Question about Briggs & Stratton Prosumer 20324 Gas Pressure Washer
Motor starts fine but only runs about 2-3 minutes than stumbles and shuts down.
  • 700 Answers
Insufficient fuel supply,
drain all fuel, disconnect and clean/replace fuel line and fuel filter.
check fuel valve for blockage and clean
check as well tank for presence of rust, if any, clean it out as well.
if this did do not help, you have some problem with carby, it need cleaning then as well, especially fuel chamber. start motor adn while it is runnig use special carby cleaning aerosol. do not overdue and never spray it on non-running carby!
if you find my advice helpful, please do not hesitate to leave comment and give me your vote4, thanx!
Posted on Aug 01, 2010
98 lincoln town car starts/runs cold,fine for 10-15 miles but once hot , it stumbles & shuts off, It wont respond to anything until is cool again then it starts right up. No codes, PATS is ok,
Something electrical is breaking , shorting when hot ! Crankshaft position sensor , or some other sensor ! Next time it shuts off pull a coil off an see if it has spark ! If there is spark check fuel pressure ! If it has spark an fuel check for a computer pluse , 5 volt reference voltage circuit ! Do you know what that is ? Making Sense out of Sensors
Feb 25, 2017 | Lincoln Cars & Trucks
IT WILL STaRT , RUN FOR 1 MINute AND SHUT OFF BUT WAS rUNNING WITH COVER OFF BUT NOW HAS STOPPED THAT IT WILL RUN FOR 20 SEcONDS AND SHUT OFF
What would cause 1995 Chevy blazer to run for 20 minutes ...
answers.angieslist.com > Auto > Auto Repair & Service
Mar 30, 2014 - For example, can you start the car cold, it will warm for 20 minutes, and shut ... While not a car, my Motorcycle (also fuel injected) would run for a little bit and shut off. The issue ... Answered 1 year ago by WoWHomeSolutions.
Car starts and it shuts off/loses power - CarGurus
www.cargurus.com > Questions > Audi > A4
CarGurusJun 20, 2013 - Car starts and it shuts off/loses power - I have a 2003 Audi A4 Turbo.93K on it. ... \n check out these few options 1. loose or faulty electrical connections at, .... After drying it for a few minutes and cleaning with a dry cotton cloth, I have ... you can't fill your car while its running the gas tank is a vacum while its ...
Car starts then dies in a few seconds - CarGurus
www.cargurus.com > Questions > Ford > Crown Victoria
CarGurusFeb 3, 2014 - Car was running fine, and then engine stops. ... 1 out of 1 people think this is helpful. ... my car will start run for a second an shut off . ... under load, dies,starts 15 minutes later, runs fine then stumbles and dies again 3 answers.
Chevrolet Silverado 1500 Questions - Engine Shutting off ...
www.cargurus.com > Questions > Chevrolet > Silverado 1500
CarGurusMay 20, 2015 - Engine Shutting off after about 10-20 seconds on 2004 Silverado ...When the engine is hot, two things occur: (1) thermal effect on .... my 2000 chevy silverado just randomly die then it will start back up idle .... It will run fine for 15minutes. ... run down behind or beside the powersteering pump, that the car will ...
Jan 06, 2016 | Cars & Trucks
My vehicles shuts off after 3 three minutes of use or when its idling after first initial start but starts perfect when the engine is heated up. Can you help me with this problem?
CarGurusFeb 3, 2014 - Engine turns over fine and starts, but stops in a second or 2. ... Good fuel pressure, starts, runs for about 7 seconds, dies after a sudden drop in fuel pressure. ...starts 15 minutes later, runs fine then stumbles and dies again 3 answers ... I drove carhome shut off and next morning would not start, but will turn ...
94 camry le 4cylinder starts when cold, shuts off .
Nov 23, 2015 | Cars & Trucks
My Simpson Water Shotgun shuts down about a minute into the wash
Have you checked the oil level? Some engines have a sensor that shuts it down if the oil is too low
Jul 16, 2009 | Simpson PS2600 PowerShot Commercial-Duty...
1999 4.0L Jeep Grand Cherokee shuts down after 20-30 minutes.
I'd suggest the ignition control module, however I'd have a certified mechanic check it out just in case...
Feb 01, 2009 | 1991 Jeep Cherokee Briarwood
Briggs & Stratton Prosumer 20324 Gas Pressure Washer Logo
191 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
