Question about Universal Remote Control URC-6131N Remote Control
I need 4 digit code for a URC-6131n oneforall remote. I have a magnavox dvd player
  • Anonymous Mar 15, 2014
    need code for remote 6131n
    President:
  • 1,932 Answers
Hi
Codes for your URC 6131 remote for magnavox DVD are
0503 ,0675
Thanx
Posted on Aug 01, 2010
NEED set up CODES FOR MAGNAVOX TV
Many One-for-All remote manuals and code lists are available here: http://www.oneforall.com/support/manual . Fill in Universal Remote Control and then the model number in the drop-down menus. Then click on the link to the manual. (It's a pdf so you'll need Adobe Reader or a similar program.) The direct link to the URC-6131N manual (English version) is http://www.oneforall.com/uploads/support/9e15c67cf9731f8b8e9b376352f23493.pdf .
Try the following codes: 0054, 0030, 0179, 0024, 0186, 0187, 0386, 1254, 1454 for Magnavox TVs. Please note that universal remotes usually only have codes for devices released at least 6 months before the remote was programmed. If your TV is newer than your remote, you may need a newer universal remote. The URC-6131 gives it a date of Feb 2003.
I hope this helps.
Sep 22, 2011 | Universal Remote Control URC-6131N Remote...
I am looking for the codes for a phillips tv model number 20pt6441/37 and a regent dvd player all the a oneforall universal remote urc6131n
Hello
Setup codes for Philips TV with URC-6131 remote are:
0054, 1454
Regent DVD player is not listed with the codes to this remote control. OK.
May 30, 2011 | Universal Remote Control URC-6131N Remote...
How can I change my Sony RDR-VX530 to a multi region DVD planer?
Follow the below instructions closely;
1. In order for this hack to work, you will have to send an infra-red code to your player with a OneForAll remote such as the OneForAll 6 (or URC7560) or OneForAll 4 (or URC7740) or OneForAll 4 Digital, or One For All 5 Digital (or URC 7555) with the following instructions:
* Press the DVD button
* Hold down the Magic button until the unit performs a double LED flash
* Configure your remote using the setup code 0 5 3 3
2. On your DVD recorder, using the official Sony remote, select the System-Menu option
3. On your DVD recorder, using the official Sony remote, select the Setup option
4. On your DVD recorder, using the official Sony remote, select the Options option
5. On your DVD recorder, using the official Sony remote, select the Command-Mode option
6. On your DVD recorder, using the official Sony remote, select the DVD1 option
7. On the official Sony remote, set the DVD1 option for the Command-Mode switch, under the sliding cover
8. Verify that both the official Sony remote control and your OneForAll remote control can power off and on your DVD player
9. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 9 9 4 or 0 0 9 9 4 if your remote only accepts 5 digit codes
* Press the Magic button once
* Configure your remote using the setup code 1 8 9 or 0 0 1 8 9 if your remote only accepts 5 digit codes
* Press the 1 button once, a double LED flash should occur
10. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 2 5 5 or 0 0 2 5 5 if your remote only accepts 5 digit codes
* Press the 2 button once, a double LED flash should occur
11. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 0 9 5 or 0 0 0 9 5 if your remote only accepts 5 digit codes
* Press the 3 button once, a double LED flash should occur
12. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 2 2 1 or 0 0 2 2 1 if your remote only accepts 5 digit codes
* Press the 4 button once, a double LED flash should occur
13. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 0 7 9 or 0 0 0 7 9 if your remote only accepts 5 digit codes
* Press the 5 button once, a double LED flash should occur
14. Place your DVD player into Standby mode
15. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
16. Your DVD player should show the words TIMER OK
17. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
18. Your DVD player should return itself to Standby mode
19. Remove the batteries for significant period of time to wipe the programmed codes on your OneForAll remote
Good luck.
Jan 14, 2011 | Sony RDR-VX530 DVD Recorder/VCR
Need codes for sylvania DVL-700F
Unfortunately, the code for the DVD player may not be available in the programming on the chip for this remote. The Sylvania DVD player was made by Funai but it was released in 2005. The URC-6131N was released in 2003. Any remote that is older than the device or is released less than 6 months after the device will not have the new model codes. There is a lag in the codes becoming available to the universal remote programmers.
Your options are a newer universal remote with the code for the Sylvania DVD player, try to program the DVD player remote to control your TV, or get a universal remote that can be programmed by a computer (USB port).
I wish that I could be of more help.
(for support see: http://oneforall-na.com/remote.php?type=URC6131n . The company will give you a list of remotes that do support your device if you contact them.)
Oct 19, 2010 | Universal Remote Control URC-6131N Remote...
Lost code booklet for my oneforall remote
I can help you with your URC-3021 Universal Remote Control issues.
The codes for Sanyo TVs is: 0154.
The codes for RCA DVDs are: 0522, 0571, & 0717.
The codes for Magnavox DVDs are: 0503, & 0675. These may or may not work with newer Blu-Ray players. Since you have two disc players, you will need to reassign the CBL/SAT key to act as a second DVD key.
I don't believe the URC-3021 stores codes for surround sound amplifiers: it has only three function buttons: TV, DVD/VCR and CBL/SAT.
For complete instructions on entering the URC-3021 remote codes, please refer to my posted Fixya Tip One For All URC-3021 Code Entry.
I hope that helps.
_______________________________________________
Reassign URC-3021 Device Key
Urc-3021 Code List Download
One For All URC-3021 Code Search
Feb 13, 2010 | One For All URC-3021 Remote Control
Need code to reprogram oneforall remote for
To control a Magnavox TV with a One for All URC-3021, follow these steps:
1) Turn on your TV.
2) On the remote, press the TV key once.
3) Press and hold SET until the LED blinks twice, then release SET.
4) Enter the first four-digit code from the following list:
0054, 0706, 0030, 1454, 1254
The LED will blink twice.
If it does not blink twice, go back to step 2 and try the same code again.
5) Aim the remote at the TV and press POWER.
The device should turn off.
If it does not turn off, repeat steps 2 through 5 with the next code in the list.
I hope that helps.
Nov 27, 2009 | One For All URC-3021 Remote Control
I just need the code to progran the television
goto http://www.oneforall-na.com/
Sect the remote you have and download the manual.  Please rate!  Thanks.
Mar 18, 2009 | One For All URC-3021 Remote Control
One for all URC4220
go to one for all universal remotes
Feb 13, 2008 | One For All URC4220 Remote Control
Universal Remote Control URC-6131N Remote Control Logo
501 people viewed this question
Top Universal Remote Control Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
