Question about Sony Handycam DCR-TRV330 Digital Camcorder
The Code C:21:00 displays every time I turn on my TRV330
The Code C:21:00 comes up every time I turn on my camcorder. I have aired it out, and left it powered off disconnected from the charger for a long time, but the error still won't go away! How can I get rid of it?
  • nthnhrvy Jul 31, 2010
    I found a solution, that is not what I expected. The solution is:
    1. Remove the battery and unplug the camera.
    2. Tap the bottom of the camera with the palm of your hand.
    In disbelief, I tried it, and it actually WORKS!
    Brigadier General:
  • 4,090 Answers
To more effectively remove the "Dew" or moisture bury it in a bag of rice to attract all the moisture out. It may be too late, depending on length of time it has been affected like this But worth the try. In future store it with a few of those crystal bags that come in packing. They absorb excess moisture Or make up some rice bags
Please rate my help++++Thanks for using FIXYA
Posted on Jul 31, 2010
Testimonial: "Thanks for the advice in keeping the Camera from getting moist again. I found a solution to my problem for now."
    New Friend:
  • 11 Answers
Hi, intro in https://www.youtube.com/watch?v=KhzD7Xf5Rso
Posted on Apr 11, 2013
My pc running windows xp does not recognise my sony dvr trv330 camcorder, any help?
Go to the sony web site and download the driver for your camcorder. Search: DCR-TRV330 softwear (or USB drive(r)) When it asks for the CD_ROM part number grab the CD that came with it and type in the number that's under the words USB DRIVE. If you no longer have the CD try this number: 2-515-350-01. It's for the DCR-TRV280. IDK if it'll work for yours. For best results fined some one who has the disk for camcorder. It's not a key/buy code or anything like that. You can use it as meany times as you like. It's just a number that is used to identify the softwear with that type of camcorder.
Sep 07, 2011 | Sony Handycam DCR-TRV330 Digital Camcorder
When I plug it into the computer it won't show up on the computer
Go to camcorder Menu and turn On USB Streaming option, computer will recognize camcorder.
Thanks.
Jan 09, 2011 | Sony Handycam DCR-TRV330 Digital Camcorder
My Sony DCR-TRV330 doesn't want to turn on at all. I've changed bateries and even tried to turn it on while connected to the charger but still doesn't turn on.
You might try pulling out the battery while connected to the charger, and then turning it on.
Or you could try resetting it while connected to the wall power. That worked with my old palm pilot :) When you open the screen of your camera, the reset "hole" is located directly below the "display" button.
Also, remember to press the little green button down and turn the "power" knob when you are trying to turn it on.
Absolutely no promises that my "solutions" will work, but you can try them just in case.
Jul 09, 2010 | Sony Handycam DCR-TRV330 Digital Camcorder
Error code c31:40
the error code c: 31:40 is related to the drum assy. of the camcorder, you can use the cleaning tape,but if the problem persist then u need to contact the near by service center because it would nt be possible for you to open the camcorder and clean its DRUM assy.
Jun 26, 2009 | Sony Handycam DCR-TRV330 Digital Camcorder
Vista Driver for Sony TRV330
No driver required. Plug the supplied cable into the computer firewire port and the Sony "i-Link" port on the TRV-330 and turn on the TRV-330 in VCR mode. Works in XP and Vista out of the box.
Apr 12, 2009 | Sony Handycam DCR-TRV330 Digital Camcorder
No sound
Great,
sound is coming in TV. It means a small speaker in camcorder is not working and seems open.
let me know exact model to help you more.
Jan 31, 2009 | Sony Handycam DCR-TRV330 Digital Camcorder
Sony DCR TRV330 Error message C:31:22
This is a failure of a motor to move inside the camera. There are a number of causes of this problem. The tape will be ejected to prevent the tape from getting damaged. This is usually the head/drum assembly that is not moving. This is not a repair that should be attempted by an inexperienced individual. Please bring this to a service center for repair.
Dan
Nov 19, 2008 | Sony Handycam DCR-TRV330 Digital Camcorder
Sony Handycam DCR-TRV330 Digital-8 won't calibrate tapes to be able to view
hi there. i just actually had this problem right now. and heres how i fixed it :) it had the error so i took out the tape left it ejected for about 5 seconds. then put the tape back. it read for a little then errored again so it was close. next what i did is plugged the camera in (last time this error happened i plugged in the power and it fixed it) still no fix so i took off the battery waited 5 seconds then put it back on. after that i ejected the tape again and re put it in and it worked! you could try anyone of those things. and usually they work for me. maybe it has something to do with the cameras being old.
Sep 16, 2008 | Sony Handycam DCR-TRV330 Digital Camcorder
C:32:30 error flashes on screen
It was due to moisture condensation. I left the cassette compartment open and remove the battery for one hour approximately. then fixed the battery again and tried and it worked.
Jul 07, 2008 | Sony Handycam DCR-TRV330 Digital Camcorder
New iMac and 2000 Sony Handycam DCR-TRV330
iMovie should support any Digital camcorder that hooks up with Firewire (IEEE1394)
Feb 13, 2008 | Sony Handycam DCR-TRV330 Digital Camcorder
Sony Handycam DCR-TRV330 Digital Camcorder Logo
270 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
