Question about Power Acoustik PTID-5300 Car DVD Player
How do i get the blue parking brake screen off so i can whatch a dvd
  • 229 Answers
Take the parking brake wire from the deck and hook it to a toggle switch on the end of that switch run a switch to a ground. When powering up toggle the switch on and off and your in business
Posted on Aug 01, 2010
Car stereo
Many in-dash video systems will not show picture if the car is not in "park". If you are parked and this is still happening, then something may be hooked up incorrectly.
May 23, 2013 | Audio Players & Recorders
My screen does not play it say warning stop whatch
As it's illegal to view your screen while the vehicle is in motion, DVD players are required to be connected to your park brake switch, so viewing can only occur when the park brake is applied.
From what you have described, I suspect the wiring (or switch) connecting to your park brake switch, may have a short, or the switch itself may be faulty.
Hope this helps....
Aug 28, 2011 | Jensen VM9020TS Car DVD Player
My dvd & usb is not working. Everytime i put a dvd in or try and use the usb a blue screen appears and says WARNING PLEASE STOP WATCH VIDEO PLAYER.
the parking brake wire must be connected to the parking brake system of you car. When the parking brake is engages, the LCD will be allowed to view your video. If not, the screen will produce an image saying, parking brake. this is a feature designed for the driver not to watch a video while driving. The video output on this unit will not be affected by this, el wire to connect is Pink - parking brake. this is wire connect with ground.
Oct 10, 2010 | BOSS AUDIO SYSTEMS BV9976 Car Video Player
I have a kenwood ddx512 double indash and when i put in a dvd i can hear it but the screen shows blue with parking off in white letters why is that
needs to be connected to the park brake circut....when the wire gets a ground from the parking brake the screen will show picture...the reason is that it is against the law to have videos play in the front seat while the vehicle is in motion.
Aug 24, 2010 | Kenwood DDX-512 Car DVD Player
My vm9510 wont play the dvd with out saying parking and screen blue
You have to connect the park wire of the Jensen to your hand brakes that gets a negative signal everytime you engage it or you can try to put in series the park wire to a switch and any ground. Then read your manual how many times you got to switch it on and off until the picture appears when your dvd is playing. Same thing if you connect it to your parking brakes you got to engage your parking brakes on for 1 or 2 secs then back off then back on again for 1 or 2 secs keep doing this varying the secs till you get a picture. That will be the sequence to turn off that blue screen and on the dvd to watch the movie. Read your manual very carefully it will tell you the same thing but you definitely have to hook up the brake wire or else you will never see the picture. Check the manual for the color of the brake wire or just find the longest wire on the harness and thats usually the brake wire.
Apr 07, 2010 | Jensen VM9510 Car DVD Player
PARKING BRAKE DISABLE my jensen in dash doesnt want to play dvds its displays a blue screen saying something about the breaks
yes its saying in toorder to play dvd's u must engage parking brake which means the wire is suppose to be hooked up to the parking brake....BUT i know the trick to make it work where u can play dvd's and drive
May 31, 2009 | Audiovox Jensen In-Dash DVD/CD Receiver w/...
I got a dual xdvd8133 and i lost the password how can i get it?
how can i lock in the parking brakes passcodes so i can whatch the dvd anytime
Jan 08, 2009 | Dual Electronics XDVD8183 Car DVD Player
Parking Brake Wire
I have not a solution but a remedy. If you would like to be able to watch movies while driving, follow these simple instructions. Take out the dvd player, Get one simple toggle switch, install somewhere easily accesible. Now run the parking brake wire from the dvd player to one of the prongs on the switch. Now find a good solid metal ground under the dash, (mounting brace,etc.). Run a wire from this ground to the other prong on the switch. Now reinstall the dvd player, turn on, when blue screen appears, flick the switch, hold for 5 seconds, then flick it back, in a few seconds it should go to the normal screen.
Feb 19, 2008 | Jensen VM9410 Car DVD Player
Hii
This is the way to do it without engaging the parking brake sequence, thus you're inputting the code blindly.
1) Insert the DVD and you'll get the blue screen.
(If you have more than one tv, the unit itself will have the blue screen but the additional tv's you have plugged in will NOT, they will show the dvd menu. Thus you will be able to see the hidden menu on the additional screens after inputting the code, but not on the main unit because of its blue screen.)
2) On the main remote, push stop twice and then 1, 2, 6, 4
3) Push the joystick on the unit SOUTH twice and then click it once.
4) Press SYS SETUP on the main remote twice to save your settings
Dec 04, 2007 | Jensen VM9510 Car DVD Player
E brake override
Ground the parking brake wire to any metal surface that is handy. Just as solution 2 suggests. I accidently clicked the top "Guest" as the best solution when Solution #2 was the one I meant to click on. Ground it and enjoy!
Dec 01, 2007 | Kenwood DNX7100 Car Video Player
Power Acoustik PTID-5300 Car DVD Player Logo
236 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Marvin
Marvin
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
