Question about Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
3.5 HP Lawnmower engine and it rus for only 30 seconds
It is a 3.5 HP Lawnmower engine and it rus for 30 seconds and then slows and stalls. Cannot restart without priming it. Took carb apart and checked and cleaned everything!!!
  • Tecumseh Master
  • 7,482 Answers
Sounds like you will need to clean your carburetor even tho you said you alread did.
Make sure to blow out all the jets with compressed air, beware of small parts sometimes in the jets such as seats for the fuel float jet seat.
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please rate me,
Thanks
Good Luck,
I hope this helped
Posted on Aug 15, 2010
  • GreenBalls Apr 15, 2011
    Definitely not the answer. Cleaning the carb is great for the carb, but these mowers are just not made like they used to be. Put in fresh gas, changed oil, cleaned carb 2x and cleaned mower. Starts up, runs for 10-30seconds and dies. Can start again without priming, but does the same thing. New air filter and spark plug as well, but same results.
Husqy mower, Honda engine. Carbarator and fuel lines clean. Will start and run for 20-30 seconds then dies out. How can i fix this without a $250+ bill.
Hi Joe, The links below are YouTube videos that might get you out of trouble... Also there's videos down the right side of the links that may help as well....... I hope they help......... CHEERS....
shows a craftsman mower with problems....
Craftsman Lawn Tractor stalling out
How to test lawn mower electrical safety switches....
Shows all safety switches disabled....
Disable all lawnmower safety switches
Apr 28, 2016 | Husqvarna Garden
Will start but will only stay running if you prim it until its warm then runs fine
Lawn Mower Repair pt.1: starts & dies, Tecumseh/Craftsman ...
? 2:10
https://www.youtube.com/watch?v=IVYYYpAviPA
Mar 7, 2011 - Uploaded by Alameda Repair Shop
Spray with starting fluid and the engine runs a bit longer but dies.... I especially like how you use the gas can to hold up the mower, Classic :) ... After I started it up, it would only stay running for a few seconds before dying. .... LAWNMOWER REPAIR: briggsand stratton pulsa prime carb overhaul - Duration: ...
How to fix a gas lawnmower that starts then dies - YouTube
? 7:37
https://www.youtube.com/watch?v=caa0WrpxqyU
May 3, 2011 - Uploaded by SmallEngineRepairGuy
This is a how to video on what to do if your gas mower starts up then dies after a ... I have a different lawnmower and not very mechanical but this got my ... Got the job done and now i can do a thorough cleanout of it when i run it dry of gas. .... How to FixBriggs & Stratton Small Engine that Only Runs Off the ...
Craftsman 5.3hp starts but won't stay running... - DoItYourself ...
Dec 09, 2015 | Briggs & Stratton Briggs Stratton Intek V...
I have a Murray 20 model 20213A with a Tecumseh engine. The lawnmower will start but it dies a few minutes later. What could cause this and where can I get a manual for this model lawnmower?
Use high test fuel without ethanol, and
Murray 22" Lawn Mower - Carburetor Cleaning, Nasty ...
? 7:33
www.youtube.com/watch?v=_dzcDZUh1MY
May 10, 2013 - Uploaded by mountainbikekayak But here is the link for the start up of this Murray had to replace the plug as well also ... as well: Murray 22" Lawn Mower 6.5 HP OHV -- First Start after Carburetor Cleaning - Part III - May 9, 2013 ... When I start it, it runs for 3-4 seconds and dies. ... Youcan also find you engine Model # online and view the ...
Sep 09, 2015 | Tecumseh Garden
Simplicity 16hp Briggs stalls
Check the slow running jet for glogging, set the mixture screw 2 turns from fully closed and make sure the small filter connected to the fuel tank is not blocked.
Mar 29, 2014 | Simplicity Garden
I have a 1998 dodge ram 4x4 with a 5.9, engine has been idleing rough, it idles fine for about 30 seconds then runs rough, almost to stalling, also the gas mileage is like 3 miles to the gallon. i had it...
If the speed sensor code is coming up change it. the sensor went out on my truck and it would die when i was slowing down and hit the clutch to downshift
Jan 26, 2013 | 1998 Dodge Ram 1500 4WD
Low output on 110 when using power tools
Take and plug in a variable speed drill now when your generator is powered up slowly hit the trigger on the drill start it at low speeds run it for 30 seconds then give it half speed for 30 then full speed fo 30 seconds then try your chop saw
Nov 25, 2012 | 5.5 HP GX160 Engine
Engine stalling/ high idle
Check that the connector for the mass air flow sensor is properly connected. You will find this on the ducting from the air filter to the engine intake. failing that start looking for a hole in the vaccum system(rubber pipes around the top of the engine).
Oct 11, 2012 | Cars & Trucks
Wont stay running
Bad fuel or check for water in your fuel! Clean your carb and float bowl. Empty gas into a clear container, if there is two levels of liquid one of them is water. Of course make sure you have good spark plug.
Apr 17, 2010 | Toro Lawn Mower With Toro Power Tools
1986 el camino
Check the EGR for leaks.Here is th emost common cause of idle surges, stalls at stops, slow idle speed, erratic idle speed, rough idle and engine hesitation (and other problems), it is in most cases the idle speed control air-bypass valve and or throttle valve and upper intake, these area's get full of gunk and combustion residue over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake
Jun 22, 2017 | 1986 Chevrolet El Camino
Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series -  Sens - A - Speed Walk Behind Mower - 10685 Logo
676 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
Jim Parker
Jim Parker
lnbn1975
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
