Question about Ace Hardware Ace Green Turf Deluxe Broadcast Spreader
Where can I find the settings for the Ace Green Turf Spreader for using Scott's 4 step annual fertilizer program? This spreader is never listed on the bag.
What setting do I use on a turf king drop spreader to cover 8,140 sq ft?
http://plantscience.psu.edu/research/centers/turf/extension/factsheets/calibrating-spreader
You have given the area you want to spread, but you also need the rate per square foot of the fertilizer. The link above tells you how to calibrate and check the rate of application.
Or you could ask Turf King direct.
http://www.turfking-lawn-care.ca/index.php?option=com_content&view=article&id=107&Itemid=328
Apr 09, 2016 | Garden
Need a setting for Scott's Speedy Green EdgeGuard mini
First, I went to the products website, in this case Lesco and looked up the spreader settings:
https://www.johndeerelandscapes.com/home/spreader-settings.aspx
Then, I went to Scotts website and looked up spreader settings:
http://www.scotts.com/smg/node2/SCOTTSCOM/lawn-care/lookup-spreader-settings/7800015-24900013-s
I cross referenced a product on the Scotts website that uses the same settings as one of those listed on the Lesco website and I found my settings that way.
In my case I was using Lesco Pre-M 0.86% 0-0-7 and wanted to apply 5.3 lbs/1000ft. My spreader was a Scotts Turf Builder EdgeGuard Mini with settings from 0-15. I found out by cross referencing that the Scotts Speedy Green 1000 and my spreader used the same settings. So I ended up using the recommended setting of 5.5, as listed on the Lesco website for the Scotts Speedy Green 1000, to apply 5.3 lbs/1000ft of pre emergent using my Scotts EdgeGuard Mini.
Hope this helps!
Mar 30, 2013 | Scotts Company Garden
What is the settting on the scotts accugreen spreader for ACE GREEN TURF SUNNY lawn sees None listed on the bag.
Sorry there are no spreader settings listed on the bag. Please give Scotts a call at 877-465-5160 and see if we have spreader settings available for you.
Sep 17, 2011 | Garden
I have a new Scotts Classic Drop spreader and an old bag of 16-4-8 fertilizer. 2,130 SF of Zoysia Zeon lawn. According to my guidance I need to spread 6.5 # of the 16-4-8 fertilizer over the entire area....
Does the product you are using list any Scotts AccuGreen spreader settings? If so, you can safely use the spreader settings listed for the Scotts AccuGreen. If your product does not list any spreader settings, please give Scotts a call at 866-465-5160.
Hilary @Scotts
Aug 27, 2011 | Scotts Company Scotts Turf Builder Classic...
I have scott drop spreader and I want how it will setting for fertilizer
Check the fertilizer bag for instructions. It will tell you the number to set it at for a drop spreader and a broadcast spreader.
Aug 14, 2011 | Scotts Company Garden
I just bought a new Scott's "Classic Drop" Spreader. I owned a Scott's drop spreader before and the recommended settings on Scott's fertilizer bags always worked great. On...
I am sorry that neither spreader performed as they should have. This is very concerning to us, and we would like to get more information about the spreaders, if you still have 1 the manufacture date would be most helpful to us. It sounds like you could possibly have an over-application of the product as well. If you could call us at 1-800-543-8873, we would be happy to discuss this with you. Stacey at Scotts.
Jun 06, 2011 | Scotts Company Scotts Turf Builder Classic...
I have a Scotts Turf Builder EdgeGuard Mini, and I'm using Ace turf builder (crabgrass preventer with fertilizer). What setting should I use???
I was just told by Scott's phone customer service (800-543-8873) that their TurfBuilder EdgeGuard mini can use the same settings as their "SpeedyGreen" broadcast spreader, if your fertilizer lists that one.
Apr 08, 2011 | Garden
As the cyclone brand spreader is "gone" from use, what are the equivalent settings to currently match spreading rates as listed on fertilizer bags for spreaders currently in use.
CYCLONE ROTARY
2.0
EARTHWAY ROTARY
6.0
EV-N-SPREAD
6.0
K-GRO ROTARY
.75
ORTHO ROTARY
.75
PRECISION ROTARY SB50
1.50
RED DEVIL ROTARY
1.50
REPUBLIC EZ ROATRY
.75
SCOTTS SPEEDYGREEN 1000,2000,3000
2.12
SCOTTS BASIC BROADCAST
2.12
SCOTTS EDGEGUARD BROADCAST
2.12
SEARS ROTARY
.75
TRUE TEMPER ROTARY
1.5
VIGORO ROTARY
1.50
SCOTTS STANDARD ROTARY
2.12
CRAFTSMAN
6.0
SCOTT’S EASY GREEN
25
SCOTT’S HANDYGREEN
__________________________________________
Drop Spreaders:
K-GRO DROP
2.25
ORTHO DROP
2.25
REPUBLIC EZ DROP
2.25
SCOTTS ACCUGREEN 1000
3.0
SCOTTS ACCUGREEN 2000
3.0
SCOTTS ACCUGREEN 3000
3.0
SCOTTS DROP PF1, PF2, PF3, PF4
3.0
SEARS DROP 2.25
Apr 29, 2010 | Scotts Company Scott'S& Lawn Pro Spreader...
How to use Ace Green Turf Spreader
At the bottom of the spreader hopper is a gate, there should be a setting lock that allows the opening to move only so far. This may be at the handle controls but unlikely.
To be sure of your spreader pattern and rate, use the spreader on a parking lot to see the pattern, you can always sweep up the granules and reuse them! Walking speed is the biggest factor in spreading rates.... Opening is the next....
Jan 30, 2010 | ACE R Broadcast Spreader - Set of 2
Ace Hardware Ace Green Turf Deluxe Broadcast Spreader Logo
646 people viewed this question
Top Ace Hardware Garden Experts
Ed Hauk
Ed Hauk
Level 1 Expert
Tom Chichester
JonSnell Electronic
JonSnell Electronic
Are you an Ace Hardware Garden Expert? Answer questions, earn points and help others
