Question about RTO Bodyguard T200 Treadmill
Elevation Will NOT go down after the elevation calibration
I just purchased the T260C model from friend of ours, and I did the elevation calibration check as stated in the manual. Now the elevation WILL NOT go back down, so....unusable. Can u help me????
    President:
  • RTO Master
  • 832 Answers
Unplug unit and remove motor shroud if you are savvy with a multi meter then try these trouble shooting procedure:
Perform and elevation calibration again, On the display, can you see numbers counting down and up and the treadmill is going up and down? If yes then the unit will proceed to work, if no when power is on, check on the lower board, on connector J5, do we have 5V DC between pin 1 & 3? If yes During Calibration, J5, between Pin 5 & 6, on the lower board, do we have 120V AC when treadmill is going up?
If Yes During Calibration, J5, between Pin 4 & 6, on the lower board, do we have 120V AC when treadmill is going up?
If Yes During Calibration, J5, between Pin 2 & 3, on the lower board, do we have DC voltage varying from 1.15 to 3.00? If any of the above is no then then the lower board will need replacing if all is yes then elevation motor needs replacing.
Posted on Aug 01, 2010
How do I calibrate elevation grade for treadmill?
Hey there, sorry to hear you're having an issue with your elevation motor. I would be happy to help you solve the problem.
Since you already installed your motor you can go straight into diagnostic mode.
To get into Diagnostic Mode on your L8
Make sure to turn off your treadmill.
-ET's - Press Menu and Start at the same time
-CT's - Press Manual (or Display^) and Start at the same time
-All other L SERIES mills - Press Display (or display and Start at the same time
SideNote-
-*CT's that were manufactured after 09/2003 - Press Display and start at the same time.
Few things you want to do, if you haven't already.
A. Align the motor with the clevis mount and install the motor mounting pin.
B. Insert hitch pin.
C. Reconnect the elevation harness to the lower board
D. Set the lowest limit switch by holding the UP elevation button for 5 seconds. Then press and hold the DN elevation button one more time to make sure you only hear a click.
E. For L7/L8 machines; Thread the elevation nut to where its flush with the threads on the "worm' shaft.
F. Mount the elevation nut to the leg assembly by lining up the holes on the leg assembly. You may have to move the leg assembly so that the holes on the elevation nut line up. Then slide the two elevation pins through the elevation assembly and into the elevation nut. then secure the pins with the 2 set screws.
To calibrate your potentiometer you can try to adjust while it is installed but for best results you must calibrate it before its in your motor housing.
G. Calibrate the elevation potentiometer and to do so you must;
1st: Visually confirm treadmill is leveled. (0% grade)
2nd: Adjust the settings as follows;
All L SERIES millls should read 0.0
3rd: If the setting is incorrect, follow these steps.
Step 1: Turn the post of the potentiometer all the way
CLOCKWISE.
Step 2: SLOWLY turn the potentiometer COUNTER
CLOCKWISE until the setting is correct.
H. Carefully install potentiometer into the motor housing
*NOTE: The setting may vary when inserting the potentiometer
into the motor. As long as the change is minimal, fine
adjustment can be achieved by rotating the meter
while inside the elevation motor.
I. Press OFF to turn treadmill off. Then restart the machine in manual mode to TEST elevation after resetting your potentiometer. As long as the change is minimal, fine adjustment can be achieved by rotating the potentiometer while inside the elevation motor.
For more Diagnostic features and possibly further detail, I will be attaching a Link to your machines service manual. I hope this helps, always hear to help. SportSmith.
http://www.sportsmith.net/images/product_support/landice/Manuals/Service/P0472050%20L%20Series%20Service%20Manual.pdf
Apr 20, 2015 | Landice L8 LTD Cardio Trainer Treadmill
Tip
How to calibrate a Vision Fitness Treadmill - Residential Models
If you are not quite sure about the speed/elevation of your machine you can perform the following to test/correct your Vision Fitness treadmill.
1. Remove safety key and then replace
2. Hold the elevation up and speed down buttons until it beeps 3 times
3. If you see the model of your treadmill on this screen make sure you hold enter and then you will see "eng1"
4. Use the elevation buttons to scroll to "eng4" and hold enter to select
5. you should see the word "auto" on the screen at this point
6. Making sure you are not on the treadmill at all, press start.
The treadmill will go through a few tests to determine the maximum and minimum of both speed/elevation. You can see the results on the display as it is performing this test and if there are any discrepancies the machine will adjust the settings to make the appropriate speed/elevation calibration.
If the test passes it will display "end" and from here just remove and replace the safety key. You should notice a difference in the speed right away.
on Aug 05, 2010 | Exercise & Fitness
I have a tunturi t40 treadmill an error code e7 appears And it cuts out after 5 seconds have tried to calibrate the elevation motor but it won't stay at 9 mm gap when it powers up the gap closes
please test the 2 alternatives for error 7. God bless you
see the diagram attached.
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Jan 08, 2013 | Tunturi T40 Folding Treadmill
E7 error message
see this steps and fix it. God bless you
ERROR CODE # 7
2)Alternative:
Nov 27, 2012 | Exercise & Fitness
What does E7 mean on Lifespan TR4000i?
see the 2 alternatives that the error code 7 means:
2)Alternative:
However RUN the software calibration for diagnostic, troubleshooting and Fix it.
