Question about Philips DVP5982
No disc error message. on philips dvp 5982 . already tried disc cleaner but could not even read disc cleaner
SOURCE: please enter password PHILIPS DVP 3960
enter the default password "136900"
Posted on Apr 22, 2009
  • 244 Answers
SOURCE: Disc Error
Simple issue, the lead laser cannot read any data, for better result please try to check with the DVD shop.
Hope you like my solution please rate me solved.
Best regards,
Philip
Posted on Nov 17, 2007
  • 476 Answers
SOURCE: philips dvp 3020
This is usually caused by a faulty laser.
Most DVDs have two lasers. One for DVD & one for CD.
Sounds like the CD laser has failed.
Posted on Feb 16, 2008
SOURCE: philips dvp 3020 dvd player will not play, the "no disc" sighn keeps coming on.
Try this. Wait for the "no disc" sign to appear, and only after that load the dvd. The 3020 I have works alright when I use this method.
Posted on Aug 20, 2008
Edcyl1856
  • 16 Answers
SOURCE: Philips DVP 3020 says 'no
ewaltercat,;
I guess the problem was in internal., you try to open case and while operated with disc watch if the optical lens working, may also try to open region code to "0" or multi region
posible problem "NO DISC"
a. Optical Lens
b. FCC wire
c. Mpeg Board
d. Wrong Region
Regards
Clyde Acenas
Posted on Nov 06, 2008
What format of video file can the DVP-NC85H read?
AVI maybe ok. Is there anything error with your converting? I ofen use kigo video converter free to convert video. It's a free ware but works well for me.
Mar 11, 2013 | Sony DVP-NC85H Multi-disc DVD Player
I have a philips wireless music center wacs700 when i put disc s in even a lens cleaner disc it comes up cant read disc can you tell me what the problem is
lens cleaner not alway working.use air to blow unit out,,lots of dust inside of units...try to clean lazer with earbud very softly untill it shines,90% its works if not u need to replace lazer and hope its not the mpeg board...im a technician
Mar 28, 2012 | Philips Audio Players & Recorders
Can't Read Disc
You could try updating the firmware.
Jul 06, 2010 | Philips DVP5990 DVD Player
Doesn't accept md's
The manual says "C13/Disc Error: The system cannot read the disc information correctly. mEject the MD once, then insert it again."
It seems this error turns up when the system cannot read the disc properly, one reason for which is a dirty/dusty lens. Try a minidisc lens cleaner if you haven't already.
Tom
May 02, 2009 | Sony CMT-MD1 Shelf System
LG DVD player Disc Error message even when playing lens cleaners!
LG DVD Player Disc Tray opens & closes automatically & unnecesarrily
Apr 29, 2009 | LG LXD5230 System
Sony DVP-NC600 Multi-disc DVD Player No Disc Error
The only other thing I can suggest, having repaired many Sony CD/DVD players, is to get a can of compressed air and try to blow any dust out from the laser assembly. Since you've already cleaned the lens (the most common problem), you also might have dust down inside the assembly. Try blowing with the air nozzle down inside, around the gap between the lens and the cover surrounding it. Do it from at least a couple of inches away, if the air is too powerful you can damage the wiring inside the assembly.
If this fails to correct the problem, your laser output may have diminished over time and the only repair is to install a new laser assembly. The cost of this part will most likely not be worth it to you since the unit is quite old now.
Mar 02, 2009 | Sony DVP-NC600 Multi-disc DVD Player
"no disc" error message
Try unplugging the unit, then remove the cover. Take a cotton swab, wet one end with glass cleaner, and clean the lens on the laser assembly. Use the other end to dry it off and finish cleaning. Wipe very gently, do not press down hard on the lens.
This problem is usually (not always) caused by dust and smog accumulating on the lens, preventing the laser from reading the disc. Symptoms are skipping, spinning and not reading, or "no disc" errors.
Feb 28, 2009 | Sony DVP-S560D
Philips DVP 5982 DVD Player USB issues
try formating the thumb drive with a fat32 partition before using it in the dvd player
Mar 16, 2008 | Televison & Video
Wrong Region message
DVD player must be made region free by unlocking it.. after that you can play all the discs you want.. for ubnlocking it you can try google//
Jan 19, 2008 | Philips DVP-3005 DVD Player
Philips DVP5982 Logo
277 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
