Question about Proview Computers & Internet
32" RX series t.v./computer monitor shows mostly black screen. Is this a light bulb problem? I live in Fort McMurray, AB Canada and can not find anyone who fixes monitors. Please advise.
    Brigadier General:
  • 10,406 Answers
It's a problem that takes a qualified technician to repair.
Take a look at:
http://ab.allpages.com/fort-mcmurray/shopping-shopping-services/appliances-household-commercial/
for several "TV repair" listings in your city.
Posted on Aug 01, 2010
No pictures showing anymore
sounds like the projection bulb went. behind computer monitors and lcd screens is a bulb that shines a light threw the screen to allow you to be able to see the image, try opening the unit to see if the bulb is on while unit is on, if not try shining a light threw the back of the screen to see if you can see the image. bulb may need to be replaced.
Dec 15, 2013 | Sunpak (SDPF-070AW-0US) Digital Picture...
Screen gets black
Typically the graphics card went out. Other possibilities include, loose monitor cable or short in the cable, or incorrect graphics driver installed or missing, or monitor is shot (least possible). Things to look for: When booting up are you able to see words in the monitor or is there a series of non-regular error code beeps? If beeps then most likely your graphics card is either loose or fried, or incompatible. If you it works fine, but the light on the monitor turns orange and screen goes black, then it's most likely a loose monitor data cable or there is a short in the cable, or monitor's power cable is loose. Then check both connections, power and data on the monitor, and also where it hooks to the computer make sure it's screwed in snug.
Jan 13, 2012 | Computers & Internet
Well, when i turn on the computer the monitor only flashes it alittle but then it like turns off, and it dosent leave the screen on?
I would first try booting from a boot disk or live cd to make sure it isn't a driver issue. If the problem persists, you may be looking at a damaged monitor. Take a flashlight, and gently hold it to the screen to see if the LCD portion is working. If the LCD is working, but the lamps are not then read on. The most common reasons for a monitor to fail like that are damaged caps, burned transformer, and/or burned bulbs. The control circuitry sends a burst of energy to the bulbs to light them, then backs off to user settings. Most monitors will sense if the bulbs didn't light, and try a couple more times before giving up. I'm in the process of working on one now that exhibits the same symptoms and after opening the thing up it needs three caps, a transformer, and a new set of bulbs. Best of luck.
Sep 18, 2011 | Hyundai ImageQuest L70S 17" LCD Monitor
I am in Fort Mcmurray Alberta, Canada, I want to configure my Shaw remote with my Vizio 42 in. LCD TV, to control the Volume of my TV. with Shaw Remote Control, Please Help to make it happen. Thank you
If you can provide the exact model number of the remote control, I can certainly assist you in the process.
Just comment back here to this page and I will respond with additional details as soon as I see it.
Thank you.
Joe.
Feb 24, 2011 | Vizio 42 in. LCD TV
My HP Pavilion dv9000 Laptop powers up but screen stays black. Keyboard lights up and you can here the computer running.
Connect it to an external monitor to see if it shows video.If it does the display panel needs to be replaced.If it doesn't show video the video card is most likely malfunctioning.The HP dv series are bad about having video problems due to heat and depleted thermal grease.Hopefully it will show video on the external monitor.
Jan 26, 2011 | HP Pavilion dv9000z Notebook
Hi, I have lost my only key to my '99 Odyssey. There is no dealer in my town so how do I go about getting a replacement? I live in Ft McMurray AB.
Most dealers have a cross reverence for vehicle replacement key's.You have to bring the vin number which can be found on the lower outside bottom of the drivers side windshield and they should be able to cross reference to your dealer for to press you out another key against the vin #............Hope this helps you out..............Magiaver Bonnyville Alberta.
Nov 19, 2010 | Honda Odyssey Cars & Trucks
Viewsonic VG 900 displays briefly, then goes blank
What Usually causes these to go on and off quickly is one af a couple things.
Usually it is the powerboard not putting out enough power to run the video board and the inverter.
Sometimes it is the actual inverter board. I have seen a plain small fuse stop these cold.
Rarely, but it could be a bad bulb in the screen. Bad bulbs usually start dark in the middle, or they start off pink. They can also flicker while they are on.
If you can take it apart and have a dc tester, the problem may be able to be found.
I repair some viewsonics , mostly VXs series, but I have done a couple of these.
bammbammfran
Oct 11, 2008 | ViewSonic VG900b (Black) (10 Pack) Monitor
RE:monitor goes black
Monitor going black after a few seconds can be causd by a faulty power supply or inverter. Some monitors have both as one unit.
Sometimes it is basic failed capacitors, After that then I would look at transistors.
The average monitor from 17 to 20 and sometimes the 22s have usually 4 bulbs in them. One bad bulb will also cause the inverter to not fire up.
Bad bulbs usually show pinkish tint, or flickering or are dark at center top or bottom of the display.
ebays bammbammfran
Sep 21, 2007 | Acer AL2017 20" LCD Monitor
17" Monitor keeps going black
Hi Rahni, It's a very common problem. LCD's use four small Cold Compact Fluorescent bulbs to back light the display. (thats what gives the LCD it's brightness allowing you to see it) The inverter board runs these lights and when they go bad they will typically show symptoms like you have or the monitor power light comes on and you have either no display or a very dim display. If you ever have one that has no display but the power light is on you can check by shining a flashlight directly into the LCD from the front (right into the screen) if you can see an image then it's either the inverter board (most likely) or the CCFL bulbs have gone bad. The inverter board and CCFL's are replaceable. Good Luck, El Duderino
Nov 18, 2006 | HP Pavilion F1703 17" LCD Monitor
Computers & Internet Logo
62 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ka4iup
ka4iup
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
