Question about Canon PowerShot SX100 IS Digital Camera
Camera will not turn on. Changed batteries, sd
Camera will not turn on. Changed batteries, sd card and the smaller battery on the side of the cameran and still nothing.
  • nick1968 Jul 31, 2010
    Camera time
    President:
  • 1,382 Answers
Check whether your batteries are actually making contact with the battery posts, and that these posts are clean. If not, bend the posts up/down a little, and maybe clean them with a little rubbing alcohol on a Q-tip.The next thing to try is examine both the battery and flash card door. There's usually a little switch on both doors (note some SD card doors do not have this switch) that activates when the doors are closed. If they don't, the camera won't start to prevent damage to the flash card or camera startup sequence. For most cameras its usually a little piece of plastic on the door that pushes in on a pin switch when the door is closed. Closely examine both doors to try to identify these switches. A lot of times that little plastic nib wears down or breaks off, but can easily be jury rigged with a small glued-on replacement.
If you've tried all of the above and still no luck, the problem is then likely to be internal to the camera. One example would be that if your camera uses Compact Flash, check to make sure all pins are present and aligned in the card slot (if bent, simply unbend/straighten them with a skinny "jewelers" screwdriver, then insert the flash card for final realignment).
Thank you!
Posted on Aug 01, 2010
Switch sim card
Your SD card is for your memory check your battery
this is what you check... turn off your camera Take out you battery charge and replace... Take out your SD card replace it correctly. Remove your lens and replace correctly then turn on camera and walla it works! PS its ok to leave the SD card in the camera. The on and off switch turns on camera with a charged battery ELEMENTRY WATSON.
Nov 19, 2013 | Nikon Cameras
Note if sd card is installed is on the screen wont advance past that DGS 160. I have tried different SD card, hard booted, changed batteries, when I plug into computer interface, it doesn't recognize ...
Do you mean the DGS I-60? What size memory card are you using? The I-60 works with SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
Sep 15, 2013 | Moultrie MFH-DGS-200 Digital Camera
WHAT TYPE OF SD CARD DO I USE
The DV179 uses SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards. You can use any brand and speed SD card, though personally I'd stick with the major brands.
May 06, 2013 | Jazz DV-179 Digital Camera
This is a new purchase, never been used. I inserted the card, installed the batteries and then pressed the putton to turn it on but the display on the screen says "Memory Full! Please Insert an SD...
You didn't specify the make and model of your camera, but from what you do say I suspect it uses SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it's electronically incompatible. Try using an SD card 2GB or smaller.
Jan 03, 2011 | Cameras
I have a Canon Power Shot A520 and have just put in a new memory card 4GB and new batteries. When I turn on camera is says memory card error at the top of the sceen. Why is that?
The A520 is designed to work with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible.
You need to use SD cards 2GB and smaller.
Oct 05, 2010 | Canon PowerShot A520 Digital Camera
Camera works with standard SD memory card, but not SDHC
There are hardware incompatibilities between SD and SDHC cards. They're upward compatible in that SDHC devices will accept SD cards but not the other way around. You will have to hunt down SD cards, 2GB and smaller.
Apr 28, 2010 | Nikon Coolpix L1 Digital Camera
How do you put your sandisk microSDHC card with adapter in your camera
That depends on the camera. If the camera supports Sandisk Micro, then the SD card will fit into a slot. The slot is often located near to the battery.
You will just have to push card in and camera will automatically read card.
If camera does not read the card, ensure that the camera model can support SanDisk Micro, and that it will also support card size. Older cameras do not support big memory card (eg.4Gb)
Sep 05, 2009 | SanDisk 4GB microSDHC Memory Card
Vivitar Vivicam 3715 can't format new 2gb SD card. Card OK!
What information is given in the manual ?
BTW, AFAIK, 2gb SD cards and 2gb SDHC cards are not interchangeable - do you have the correct one ?
Jan 13, 2018 | Vivitar ViviCam 3715 Digital Camera
SD Card Wont Work
Check if the SD card is iserted properly into the camera, eventually pull it out and push it back inside the camera. Also remove camera batteries , repeat the operation, and put back batteries.
If the card still does not work test the card into a different device, it is not unfrequent that an SD card comes defective from factory. In this case take the card back to the retailer and a have it changed.
If the card works on a different device, then it may be that the NV3 does not support 4 GB , there is no mention about max SD format supported in camera specs, or in the manual. In this case I suggest testing a 1 or 2 Gb card at the shop, and then buying right one.
Regards
Apr 02, 2008 | Samsung NV3 Digital Camera
SD Card Recognition
Perform the following procedures when your digital camera does not detect the SD card. 1. Restart the camera Turn the main power OFF, or open the battery cover or SD card/battery cover to remove the battery. Make sure the SD card is fully installed. Then, turn the main power ON, or insert a battery again and close the battery cover or SD card/battery cover until it latches. 2. Initialize the SD card Format the SD card with your camera. Formatting procedures varies depending on the camera model. See the Camera User Guide supplied with your camera for the instruction to format the SD card. When formatting the SD card, slide its tab upward to cancel write protection. It is impossible to format the SD card while it is write protected. 3. Check if your camera detects other SD cards (If you own multiple SD cards.) If your camera does not detect the SD card after performing the procedures 1 and 2, check if the camera detects other SD cards. If it does detect other SD cards, the SD card that wasn't detected may contain some problem.
Aug 31, 2005 | Canon PowerShot SD110 / IXUS IIs Digital...
Canon PowerShot SX100 IS Digital Camera Logo
297 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
