Question about LG WM-2277HW Front Load Washer
Washer Leaks from Detergent Compartment
My 3-year-old washer leaked from the detergent compartment and caused significant water damage to my floor and walls.  The repairman couldn't find anything that would cause this problem, so now I have to "babysit" my washer in the event that it might happen again.  What exactly was the issue that you mentioned that would cause the water backup to leak (actually pour) from the detergent compartment?
  • 489 Answers
Two things might be wrong with this unit.  One problem is there is a blockage inside the hose that sends water into drum.  Make sure that's clear.  The other problem is the dispenser assembly may have a leaking problem and will spray water at an angle that will cause it to leak through the dispenser drawer.  My recommendation is to have the dispenser assembly inspected and possibly replaced.
Posted on Apr 27, 2008
I am experiencing similar problem, I checked pump filter and was clogged, removed and tried again and same problem found water leaking from soap dispenser. I am not sure where to locate the codes given in the manual and how or where to read it on the washing machine model WM2277HB. Please advise if you have any information.
  • 8 Answers
The description of this problem is exactly what I experienced. At first I thought water was leaking from around the front loader door (i.e. a bad water seal). After babysitting a couple of dry (actually wet) runs, I noticed that the water was coming out of the dispenser drawer and seeping down the front of the washing machine onto the floor. The problem turned out to be a container cap (from a Kirkland Laundry Detergent or a Kirkland Fabric Softener) that had fallen into the Pre-Wash Compartment of the LG Front Loader Dispenser Drawer. It lodged itself inside the filler hose that carries water from the dispenser drawer to the washer drum. The Kirkland container cap is exactly the same size as the inside of the filler hose and managed to lodged itself to where it was blocking 100% of the flow (not good). The Pre-Wash compartment has a wide unobstructed opening that directly leads to the filler hose whereas the detergent, fabric softener, and bleach compartments have a small ¼" vertical tube that only allows it's content to enter the filler hose once controlled water floods these compartments. Not knowing ahead of time what the problem was, I ended up taking the washing machine panels off and removed the filler hose before I discovered the problem. I have since crimped a mesh screen over the fabric softener compartment into the Pre-Wash compartment to prevent a reoccurrence. However, if the problem were to reoccur I would first remove the dispenser drawer and try to blindly fish for the lodged container cap by sticking a pair of mechanical fingers into the filler hose. Only if the fishing attempt failed would I remove the washing machine panels and filler hose, hence this write-up. Hope it helps someone.
Posted on Apr 23, 2015
I had this problem happen to me and I called somebody for extended warranty. The guy told me that I was using the wrong detergent?!?! I use Purex HE and I have been using it for a Long time. I'll try to switch brands and post again if it works.
Posted on Jul 17, 2008
Fabric Softener Does Not Drain
compartment 1: Detergent for pre-wash
(powder)
Before pouring in the detergent, make sure that extra compartment 4 has been removed.
compartment 2: Detergent for the wash cycle
(powder or liquid)
Liquid detergent should only be poured in immediately prior to the wash cycle start.
compartment 3: Additives (fabric softeners, etc.)
The fabric softener should not overflow from the grid.
extra compartment 4: Bleach
! Do not use Hand Wash Detergent because it may form too much foam.
Cleaning the detergent dispenser
Remove the dispenser by raising it and pulling it out (see figure).
Wash it under running water; this operation should be repeated
frequently.
25569074-ineink0kisfnom0atbkujjcx-3-1.jpg 25569074-ineink0kisfnom0atbkujjcx-3-3.jpg 25569074-ineink0kisfnom0atbkujjcx-3-6.jpg
Dado
Mar 14, 2015 | Ariston Technologies AW125NA 13 lbs. Load...
Whirlpool commercial duty washer - liquid detergent
Jenny what do you mean by 'flow right out of the compartment'. IF the detergent flows right into the machine as you pour, it ok.
Jan 05, 2014 | Washing Machines
The fabric softner compartment of my whirlpool duet washer is completely full of water
Mine is doing the same. For over 2 months now I've been adding fabric softner to the detergent compartment but I broke down and called a repairman to come tomorrow... at a ridiculous repair rate. My washer is less than 3 years old and this will be the 3rd major problem that needed to be fixed. I've seen a lot of people post the same problem - some say all 3 compartments won't drain.
Feb 24, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite HE4 won't start
Top 10 front-load washer problems
1)Water fill problem: water took more than 10 minutes to fill to desired level sometimes indicated as a LF/IE or long fill/inlet error. Water valve screens clogged, hoses kinked, low water pressure, unpaid water bill. Check hose, clean screens.
2)Excessive vibration: noisy,roar, knocking noises. Bad damper,bearing or broken trunnion. no error code
3)Dispenser drawer open/detergent in wrong compartment: washer will not operate with drawer open or cleaning products in wrong compartment.
4)Washer won't drain: clogged pump/filter, slow or clogged drain usually indicated as a LD/DE, if a code is given (long drain/drain error) Clear pump of objects
5)Drum overfilled: usually caused by sediment in the water level pressure sensing tube going up to the main control.Find it and blow out the sediment, re-secure pump out water and retry.
