Question about Kenmore Oasis HE 27082 Top Load Washer
Washer makes a lot of noise and has code of HC on it
  • 15,935 Answers
This HC error code will appear at the end of the wash cycle to indicate that the hot and cold water inlet hoses are switched. If the hoses are not switched it could indicate a problem with the Electronic Control Board. You can try to rest the washer by unplugging or flipping the breaker to the washer fo 2-5 min. Restore power to the washer and try running a short cycle. This will help clear any irregularities that the control board may have encountered.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!@#$
Posted on Sep 27, 2010
HC code shows up after washing cycle is over
HC flashes when the hot and cold inlet hoses are reversed.
Make sure inlet hoses are connected correctly.
http://www.advantagesupplyfl.com/WhirlpoolCabrioWasherFaultCodes.html
Aug 25, 2014 | Whirlpool WTW8200YW 4.6 cu. ft. Cabrio...
The washing machine makes a lot thumping noise during the drying cycle. Sounds like it is bout to take off. A lot of rubbing during the wash cycle
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Dec 12, 2010 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
My cabrio washer shows a code HC...what does this mean?
HC will flash when the hot and cold inlet hoses are reversed. Make sure your inlet hoses are connected correctly. That should correct the issue.
Jun 29, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Makes a lot of noise when spinning, could be
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 31, 2010 | Candy CBL166 Front Load Washer
My washer shows a HC in the panel. what does that
HC means that the Hot and Cold water lines are reversed. Make sure that the supply hoses are connected correctly. If they are, then there is a problem with the sensor or control board.
Apr 28, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Why is my kenmore elite (top loader) oasis washer HE is displaying a code of HC
The water inlet hoses are probably removed and reconnected in reverse, and then trigger the HC error code to flash indicating the hot and cold water inlet hoses are reversed. Reconnect the water inlet hoses properly and start a cycle then let us know what happens next.
Apr 18, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
What does HC stand for?
According to the Whirlpool "Cabrio" washer installation and maintenance manual, (Cabrio is the Sears Oasis) the HC code will come up when.
“HC” (Cold and Hot hoses switched)
This code will appear at the end of the wash
cycle to indicate that the cold and hot water
inlet hoses are switched. If an error code
does not appear, but you are experiencing
poor washing performance, check to see
whether the inlet hoses are reversed. See
“Connect the Inlet Hoses.”
Sep 24, 2009 | Kenmore Oasis HE 27082 Top Load Washer
What is the HC code for the washer . It comes on after the wash cycle is finished.
After replacing the part to fix the F1 code, the washer (Oasis he) now comes up with a HC code. Also, even though the cycle is set for warm/cold, the clothes are coming out hot at the end of the cycle...and the cold water is hooked up and on. Any suggestions?
Sep 08, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Error code HC
I recently started getting this message as well. I found out that I accidentally switched the hot and cold water lines into the washer. After switching so hot goes to hot and cold goes to cold the 'hc' message has stopped.
Apr 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore washer has a error code of hc
You need to switch over your hot and cold water lines. 'HC' means that your hot and cold are hooked up to the wrong inlets.
Mar 30, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
