Question about Fisher Paykel EcoSmart GWL15
My five yr old Fisher Paykel EcoSmart washer is dripping water into the tub when it is off. Is this hard to fix on this machine?
  • Fisher Master
  • 713 Answers
Hi just read your posting.The problem with your machine is a faulty water valve.Now there is 2 ways you can rectify this .The first and cheapest is to turn off the taps to the machine after use or the 2nd is to replace the faulty valve or valves.Hope this helps and please reply on how you got on and if you would like to change the faulty valve or valves.Looking forward to your reply.
Posted on Aug 01, 2010
Washing machine drips water from top of tub.
THE WATER INLET FILTER IS MISSING , SO IT ALLOWS SOME FRAGMENTOF DIRTS INTO THE SYSTEM......U HAVE 2 LOSSE WATER INLET VALVE AND CLEAN
Feb 24, 2012 | Fisher and Paykel Washing Machines
Fisher Paykel Intuitive Eco Washer is squealing
You need to pull out the washer, TURN OFF THE WATER, then take the water hoses off the back of the washer. Check the screens inside the water inlets for debris. If that doesn't fix the problem you may need to ask fisher paykel if it's safe to put a chemical like limeaway in those holes to remove hard water deposits that have built up inside the valves.
Sep 20, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher Paykel Ecosmart washing machine spills water.
sometimes too much detergent, or extra cleaners like oxy clean) will cause lots of foam which will cause the water level sensor to misread, or foam over the top of the drum. if this is not the problem, you will have to tilt the machine on its side and look for loose or damaged hoses. the play in the tub will not cause leaking
Jul 10, 2009 | Washing Machines
I have a 1.5 yr old Fisher Paykel ecosmart washing machine. During the past 2 loads there has been a notable water leak (significant puddling on the floor). I haven't witnessed the problem, but there is...
the play in the tub in normal, it sounds like you have an over sudsing issue, run an empty load with 3 cups of vinager in the tub, set the water temp to hot, cut way down on soap, if you use liquid dont even fill the cup 1/3 of the way, I know this sounds dumb but try it, I have one and this happened to me
Jul 10, 2009 | Fisher and Paykel Washing Machines
Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Apr 20, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel washer dripping water into tub.
Dear FixYa Customer,
First and Always go to the Manufacturer for Parts Compatibility and/or Service!
For a GREAT APPLIANCE PARTS WEB SITE click on the highlighted http:// link that follows...
Same-Day Shipping, Return Any Part
Save When You Do Repairs Yourself! @
http://www.partselect.com/Entry.aspx?
jackiaria
Mar 21, 2009 | Fisher Paykel EcoSmart GWL15
Fisher paykel ecosmart washer wont go drain or go to rinse cycle
this is joyce
take hose and siphion the water out of the unit.run into pan on floor or outside if you have long enough hose. it will come out just get started by putting one end in water in tub and the other end outside or in tub or whatever and start suction on hose untill water comes out and let run untill all water is out of tub.
thanks,
joyce
Feb 07, 2009 | Fisher Paykel EcoSmart GWL15
Washer leaking from top
Sounds like it's plugged and the water is thrown by the centrifugal force. Sometimes stuff can get between the drum and tub, plugging the drain. This can be sporadic, sometimes no problem cuz the item is away from the drain hole during extract.
Sometimes minor partial disassembly will allow you to see between the drum and tub. A pick up tool can snag things down deep.
Jan 24, 2009 | Fisher Paykel EcoSmart GWL15
Fixed basket came loose...
if less than 2 yrs warranty and washer has 2 yr warranty (ck owners manual) call service ..if not remove plugs on front sides of top remove phillip screws lift top outer tub is supported by 4 swing arms one or more is probably loose or broke but can be replaced also have known then to just pop out of position with really bad off balance load
Aug 20, 2008 | Fisher Paykel EcoSmart GWL15
Musty odor in laundry
I would say that you are getting a build up of soap and oil from our bodies, on the inside of your wash bowl.
The Tubs pull out of the washing machine really easy and then you can water blast the two tubs.Solves this problem?
Once you learn how to pull the tub out you can also clear a blocked pump.
I have a after market lint filter fitted to my F&P washing machine,works wonders .
ask your local whiteware Man for some hints on a Bowl removal.
A five minute job???
Jul 27, 2008 | Fisher Paykel EcoSmart GWL15
Fisher Paykel EcoSmart GWL15 Logo
204 people viewed this question
Top Fisher Washing Machines Experts
Mike
Gerry Harvey
Gerry Harvey
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
