Question about Microsoft Turtle Beach X4 Dolby Digital Wireless Headphones for Xbox, Xbox 360
My headset transmitter has stopped working. It is not the devices power cable as i have used them on another unit to power it and it worked so the problem lies within the transmitter. It turnt off suddenly and it now can't be switched back on
2 Suggested Answers
SOURCE: xbox my power cable won't fit into the back
I never heard of this, it is probably up-side down. Or perhapes you forced it in, while the wrong way which make's some plastic tear off, so if you notice it, your might need a new powerbrick/AV cable
Posted on Nov 08, 2009
What are connections and connectors for audio output to wireless headset
Hi Richard,
First, you'll need to determine which type of input(s) the wireless headset transmitter has. Most common is the 3.5mm stereo plug designed to slip into the headphone jack of a TV, MP3 player, cell phone, etc. Some transmitters have adapters in the box to allow connecting to the Left and Right channel RCA / phono style jacks found on other components such as CD, DVD, VCR, Stereo receivers / amplifiers, etc.
You'll need to find OUTPUTS of the CD and TV that match the plug on the wireless headset transmitter. If yours doesn't include adapters to go from say the RCA jacks mentioned above - to whatever connector that the transmitter input has - you'll need to go to your local Radio Shack store or similar store to see if they can provide an adapter that will allow you to connect.
Here are a couple plugs / adapters:
Above: A "3.5mm stereo patch cable". Your transmitter may have a cable with an end like this to plug into the TV's headphone jack.
25683604-gy4zxbmnj5ndu14q12lmwneo-2-1.jpg Above: A "3.5mm female stereo jack to RCA stereo male plug" adapter that would allow the top cable to connect to the Left and Right audio output jacks on a typical CD, DVD, etc. device.
These cables / adapters are typically $5 to $10 maximum.
I hope this helps and good luck!
May 07, 2015 | RCA Televison & Video
Why does my Afterglow prismatic microphone work at certain lengths?
A lot of the wireless headsets work on a smaller scale than things like bluetooth devices and require you to be closer to the transmitter, but if it's still under warranty it wouldn't be a bad idea to take it in and see what they say about it.
Jan 08, 2015 | PDP Afterglow Universal Prismatic Wireless...
When I connect the USB for headset into system it messes up my internet wireless connection. when I take USB out my internet will work fine again
The wireless transmitter for your headset is causing interference with your wireless network.
If you can move your wireless networking equipment away from the USB transmitter then this may lessen the problem.
Perhaps using a usb cable extender will allow you to move your USB transmitter away from your computer?
Hope this helps,
Chris
Mar 02, 2011 | Logitech H760 Wireless Headset
My Belkin F8Z441 has stopped working after a month. It's charging my iphone but the transmitter doesnt work at all. No display. Please help...
wrong... you need to open device to check the cable connections... due to the devices ability to turn this pulls out some of the connections.
Feb 21, 2011 | Belkin F8Z441 TuneBase FM with HandsFree...
I bought a samson se50 headset microphone to go with my GTD Audio wireless system. It has the correct adapter plug to plug in to the transmitter. The plug is a mini XLR plug. The microphone does not...
You need power from the transmitter to power this mic. See your mics specs to determine if it needs "Phantom Power"
Perhaps the transmitter doesn't supply power. Condenser mics may not work. Stay with the dynamic type. IMHO
Jul 29, 2010 | Nady Systems Nady ATM-75 Headset Mic w/...
Computer Does Not Detect Headset Microphone
Sound and Recording jacks stop working on the DV6000 series due to the ribbon cable running under the power button. when the power button is pushed it bends the flex cable and over time it breaks the connection rendering the front jacks useless you can buy a new upper button panel for about 20 dollars on ebay
Aug 02, 2009 | HP Pavilion dv6000z Notebook
Wireless keyboard won't work
Check the cabling from transmitter unit to the back of your pc, unplug and plug the cable back in, perhaps to another USB port. When you do the connect button I have always down the transmitter first and then the device, like they keyboard or mouse. Make sure the batteries you used work. If you have another computer you could try it as a test.
Jan 17, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Will the Iogear GBMA211 Wireless Audio Transmitter (GBMA211) work with ANY bluetooth headset I have a Motorola S9???
No, it will not work with other headset like Motorola S9. The GBMA211 Audio transmitter is tested to work with the GBMH211 IOGEAR Bluetooth headset.
The GBMA211 was tried with the other Bluetooth headset but no success.
Jan 14, 2009 | IOGear GBMA201 (GMA201) Bluetooth Wireless...
Not able to do fm transmittal
if the headsets work the fm transmitter may already be working. unless they are using an ir signal. you can test this by blocking the the ir or (infrared) led's on the lcd and the dvd player , if the headsets still work than its probably being sent via fm signal. turn your head unit on to fm andstart at 87.1mhz and work your way up to 89.9mhz in .1mhz intervals fm transmiters are usualy some where in that frequency.hope that helps
Dec 01, 2008 | XO Vision XO-141FM 14.1 in. Car Monitor
Logitech wireless headphones
Trying re-syncing the transmitter and the headphones. Hold down the power buttons on both until they alternate red and blue blinking, worked for me and now they work just fine. Got that from the Logitech FAQ website.
Feb 27, 2008 | Logitech (980361-0403) Headphones
Microsoft Turtle Beach X4 Dolby Digital Wireless Headphones  for Xbox, Xbox 360 Logo
160 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
