Question about Gear Head WC535I Webcam
I can't locate the drivers; brand new device but packaged drivers out of date. Please ssist. RAP
  • 702 Answers
Have you tried using a driver finder program?
Posted on Jul 31, 2010
    President:
  • 2,571 Answers
2002 Cadillac escalade driver side windows don't work but passenger windows do work. The drive side ones quit all of the sudden and also my radio doesn't turn off what is my problem? And how do I fix it?
Right side of the vehicle has a different power supply then left side . Two relay's . RAP #1 & RAP #2 . The RAP #1 relay supply's power to the radio an driver side power windows . I think maybe you have two different problems . The radio not turning off, maybe caused by the RAP relay having stuck contacts . Driver side windows not working , could have broken wire inside the flex boot from the body to the driver door .
Rap relay #1 is located in the left instrument panel fuse box .
Fuse Block -Left I/P
On the lower left side of the I/P
The RAP #1 relay is turned on by the BCM - body control module . Could have a DTC - diagnostic trouble code stored .
Do you know how to test automotive electrical circuit's use a wiring diagram an a DMM - digital multi-meter ? Pull the driver door panel off an check power an ground circuit's for the driver window switch . Free wiring diagrams here
http://www.bbbind.com/free_tsb.html Enter vehicle info. Year , Make , Model an engine . Under system click on body & accessories , then under subsystem click on power windows . Click the search button then the blue link .
The Trainer 24 Power Window Troubleshooting
Good luck !
Jan 13, 2018 | Cadillac Cars & Trucks
Tip
How to Reload Sound Drivers
Instructional steps
  1. 1 Download the installation package for your sound driver from your sound card's manufacturer to a location on your hard drive, such as your desktop. Locate the installation package on your hard drive if you already have the file on your computer.
  2. Open the Windows "Start" menu and click "Run" to open the Run dialog. In Windows Vista and 7, locate the "Run" option by selecting "All Programs" in the "Start" menu and opening the "Accessories" folder.
  3. Type "devmgmt.msc" (without quotations) into the Run dialog. Press "Enter" or click "OK" to open the Device Manager. Click "View" and select "Devices by Type" to arrange the installed devices by their type. Double-click "Sound, Video and Game Controllers." Locate the name of your sound card from the list of installed sound devices and double-click it to open the properties dialog for the device.
  4. Click the "Driver" tab in the properties pane to view the device's driver options. Click "Uninstall" to remove the current driver installation. This step prevents possible conflicts when you reload sound drivers on your computer.
  5. Close the Device Manager after the process of uninstalling the sound driver is complete. Navigate to the location on your hard drive where you saved or stored the installation package for your sound card. Double-click the installation file. The installation package will automatically install the driver again. After the installation process, restart your computer if directed to do so.
on Oct 09, 2010 | Computers & Internet
Where is the RAP Retained Aux Power module/relay located in a 2005 Corvette C6? Where can I find a wiring diagram and how would I check RAP status with a TechII???
Serial Data Control of Retained Accessory Power (RAP)
Retained accessory power (RAP) is a vehicle power mode that permits the operation of selected customer convenience items after the ignition switch is turned OFF. These selected items will remain in operation until a passenger compartment door is opened or until the RAP function timer reaches its shut-off limit.
The class 2 RAP power mode is mapped to GMLAN serial data circuit as Off power mode. Refer to Data Link Communications Description and Operation for more information on data link communications. The body control module (BCM) monitors the ignition mode signal from the ignition mode switch, battery condition and the doors status to determine whether RAP should be initiated. The modules that support the RAP power mode will operate the systems under their control as required by their RAP power mode strategy.
RAP will end when one of the following conditions is met:
• The BCM detects the opening of a passenger compartment door.
• The RAP timer expires.
• The battery capacity decreases below a prescribed limit.
• Any other ignition switch state is chosen.
The functions supported in the RAP power mode are:
• The power windows
• The instrument panel cluster (IPC) and driver information center (DIC) displays
• The entertainment devices
Retained Accessory Power (RAP) On After Timeout
Step
Action
Yes
No
Schematic Reference: Data Link Connector Schematics
Connector End View Reference: Master Electrical Component List in Wiring Systems
Did you perform the Diagnostic System Check - Vehicle?
