Question about Canon Office Equipment & Supplies
CHANGING THE WASTE TONER CONTAINER ON A 5020I CANON COPIER
CANNOT LOCATE THE WASTE TONER CONTAINER
    President:
  • 567 Answers
Hi please try these steps:
  • Press and hold the power switch on the control panel for three seconds. Touch the touch key on the display panel when prompted to confirm power down. Allow the machine to power down. Turn off the main power switch on the right side of the machine behind the manual feed tray.
  • Step 2.Disconnect the power cord from the wall outlet. Disconnect the network connection from the machine.
  • Step 3.Remove two screws from the rear lower cover on the machine's right side. Set the cover aside.
  • Step 4.Open the trash bag. Grasp the bottle and slide it out of the compartment. Place it in the trash bag and dispose of it.
  • Step 5.Grasp the new bottle by the handle and slide it into the compartment until it is fully seated.
  • Posted on Aug 01, 2010
    • 1 more comment
    • Hilton Bristol Aug 01, 2010
    • Reinstall the lower rear cover on the machine's right side. Tighten the screws snugly.
    • Step 7Plug the power cord into the wall outlet. Power up the machine and allow the machine to come to a "Ready" state. ("Ready to Copy" displays on the control panel.)
    • Step 8Press the asterisk key on the number pad of the control panel. Press the "2" key and the "8" key at the same time. Press the asterisk key again. The service mode display appears.
    • Step 9Touch the "Copier" soft key on the touch screen, then touch the "Counter" soft key on the touch screen.
    • Step 10Touch the "MISC" soft key on the touch screen, then touch the "WST-TNR" soft key on the touch screen. Press the "C" key on the control panel to clear the waste toner counter.
  • Press the "Reset" key twice to return to user mode.
  • Step 12Press and hold the power switch on the control panel for three seconds. Touch the touch key on the display panel when prompted to confirm power down. Turn off the main power switch.
  • Step 13Plug in the network connection. Power up the machine and allow it to come to a "Ready" state.
    Canon markets a network-capable, multifunction printer called the imageRunner (iR) 5870. The machine's toner-collection system delivers unused toner from the copy process to a waste toner collection bottle in the back of the machine. Over time, the bottle fills up. A soft counter in the machine's logic center counts the copies made and generates a waste toner full message (WTNR-FUL) on the display panel when the machine reaches a preset number of copies. A mechanical switch in the toner-collection system physically detects a full condition and generates an E013 error code. When either of these conditions arise, the toner bottle must be changed and the internal counter reset.
    Copier says to replace the waste toner container...where exactly is that located. we don't have the manual
    the waste toner container is located on right side way of copier behind plastic cover in left angle, near the paper path door.
    Hope that helps!
    Apr 26, 2011 | Canon imageRUNNER 5020i Copier
    Where is the waste toner container on a canon 7065 copier fax machine
    waste toner container is located in front side.open your toner door and door support front frame where the canon logo was sticked.after removing this you can see easily waste toner container
    Jan 27, 2011 | Canon ImageRUNNER 3235 Black and White...
    From where do you remove the waste toner bottle and replace it with a new one?
    Right hand side of machine towards the rear lower small cover two screws at top to remove. Remove bottle empty into plastic bag with no holes in the bottom,then replace old container. Tie the bag off and try not to inhale the powder it is not good for you.
    Aug 31, 2010 | Canon imageRUNNER 5020i Copier
    WHERE IS THE WASTE TONER CONTAINER ON A CANON 5020I COPIER?
    The waste toner bottle is on the right side of the copier by the main power switch. There are two screws that hold the cover on, the cover is the whole one piece below the power switch. Take the two screws out and take the cover off. The waste container is a big milky white container. Pull it out and carefully dump it out and reinstall it and put the cover back on. You will have to go into service mode and reset the counter for it. Good Luck
    Jul 31, 2010 | Canon imageRUNNER 5020i Copier
    Where is the waste toner bottle located on the Panasonic DP-4510 copier? If I empty it, will the message on the machine go away?
    You can access the waste bottle behind the right side rear panel. Three screws. The wast bottle will slide out. the error will go away after emptying.
    Jan 13, 2010 | Canon imageRUNNER 5020i Copier
    CANON CLC3220 COPIER ERROR CODE E0000001-0003
    although the waste container is empty still it show 'THE WASTE TONER IS FULL' cleaned the bottle neck of waste container see to it that the 2transparent round hole area is not clouded by toner .this is the sensor path it should be cleaned(remove one screw to remove transparent cap)
    Oct 01, 2009 | Canon Office Equipment & Supplies
    Need to locate the waste toner container on a Canon ir 6800
    The waste toner bottle should be on the right side of the copier toward the rear of the copier. It is behind a pannel that is held in with 2 screws. Take the screw out & open the pannel & the bottel should be inside that opening it is a milky white container. Pull it out, it is rather large. When you dump out the toner make sure you have a plastic bag with No holes in it, it can be very messy if you are not carefull......Good Luck
    May 20, 2009 | Canon IMAGERUNNER 6570 Copier
    Waste toner
    Turn off the copier. Remove the lower left panel on the left side of the copier, then pull out the plastic container and empty it. Reinstall the container and cover then turn the machine back on.
    Apr 08, 2009 | Canon imageRUNNER C3170U Color Copier
    Canon Imagerunner C3100
    If you open the front door,the plastic container in front is the waste toner container .Remove that bottle and dump all that toner.Make sure the neck of the container is free from toner inside and outside.And put the container back in it's place.
    Mar 29, 2009 | Canon imageRunner C3100 Copier
    Where is the waste toner container in a Canon 5020i?
    ok on the right side of the copier lower right cover 2 screws pakes the panel off behind it is a large plastic bottle pull it out empty it put it back in. then in this order touch these keys... add func// 2 & 8 at same time / then add func again screen should change to serv mode.. then in this order touch copier / counter / misc/ waste toner / clear /ok turn off and on good luck
    Jan 02, 2009 | Canon imageRUNNER 5020i Copier
    317 people viewed this question
    old marine
    old marine
