manually to get better functionality out of the lens camera combo.
Sep 25, 2013 | Nikon D3200 24.2 MP CMOS Digital SLR with...
I am new user for DSLR, using old 50 mm 1.8 manual focus on D80, unable to see any inmage on playback (shows information). Will this lens work with D80, using settings as manual mode, f22 . Please guide...
Turn the aperture ring to its smallest setting (largest f/number). You control the aperture from the camera body, as on a lens without an aperture ring. Turn the mode dial to M (manual). The camera's exposure meter will not work with this lens. You can use another lens to get an approximate exposure, or take pictures and review them and/or use the histogram to fine-tune the exposure. The camera won't autofocus, of course, but the in-focus indicator in the viewfinder will still light up to indicate proper focus.
Jun 17, 2011 | Nikon D80 Digital Camera with 18-135mm...
What does FEE mean? The camera won't take a picture and I see that in the display of my Nikon N90S
FEE error message displayed on SLR camera LCD Description If the cameras LCD screen displays "FEE" in the area where the aperture is normally displayed, please ensure that the lens is attached to the camera correctly. This error message will appear if the lens is not attached correctly to the camera or if you are not using a CPU lens such as the Nikon AF or Nikkor P lenses. Alternatively, if the lens has an aperture ring, it may not be set to f22 (or the highest aperture number on the aperture ring - normally marked in orange). Select the aperture number marked in orange on the lens and lock it using the aperture locking switch to prevent this occurring again.
The FEE error message
Set to F22, or the highest aperture number - normally marked in orange. Note the locking switch.
If the above did not resolve the problem and you still experence the the error display FEE, please contact your local Nikon office. Before doing so please also check the following.
1157d.gif That the EE servo coupling highlighted above on the lenses has not been broken. That the F-min switch highlighted above on the camera body has not been broken. If either of the two items above are broken please contact your local Nikon service center.
Apr 19, 2011 | Nikon N90S 35mm SLR Camera
I have a Nikon D60 and have just bought a 50mm AF 1.8 D lens but find I can only use the aperture setting at 22. Is that right ?? why can't I use the other aperture settings ??
The D60 camera sets and triggers the aperture that you have selected (or the camera has selected if in auto mode) and sets the aperture as you take the picture. Moving the aperture ring on the lens will not work, in fact once you move it from the f22 position the camera will stop or possible show and error. on my older Nikon AF lenses there is a small lock to lock the aperture ring in the lowest position when mounted on a digital camera, it is found near the f2.8 side of the aperture ring. when you want to set the apertures manually, you put the camera in aperture or manual mode and set the aperture you want by moving the the rotating wheel on the grip part of the camera. the aperture you select will show in the window, you do not have to move the ring on the lens,it must remain the f22(highest numerical) position.
Oct 24, 2010 | Nikon Normal AF Nikkor 50mm f/1.8D...
I am new so do I keep the f22 lock on when auto focusing?
No. You only need to do that when using any exposure modes where the camera needs to take full control of the aperture setting for you (basically everything except full manual metering and aperture priority metering). The idea is that by setting the lens to the minimum f-number (aperture) the camera can then automatically set the actual aperture required by the exposure meter and exposure program to anything between maximum aperture (lowest f-number) and the f22 set on the lens.
Aperture settings are independent of autofocus on all SLR cameras. If you're new to SLR photography then I highly recommend the latest (2009) edition of John Hedgecoe's New Manual of Photography. The link is just to show you the book and not an endorsement of the featured supplier; I'm sure that you'll want to make your own buying choices.
I hope this has helped, if so please return the favour by taking a moment to rate my answer. If not then please explain your problem in more detail and I'll be happy to offer further assistance.
Oct 30, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
I think I messed something up on my lens.
You are correct that the switch locks the aperture. In order for your camera to function correctly in the auto-focus mode you must lock the aperture to the smallest opening (largest number such as f22). The switch has two positions. The position where the switch is lined up with the orange line is the locked position. When the lens functions properly and on the camera, the lens aperture is forced wide open by a pin on the camera body pushing a lever on the lens that opens the aperture. As part of the sequence when you push the shutter button, the camera releases its pressure on the spring-loaded lever on the lens, allowing the aperture to close to the setting that the "computer" has determined as correct. You will find this lever on the outside of the black ring that surrounds the rear lens element. With the lens removed, find the lever and make sure that with the lens set to the f22, sliding the lever counter-clockwise against the slight spring tension, the aperture opens wide and returns to f22 when released. If this is not the case, the problem is in the lens. If this works, then the problem is either in your camera body or in the alignment between the body and lens. If this does not get you on the right track, let me know what you find and we will proceed from there.
Nov 23, 2008 | Nikon Cameras
NIKON 50mm 1.8 ---"Err" on top panel display if aperture setting is not at f1.8
this same thing is happening to me on my D70s.
i posted about it at photo.net and everyone is stumped.
http://photo.net/nikon-camera-forum/00Q6eB
i already returned the lens and got a new one...
same problem. i don't know what's wrong.
does anyone here have any insight?
Aug 10, 2008 | Nikon Normal AF Nikkor 50mm f/1.8D...
Nikon N60 35mm camera error code FEE
Check your lens aperture ring setting. It must be set on the highest number I.E. f16,f22,f32..
Jan 16, 2008 | Nikon N60 35mm SLR Camera
Error message
You might want to check the position of the aperture ring on the lens. If it is not set at the highest number, ( IE smallest aperture, f22,f32 ), then the camera will display that error message
Dec 03, 2007 | Nikon Telephoto AF Micro Nikkor 60mm...
What does the fEE error message displayed on an SLR camera mean?
The "fEE" error indicates that the camera is not communicating with the lens. The lens may not be attached to the camera properly, or if it has an aperture ring, it may not be set to f22 (or the highest aperture number of the lens) - which is normally marked in orange. Select this aperture and lock it using the aperture locking switch to prevent this from occuring again. The fEE error message Set to f22, or the highest aperture number - normally marked in orange. Note the locking switch.
Aug 30, 2005 | Nikon D70 Digital Camera with 18-50mm Lens
Nikon Telephoto 500mm f/4.0 P ED IF AIS Manual Focus Lens Logo
57 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