God bless you
Sep 29, 2012 | LifeSpan Fitness TR4000i Folding Treadmill
Efx 546 in diagnostics mode, flashes 255 and then real position of incline. getting error 42 when first turning machine on.
ok
elevation needs calibration or stuck
open--put elevation manually lowest and turn the unit on and bring the elevation lowest by pressing el down key
put it together clear it and start elevation will come in the starting position clear it and use it 225 is out of range of elevation
also check elevation fuse if it is good and secure
Nov 20, 2010 | Precor EFX 546i Elliptical Version 4
Why won't my vision fitness simple T9500 run? I tried holding down the stop button for 3 seconds. It did clear the screen. Then when I hit start it puts 6000 in the screen and will not run. It beeps as if...
With the safety key in place, press and hold “ELEVATION UP” and “SPEED DOWN” for 5 seconds. The software version will appear in display window shortly before model number appears. Press “ENTER” to accept correct model number IF YOU CANNOT GET INTO CALIBRATION EITHER UPPER CONSOLE ELECTRONICS OR OVERLAY CONSOLE ASSEMBLY HAS FAILED.
• Press “STOP” to enter “ENG1”. Press “ENTER”. PLEASE NOTE: HR Window = “0” for miles, “1” for kilometers, treadmill will calibrate in kilometers if set for kilometers. STEP 2 MINIMUM SPEED • Press “ELEVATION DOWN” button, “P0” will appear in display. • Press “START” button, the running belt will begin to move at minimum speed. • The display window should read approximately “.49 - .51”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “.49 - .51”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P0”. STEP 3 1/4 SPEED • Press “ELEVATION UP” button, “SP1” will appear in display. • Press “START” button, the belt will move 1/4 speed. • The display should read approximately “2.71 - 2.73”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “2.71 - 2.73”. Press and hold “ENTER” to save changes. Press “STOP” to return to “SP1”. STEP 4 1/2 SPEED • Press “ELEVATION UP” button, “P1” will appear in display. • Press “START” button, the belt will move at 1/2 speed. • The display should read approximately “6.72 - 6.73”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “6.72 - 6.73”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P1”. STEP 5 3/4 SPEED • Press “ELEVATION UP” button, “SP2” will appear in display. • Press “START” button, the belt will move at 3/4 speed. • The display should read approximately “9.41 - 9.43”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “9.41 - 9.43”. Press and hold “ENTER” to save changes. Press “STOP” to return to “SP2”.
STEP 6 MAXIMUM SPEED • Press “ELEVATION UP” button, “P2” will appear in display. • Press “START” button, the belt will move at maximum speed. • The display should read approximately “12.10 - 12.12”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “12.10 - 12.12”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P2”. STEP 7 MINIMUM ELEVATION • Press “ELEVATION UP” button twice, “P4” will appear in display. • The display should ready approximately “190 - 205”. • To adjust, press “ENTER” for value which should read “190 - 205”. Use “SPEED UP” or “SPEED DOWN” buttons. Press and hold “ENTER” to save changes. Press “STOP” to return to “P4”. STEP 8 MAXIMUM ELEVATION • Press “ELEVATION UP” button, “P5” will appear in display. • The display should read approximately “750 - 765”. • To adjust, press “ENTER” for value which should read “750 - 765”. Use “SPEED UP” or “SPEED DOWN” buttons. Press and hold “ENTER” to save changes. Press “STOP” to return to “P5”. REMOVE SAFETY KEY TO EXIT ENGINEERING MODE REPLACE SAFETY KEY AND PRESS START TO TEST TREADMILL
Jun 14, 2010 | Dmm Vision Fitness T9500 Treadmill
I turned on my treadmill after a long hiatus :) and got an error message and a beep. The errors were E4, E9 and a few others. It is a Vision Fitness T9400HRT model. Any idea how to fix?
E4: Solution 1. Check power to the treadmill, as insufficient voltage to the treadmill can cause this error to reoccur. Check the power socket that the tread is plugged into. Eliminate any extension cords or surge protectors (plug the tread directly into a functional power source). Make sure the circuit is not overloaded. Make sure the circuit is NON-GFI. 2. Calibrate (See engineering mode for specific treadmill). 3. If calibrations do not hold, replace upper console. Note: Usually simultaneous with an E6. E6: Solution 1. Check the elevation plug connection at the lower board. 2. Check ALL large data cable connection at the lower and upper boards. 3. Calibrate (See engineering mode for specific treadmill) 4. Test/change large data cable (use large data cable information provided in the data cable portion of this Guide). 5. Replace elevation motor E7/E9: Solution 1. Certain lower boards have an LED that flashes when the magnet on the roller passes the sensor. Adjust sensor position if LED does not flash. See lower board basic troubleshooting for lower boards with the LED. 2. Unplug RPM sensor at the lower board. Check continuity. Treadmill will operate without sensor but cannot Autocalibrate. Calibrate manually. 3. Replace RPM sensor TREADMILL.TROUBLESHOOTING. AUTO CALIBRATION STEP 1 ENTER ENGINEERING MODE • With the SAFETY KEY in place, hold the “ELEVATION UP” and “SPEED DOWN” buttons for 5 seconds. “DGA3” will appear in the profile window and “EHG1” will appear in the function window. • You are now in ENGINEERING MODE STEP 2 ENTER AUTO CALIBRATIONS • Press the “ELEVATION UP” or “SPEED UP” to “EHG4”. • Press “SELECT”. STEP 3 • Press “START”. The treadmill will calibrate itself. This will take about 3 to 5 minutes. When AUTO is complete, “END” will appear in the window. Wait 10 to 15 seconds and the treadmill will reset itself to “P1”. STEP 4 • Press “START” to test the treadmill
May 04, 2010 | Exercise & Fitness
RTO Bodyguard T200 Treadmill Logo
271 people viewed this question
Top RTO Exercise & Fitness Experts
Howard
Howard
Jax Planet
Jax Planet
Marvin
Marvin
Are you a RTO Exercise and Fitnes Expert? Answer questions, earn points and help others
