Question about Yard Machines Tecumseh 148cc Front Tine Tiller #21a 251e000
The machine is making to much smoke and ia becoming to hot the engine were is the exhaust line
White smoke from BMW 740i exhaust
white were? the exhaust tip, or other spot, long pipe, name spot?
white, is steam or OIL.
oil smells like burnt oil and takes for ever to dispate
steam is water, and smells , sweet due to 50% glycol inside.
and goes away fast.
but all Gas engines make water at all the time running as a by product of combustion and for sure on cold days, some times full time cold
due to climate effects.
does your neighbors car smoke at same time, (look)
bingo , dew point.
all gas engine smoke cold started, (steam)
so first find out what it is,
take the dip stick out of a hot engine. stalled, drip it on the exhaust
see that smoke ,smell it? that is burning oil
now you know what you have, steam or oil. smoke.
Jan 18, 2014 | 2004 Suzuki Forenza
I changed the turbo now white smoke coming out of my exhaust
This seems to be a symptom of a blown head gasket.
White exhaust smoke is an indication of water / coolant in the exhaust. The car running sluggish and using lots of fuel can be caused by compression loss.
Look at the coolant level color and smell (with cold engine - don't open the high pressure reservoir with engine hot as hot coolant may spray you in the face). If you have a blown gasket, the coolant color may become brownish and it may smell bad or the level will get lower even if you have just refilled the cooling system.
What you can also check for is bubbles in the reservoir. With engine cold, remove the reservoir cap. Start the engine. Try to rev the engine (or have someone do it) and observe if there are bubbles in the reservoir tank. If you see lots of bubbles, you have a blown gasket.
Dec 05, 2013 | 2001 Oldsmobile Intrigue
Filled up with gas started cutting back and smoke from back of engine
not sure what you are describing really, is it possible you can elaborate? After you filled up this happened? The engine started cutting back? Did you put diesel instead of gas? A common mistake! This will make the vehicle putt putt if it even starts and will have no power what-so-ever! Will just sit there and putt putt. A plugged catalytic converter will get red hot and sometimes hiss if there is any leak you your exhaust and the car will overheat and have a loss of power and the hotter it gets the more the power loss will be until it overheats the head and warps it or blows a head-gasket.
If that is smoke from a fuel leak then this is dangerous of explosion.
If you had a service guy check your oil when you filled up, he left the oil filler cap off and it's spraying all over the exhaust and engine and again dangerous of fire. You must carefully determine what is leaking to cause this smoke, it's either an exhaust leak, an antifreeze (coolant) leak or from the power steering or transmission line or brake line. One thing to find a small leak is to place a piece of cardboard under the engine to see what and where anything is dripping.
Nov 26, 2013 | 1999 Kia Sportage
My car is jerking. It's a 2003 ford tarus. It also
Open the hood and find the source of the smoking. Check all the engine fluids-the oil level (and appearance-is it clean?) and the coolant level. If low on either, you may have a leak that is causing the smoking. The fluid may be dripping on the hot exhaust. Also check the transmission fluid and add if low. That may be the reason for the jerking. The hissing hose sound is usually a disconnected or broken vacuum line. That would not be causing the smoking, however. Just may make the engine run a bit rough, and the idle speed may be a bit higher than normal.
If the smoking has a burnt electrical smell, better have a shop check it out.
Aug 27, 2013 | Cars & Trucks
Hot Exhaust, Bogging, and Flashing Check Engine light, diagnostics plug wont allow reading
yes the cat can be installed backwards especially if it is a universal fit style part
take the cat off and run the engine without it next
Jun 30, 2012 | 1999 Chevrolet Blazer
What cause my 2000 lexus es 300 exhaust manifold to get hot
The exhaust manifold is going to get hot, this is where the engines exhaust flows through. these tempertures reach high temps,
If the manifold is glowing hot then theres a problem.
Sometimes people say the manifolds are getting to hot because they see them smoking. The reason on most of these cases is due to a leak, aleak from a bad gasket like a valve cover gasket. Engine oil leaks down on to the exhaust manifold causing smoke. make sure there are no leaks .
A few reasons that would cause exhaust manifold to heat up more than normal would be a engine thats running rich, this may be due to a leaking injector or a poor running engine. Another reason may be that you have a plugged cat. converter.
The Exhaust manifolds can reach about 600 degrees, the last thing is people hear the metal expand or contract and think there are getting to hot , this is normal.
Please let me know if there is something else i can help you with. thank you and have a good day.
Mar 18, 2012 | 1993 Lexus Ls 400
When starting my mower a lot of white smoke comes from the left side and becomes very hot thank you
You most likely have either too much oil in the engine, have tilted the machine the wrong way, or have an issue with some water in the gas. Check the oil level. Make sure it is normal and doesn't look like a chocolate milkshake. If it is dirty, change it. Drain your old fuel, and add fresh fuel. Don't run it for any length of time with it smoking that way. If the machine was tilted the wrong way, some of the oil may drain back where it needs to be, but the rest will be ingested into the carburetor and intake of the engine creating smoke.
Apr 13, 2011 | Husqvarna Garden
How do you get to the oil filter
Hello there,
The oil filter is behind the engine, on the passenger side, right above the braided steel exhaust line..use a deflector when removing the oil filter, as engineers did not care that the oil filter leaks onto the exhaust, and makes smoke long after the oil change...it is real easy to get to...a simple piece of cardboard on the pipe will prevent smoke...use it on a cool exhaust, not hot, or the paper will burn...if the engine is hot, use a piece of aluminum foil..it works great.
Good luck!!
Jan 28, 2011 | 1997 Pontiac Sunfire
Runs hot, smoking and water coming from exhaust. 5 month old battery run down . Think it may be head gasket but not sure. What do you think ??
before you change anything check you're throttle body it may be crack and water goes in to the engine from there ,disconnect the water line and run you're engine,if the smoke stop you found the problem.
Aug 27, 2010 | 1999 Mercury Sable
Smoke comes from around engine
Probably a vavle cover gasket leak, small but enought to produce oil, in or on the surface of the motor doesnt take much to a lil smoke from aa hot engine...it could be collectiing in the canals ontop of the motor where the vlave covers sit on the head? or a head gasket problem....inspect it well after you run the car for a lil while, b4 it starts to smoke
May 18, 2009 | 1986 Oldsmobile Cutlass Supreme
Yard Machines Tecumseh 148cc Front Tine Tiller #21a 251e000 Logo
19 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
