Our Bosch dishwasher #SHU9922UC (FD8007) will not turn on properly. Only its drain pump starts -- and keeps running -- when it's powered on and the door's closed. Pressing the two "drain cancel" buttons for more than 3 seconds doesn't help. Neither does cutting off power, then turning it back on in the hopes of resetting the machine's 'computer'. No water inflow occurs. Help?
Comments:
Apr 27, 2008
- Thank you! Some sediment had caused the drain level float to stick, and just jiggling its stem fixed the problem!
I had a similar issue after I replaced a bad drain pump, seems the logic got hung up.. I poured in a pitcher of water, closed the door, it drained and was then ok - worth a try. If not, you may have a bad water level switch.
my dishwasher just displays 00 and wont start. none of the wash cycles light up Frigidaire...
(More)
my dishwasher just displays 00 and wont start. none of the wash cycles light up Frigidaire PLDF2850RDC2
Eurotech dishwasher Model EDW294E continues to get the Water fill fault intermittently. Yet once...
(More)
Eurotech dishwasher Model EDW294E continues to get the Water fill fault intermittently. Yet once the water has been removed it runs well for several weeks. What is the cause of this fault?
