Question about Price Pfister Home
I need an installtion book or pamplet for a PRICE PFISTER shower/tub faucet
    Scholar:
  • 67 Answers
To find install manuals for Prive PFister go to http://www.pricepfister.com/bath/bath_product_documentation.aspx.
You will need to know either the model number or the collection name of your fixture.
Posted on Aug 03, 2010
My pfister shower cold water faucet handle broke off. The stem is stuck so I can't replace the faucet handle. How do I remove this stuck portion of the old handle?
the model is needed for a step by step but. if your faucet is for a sink and not a shower then the handles may be connected to the pour spout or separate depending on model and in either case there is a nut screwed under the fixture that hold it in place. do not unscrew any of the faucet until you have turned of the water running to it.
here are links to the different types
Price Pfister Bathroom Sink Faucet Repair
Moen 4570 Handle Fell Off But Then Fixed It Here How
How to remove kitchen faucet
and just in case it is a bathroom fixture
Maintenance How to Remove Replace Cartridge on Single Handle Tub Shower
Sep 03, 2017 | Plumbing
Set water temp
remove the handle, find the plastic disk with teeth, pull out disk and turn to left for hot, right for cold, set disk back in place, then replace the handle, repeat as necessary.
Feb 22, 2012 | Price Pfister Plumbing
I have a price pfister a112.18.1 shower only (no tub), single-handle. It is leaking from the shower faucet. How do I repair?
You have to turn water off to shower and remove handle then cartridge lock ring then there are two washers and srpings that can be popped out with small screwdriver.Lowe's has replacement springs and washers ,be sure to mark position cartridge was because that is very important to reinstall the same way it came out.
Jun 09, 2011 | Price Pfister Plumbing
The hot and cold are reversed on our single handle shower (no tub faucet -- shower only)
Hot on left.
Cold on right.
Some single handle faucets have bleed-over where both hot and cold enter mixing valve each time handle is turned on, even when faucet calls for just cold or just hot.
Otherwise maybe a do-it-yourself plumber got pipes backwards... or maybe the tub used to be on other side of wall, and tub was moved during remodeling but pipes were not changed.
To fix problem:
First of all, turn off shower faucet. Turn on Hot at sink and put ear against shower faucet listening for sound of water flowing through the mixing valve.
If mixing valve is working fine, you need to open wall and investigate more.
For example if you have access door, reach in and feel which pipe is hot.
Pipes might need to be reversed if problem comes up in home inspection, otherwise the problem will not harm anything.
Feb 19, 2011 | Price Pfister Plumbing
Our shower head is very similar to the Price Pfister Savannah model. Recently we were forced to replace our water heater. As a result several faucets were blocked up with debris. We suspect that is the...
The simple method is to take the faucet head off the extension pipe that comes out of the wall. It will take two pair of pliers and a firm grip to take it off. Using a wet/dry shop vac at the supply end and a garden hose at the shower end, force water backwards through the faucet head.
Jan 02, 2011 | Price Pfister 01-81BC Savannah 3 Handle...
Price Pfister tub/shower facuet needs much force turn on and off
put water off at mains . step 1.-open your i box mixer. step 2-u will see a 2 mm pin. mabe yours looks difrent. bt there were u change between bath and shower that button... that nob wil have a pin at the back. try to put q20/oil in there or sope. if that dosent work u will have to get a plumber in to unscrew the mixer and clean out the inside. not recomended if not a plumber bt if u do wane try it ur self and the sope and oil dident do the job let me know im a plumber will walk u threw it
Jul 04, 2010 | Price Pfister 07-81PC Savannah 2 Handle...
I have a Price Pfister Model no. 808 DK00 single handle bath tub/shower faucet. I am only getting hot water coming out when the handle is turned on. This problem just started. It was working fine for about...
It's likely that you have some sediment that has accumulated in the cold water valve and has clogged it. The model number you have cited above is only for the trim (rather than for the valves behind it). Assuming that you have a Price Pfister valve, they don't have built in filters, so you're probably going to have to either clean or replace the valve.
Sep 17, 2009 | Price Pfister R89-7PC0 Chrome Portland...
My 3 handle bathtub fauset [price pfisher] cycles hot and cold
You will need to either replace center "shower diverter"assembly or a quicker fix would be to remove old tub water fill spout and replace with a "pull up diverter knob" type water spout. Cost about 10 dollars Hdepot Pull Knob to divert water to shower when showering.
jthomefix
Mar 15, 2009 | Price Pfister Ashfield Widespread Bathroom...
My price pfister tub valve leaks
there is an o-ring inside the valve that seals. It has failed. They should sell a rebuild kit where you bought it, or dis-assemble, and take the failed oring in to have it matched to a new one.
Dec 26, 2008 | Price Pfister Ashfield Single Control...
Home Logo
373 people viewed this question
Top Price Pfister Home Experts
Mike
Tim Whalen
Are you a Price Pfister Home Expert? Answer questions, earn points and help others
