Question about Whirlpool Duet GHW9150P Front Load Washer
THE DOOR WON'T COME UNLOCKED - Whirlpool Duet GHW9150P Front Load Washer
    Sergeant:
  • 209 Answers
Usually this means that it has not finished its programme cycle. Unplug it from the power source for a few minutes then plug it back in and see if that releases the door switch, if not try to manually turn the programme dial round to its finish position.
Posted on Jul 31, 2010
Keyless entry on car unlocks then locks back automatic
How about a year, make, model????? Not all cars are the same
Dec 23, 2017 | Cars & Trucks
Nissan 1990 pathfinder doors won't unlock
Door locks are powered through a circuit breaker (location not indicated) which applies 12V to the door lock timer. Insertion of the key causes the door lock actuator to unlock the door ...unless the timer prevents it. It is doubtful that all the doors could have failed lock components
Oct 15, 2012 | 1990 Nissan Pathfinder
The doors will not lock or unlock from the door but will from the remote?
The title suggest the door won't unlock unless the remote is used but during the summer it was the inverse. If while inside the car the doors will not lock or unlock from the door but will from the remote then you have a faulty switch.If while outside the car the key turns while in the lock but the door won't lock or unlock then the linkage at the end of the lock is faulty. You'll need to remove the door inside plate to check this.
Dec 07, 2011 | 2004 Infiniti FX45
2003 Monte Carlo SS, FOBS won't unlock doors (new batterries), use key and open the door with the door open FOB will lock and unlock the door, shut the door and the FOB won't lock the doors. After...
If the passkey is messed up, there will be a light on the dash that says security, or have a picture of a car with a lock thru it. If there is no light when the key is turned forward, then its NOT a passkey problem.
Aug 17, 2011 | 2003 Chevrolet Monte Carlo
Won't open my door when I press unlock, key won't open door either
can you manually unlock the lock and open the door?? Is it more than one door or just one specific door? If its just one door, yourcactuator inside the door may be bad or you have a wire issue. If its all the doors, more than likely you blew a fuse or a relay(id say fuse)
May 23, 2011 | 2005 Nissan Murano
Bosch Nexxt 300 has error code E-13 and the door is locked. turned on/off, unplugged, removed the drain hose to see if it is blocked, but ok. but still won't unlock. Is there someway to unlock the...
Turn the dial to off position wait few second, door should unlock. Unless you try to open it during cycle, it won't open. Otherwise, follow owner manual. call the manufacture.
May 18, 2011 | Bosch Washing Machines
Drivers door doesn`t unlock when the weathers cold or it`s raining
weird this one, has a transistor playing up but where ??
Oct 05, 2008 | 2001 Volvo S60
Whirlpool Duet GHW9150P Front Load Washer Logo
158 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