6)Door open, Door not latched, clothes/objects keeping door from completely closing. Tighten door latch, add washers if nesessary to make good contact and close door tighter in case of leaks.Note some models send a signal to the motor and another to the control letting both know the door is secure before proceeding, corrosion gets into the lid lock and the door can be locked and the control is ready but the motor ain't getting the message.
7)Cold water does not enter washer: hoses connected backwards. Oops.
8)Over-sudsing: Wrong Detergent, too much detergent, detergent in wrong dispensing drawer, turbidity monitors pick up particles in the water and judge soil content then the washer allows for extra time to wash the clothes, if the wrong detergent is in there the machine thinks that is too much and declares a suds error. On some models a suds detect is determined by the motor over amping, most machines will try a few mini loads to correct the problem. Remove detergent, retry
9)Locked motor: error LE,loose connection,broken wire/hallsensor, motor overheated/failed.
10)Water heating error, hE, the thermister/heater is out.
Feb 06, 2010 | Kenmore Elite HE4 Electric Dryer
The washing machine keeps blinking sud what does this mean? It won't finish the cycle.. it is a kenmore front loader HE 5t
Either you have too much of the correct detergent in there or the wrong detergent in there. Here are a few of the errors:
2)Excessive vibration: noisey,roar, knocking noises. Bad damper,bearing or broken trunion. no error code
6)Door open, Door not latched, clothes/objects keeping door from completly closing. Tighten door latch, add washers if nessesary to make good contact and close door tighter in case of leaks.
8)Oversudsing: Wrong Detergent, turbidity monitors pick up particles in the water and judge soil content then the washer allows for extra time to wash the clothes, if the wrong detergent is in there the machine thinks that is too much and declares a suds error. Remove detergent, retry
Feb 01, 2010 | Washing Machines
Kenmore front-load. washer leaks out of the detergent compartment
try cleaning out detergent compartment if you can take compartment out the inside area may need to be cleaned out make sure the machine is not to full
and if there is mold you can try using pool shock about a spoon full on wash cycle by it self this well not hurt seals and is safer then bleach and also to control the mold use a pool algecide use litely two tbs to a spray bottle and keep door open after use
but it sounds like compartment door is not fitted properly i hope this helps
Nov 24, 2009 | Washing Machines
Heavy towels don't come clean & smell of mildew - all whites and colours are gray after bleach has been used.
Did you add detergent to the dispenser?
For best results, add detergent to the detergent
compartment. Do not add detergent to the washer drum.
 Did you sort properly?
Sort lint givers (towels, chenille) from lint takers (corduroy,
synthetics). Dye transfer can occur when mixing whites and
colors in a load. Sort dark clothes from whites and lights.
 Did you overload the washer?
Do not overload the washer. The washer can be fully loaded,
but not tightly packed. The wash load must be balanced. Lint
can be trapped in the load if overloaded.
 Check the following:
Was paper or tissue left in pockets?
 Did you use enough HE detergent?
Follow manufacturer’s recommendations for the type of load
you are washing. For best performance, use only High
Efficiency detergent. Use enough HE detergent to remove soil
and hold it in suspension.
 Do you have hard water?
Use more detergent for washing heavy soils in cold or hard
water.
 Is your water colder than 60°F (15.6°C)?
Wash water colder than 60°F (15.6°C) may not completely
dissolve the detergent. Use hot or warm washes if safe for the
fabric load. Make sure your hot water system is adequate to
provide a hot water wash.
 Have you run the Clean Washer Cycle lately?
To freshen your washer and to avoid odors, see “Cleaning
Your Washer.”
 Are you using HE detergent?
Use of non-HE detergent can cause a film residue which can
result in odor.
 Did you leave the door open after use?
This washer has a tight seal to avoid water leaks. To avoid
odors leave the door open to allow the washer to dry
between uses.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10117768.pdf
(see page 20 for washer cleaning instructions)
Oct 10, 2009 | Whirlpool Duet Sport HT WFW8400TE Washer
Washer is leaking
Check the rubber bellow (gasket) around the door. This is the symptom of a door gasket that it starting to leak. Pull the rubber folds back and check the area where the gasket attaches to the wash tub. You may have a crack or tear. If the gasket is worn please replay back to this post and I can give you advice on how to replace it and where to get a replacement gasket.
May 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
RE: Water Leaks from Detergent Compartment
I don't know what else to tell you.  I hope that whatever the problem was, it is permanently gone.  Good luck.
Apr 27, 2008 | LG WM-2277HW Front Load Washer
Washer leaks small amount. DIY fix: check hoses and ???
Wires found in hose!
When we turned washer on it's side, we found the hose from the pump to the basket had been pierced by two stiff curved wires, still embedded in the hose. Water was leaking around the wires. Wires had come out of an underwire bra! Dealer had only heard of this once before; on his own washer!
MORAL: handwash your bras, ladies.... or pull those wires out each time.
Apr 12, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
LG WM-2277HW Front Load Washer Logo
953 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
