Question about Canon imageRUNNER 5020i Copier
WHERE IS THE WASTE TONER CONTAINER ON A CANON 5020I COPIER?
  • Canon Expert
  • 1,326 Answers
The waste toner bottle is on the right side of the copier by the main power switch. There are two screws that hold the cover on, the cover is the whole one piece below the power switch. Take the two screws out and take the cover off. The waste container is a big milky white container. Pull it out and carefully dump it out and reinstall it and put the cover back on. You will have to go into service mode and reset the counter for it. Good Luck
Posted on Aug 01, 2010
3 Suggested Answers
  • 567 Answers
SOURCE: CHANGING THE WASTE TONER CONTAINER ON A 5020I CANON COPIER
Hi please try these steps:
  • Press and hold the power switch on the control panel for three seconds. Touch the touch key on the display panel when prompted to confirm power down. Allow the machine to power down. Turn off the main power switch on the right side of the machine behind the manual feed tray.
  • Step 2.Disconnect the power cord from the wall outlet. Disconnect the network connection from the machine.
  • Step 3.Remove two screws from the rear lower cover on the machine's right side. Set the cover aside.
  • Step 4.Open the trash bag. Grasp the bottle and slide it out of the compartment. Place it in the trash bag and dispose of it.
  • Step 5.Grasp the new bottle by the handle and slide it into the compartment until it is fully seated.
  • Posted on Aug 01, 2010
    • 168 Answers
    SOURCE: Where is the waste toner container in a Canon 5020i?
    ok on the right side of the copier lower right cover 2 screws pakes the panel off behind it is a large plastic bottle pull it out empty it put it back in. then in this order touch these keys... add func// 2 & 8 at same time / then add func again screen should change to serv mode.. then in this order touch copier / counter / misc/ waste toner / clear /ok turn off and on good luck
    Posted on Jan 03, 2009
    Copier says to replace the waste toner container...where exactly is that located. we don't have the manual
    the waste toner container is located on right side way of copier behind plastic cover in left angle, near the paper path door.
    Hope that helps!
    Apr 26, 2011 | Canon imageRUNNER 5020i Copier
    Where is the waste toner container on a canon 7065 copier fax machine
    waste toner container is located in front side.open your toner door and door support front frame where the canon logo was sticked.after removing this you can see easily waste toner container
    Jan 27, 2011 | Canon ImageRUNNER 3235 Black and White...
    From where do you remove the waste toner bottle and replace it with a new one?
    Right hand side of machine towards the rear lower small cover two screws at top to remove. Remove bottle empty into plastic bag with no holes in the bottom,then replace old container. Tie the bag off and try not to inhale the powder it is not good for you.
    Aug 31, 2010 | Canon imageRUNNER 5020i Copier
  • Jul 31, 2010 | Canon Office Equipment & Supplies
    Where is the waste toner bottle located on the Panasonic DP-4510 copier? If I empty it, will the message on the machine go away?
    You can access the waste bottle behind the right side rear panel. Three screws. The wast bottle will slide out. the error will go away after emptying.
    Jan 13, 2010 | Canon imageRUNNER 5020i Copier
    Rplacing Waste Toner Container
    Hello sir;The waste toner bottle right in front of the machine, when you open front door you ill see a white bottle remove and dump it out, turn power off and back on.
    Apr 14, 2009 | Canon imageRUNNER 2270 Copier
    Waste toner
    Turn off the copier. Remove the lower left panel on the left side of the copier, then pull out the plastic container and empty it. Reinstall the container and cover then turn the machine back on.
    Apr 08, 2009 | Canon imageRUNNER C3170U Color Copier
    Canon Imagerunner C3100
    If you open the front door,the plastic container in front is the waste toner container .Remove that bottle and dump all that toner.Make sure the neck of the container is free from toner inside and outside.And put the container back in it's place.
    Mar 29, 2009 | Canon imageRunner C3100 Copier
    Jan 02, 2009 | Canon imageRUNNER 5020i Copier
    You must take off the back panel of the copier and you will see a box sitting on the bottom. You can empty it and should be ok
    Apr 10, 2007 | Canon imageRUNNER 6020I Copier
    Canon imageRUNNER 5020i Copier Logo
    380 people viewed this question
    old marine
    old marine
