Question about Nintendo Wii Console
My wii console will not come on and its plugged in
    President:
  • 1,382 Answers
If there is no LED on, then the most likely reason is, that your wii isn't getting power. So the problem, is with the plugs, and the power adapter. If you have a friend who has a wii, try testing his power adapter on your wii. Make sure your cords are completely plugged in, on both sides, (the outlet and the wii) then press the power button on the wii. If that do-sent work, try turning it on with one of yourwiimotes. If that dosent work, that means your wiimote is not synchronized with your wii. To sync. it, open the sd card cover on the front of the wii, press the red button above the sd card slot. Then open the bottom of your wiimote, (where the batteries are) and press the small red button that should be beside the batteries. Then hold the wiimote close to the wii,then after its done flashing, press the power button on the wiimote and also, try plugging your power cord into another outlet. If it still won't work, you've got a broken wii, so you better send it to get replaced or fixed, again as suggested. DON'T OPEN IT! You could loose your warranty if you open it, so it's safest not to. Hope you get it to work
Thank you !!
Posted on Aug 01, 2010
I just recently move my entertainment center around and plug all of including the Wii console. so when i put everything back, plug them all in the Wii console did not work... I thought i meight have...
It's very possible. If you plug in the power source for you Wii and no light comes on at the power button for the Wii, it is a problem with the power cord. If not, it may be a problem with the Wii itself. Test this out to see whether you need to get a new power cord or to have you Wii sent in for repair.
May 19, 2011 | Nintendo Wii Console
Code error 32022 what is it
Error Occurred. Press the Eject button and remove the disc. Turn the power off and follow the instructions in the console manual.
First turn the Wii console power OFF, and remove the AC adapter's AC plug from the power socket. Next, check whether the disc is dirty or scratched. If it is dirty, gently wipe with a soft cloth from the center to the outside. Wait about 5 minutes. Then plug the AC adapter's AC plug back into the power socket and turn the console power on. If the same message still appears, the Wii console may be damaged. Turn the Wii console off immediately.
Click here to download Ninento wii repair guide
Jan 05, 2011 | Nintendo Wii Console
Keep getting error message,remove disc and turn power off
Remove the AC adapter's AC plug from the plug, and visit support.nintendo.com for additional troubleshooting or call 1-800-255-3700.
Jan 04, 2011 | Nintendo Wii Console
I get an error. error has occured press the eject botton and remove the disk and than turn off consel . and refer to the wii manual.
Dec 21, 2010 | Nintendo Wii Console
Help me to put up my nintendo wii
1- Plug the video cable to both wii and T.V.
2- Plug the wii sensor in wii and place it at top of T.V.
3- Plug the power cord in both wii and electrical supply.
4- Press the power button and sync your wii remote.
Mar 13, 2010 | Nintendo Wii Console
My wii console will not turn on at all, the blue light will not come on. I have checked all plugs and cables and everything is connected. We have only had this wii console not even a year yet. what could...
it could be the power suppy mine went wrong after about 18 months, try ebay there the cheapest. you can test if its the power supply if you know someone with a wii and use there power supply or know how to use a multi meter and check if you have a voltage coming out of the wii plug end. if you dont first try replacing the fuse in the wall plug. hope this helps.
Nov 11, 2009 | Nintendo Wii Console
The electricity went off this morning...Now the Wii console power won't turn on....
Confirm the wii is plugged in (wall and wii side); if the wii is plugged into a power strip, confirm the power strip is plugged in, and that any on/off or fuse switch on the strip is set to on (may have been tripped during power surge/outage); unplug the wii for 15 minutes (seriously, 15 minutes), then plug it back in and try again.
Aug 09, 2009 | Nintendo Wii Console
It wont work
take it to a game store to get it buffed out
Aug 07, 2009 | Nintendo Mario Kart (Wii) for Wii
Hooking up the rock band to a wii console
You plug the hub into the back of the wii, and then plug the guitar (and mic) into the hub. If you just want to use the guitar, it doesn't matter if you use the hub or not. The hub is pretty much just to make life easier because there are only two ports and rock band requires at least those 2.
Jan 02, 2009 | Nintendo Wii Console
Dance mat
The only controllers that plug directly into the Wii console are GameCube controllers (and USB keyboard for messaging and Internet Channel).
Everything else plugs into the Wii Remote.
Apr 06, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
146 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