Go to Step 2
Go to Diagnostic System Check - Vehicle in Vehicle DTC Information
On the scan tool select Data Link Tests under Computer/Integrating Systems, and then Class 2 Power Mode.
Close all the doors.
Turn ON the ignition, with the engine OFF.
Wait 5 seconds, then turn the ignition OFF.
Wait approximately 10 minutes.
Did the scan tool display the RAP power mode and after 10 minutes the OFF-Awake power mode?
Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
Go to Step 3
With the scan tool observe the driver and passenger door ajar switches.
Open and close each door.
Does the scan tool display change from Door Ajar to Door Closed?
Go to Step 4
Go to Symptoms - Doors in Doors
With the scan tool observe the driver and passenger door open switches.
Does the scan tool display change from Door Open to Door Closed?
Go to Step 5
5
Replace the body control module (BCM). Refer to Control Module References for replacement, setup, and programming.
Did you complete the replacement?
Go to Step 6
6
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 1
Aug 25, 2017 | Cars & Trucks
Where is the rap locate
The Recognition and Prevention (RAP) Program is a research program providing assessment and services for adolescents and young adults in the New York City and Long Island areas. The RAP Program is located on the campus of The Zucker Hillside Hospital which is part of the North Shore-LIJ Health System. The RAP Program offices are in Glen Oaks, NY which is on the border of Queens and Nassau Counties.
To speak to a RAP team member, CALL # 718-470-8115.
The Recognition and Prevention (RAP) Program The Zucker Hillside Hospital Department of Psychiatry Research Behavioral Health Pavilion 75-59 263rd Street Glen Oaks, NY 11004
Driving Directions:
From the Grand Central Parkway/Northern State:
Take to exit 25 South (Lakeville Road). Drive South on Lakeville past three traffic lights. At the fourth traffic light, turn right onto Union Turnpike. Proceed on Union Turnpike to 263rd St. and turn right onto 263rd St. Continue to 74th Avenue. Turn right onto 74th Avenue and continue to the Ambulatory Care Pavilion. Free parking is available with the valet. A RAP program representative will meet you at the Ambulatory Care Pavilion and escort you to our offices in Psychiatry Research in the lower level of the Behavioral Health Pavilion.
Public Transportation:
The RAP Program is accessible by the Q46 bus line - exit at Union Turnpike and 263rd Street. The nearest LIRR stop is New Hyde Park with taxi service available to travel from the train station to the RAP offices.
May 27, 2016 | 2003 Ford Ranger
No sound on HP Compaq DX2450 AM have tried all realtek hd audio drivers none have worked
Open up device manager, Click on the Unknown Devices, Click on Properties, Click on Details, in Details, Change Property to Hardware Ids, then Copy code, put it into Google and it should bring you to a page, if that Fails, then Download Diver Pack Solution, v14.5 Via Torrent or by the Lite install program and let it download the full package. To install the correct/up-to-date drivers.
Aug 19, 2014 | HP Compaq DX2450 PC Desktop
How can i install again the reatek high definition audio device because i've unstalled it accidentally?
I would start here: http://www.driverstorer.com/help.html
Use speccy to determine the exact Realtek device, then find the latest device driver download here:http://www.driverstorer.com/help.html
May 23, 2011 | Dell Inspiron Mini 1012 Netbook...
I have a nokia 5130c there is problm camra on stand by please help me
Tools & Materials required  :
  1. Mxkey Dongle with latest software installed
  2. UFS / JAF Box
  3. Nokia 5130c Fbus cable
  4. CA-101 Usb data Cable
Step By Step :
  • Backup RPL & PM
  1. Open Mxkey Software
  2. Select UFS / JAF as Interface, then connect it.
  3. Pick Nokia Module
  4. Pick BB5 Tab
  5. Pick Service Tab
  6. Connect Phone to UFS / JAF box using Nokia 5130c Fbus Cable
  7. Click on " backup RPL "
  8. Save to safe location.
  9. Pick PM Tab, read full, save to safe location.
  • Flashing / Firmware Updating via CA-101 Usb data cable
  2. Select Nokia Usb Rom as Interface
  4. Pick BB5 Tab
  5. On flashng Tab, Pick Nokia 5130c Latest Firmware Package Properly.
  6. Click on " Flash " Tab
  7. Connect Phone to PC via CA-101 Usb data cable.
  8. Wait Until All Process done
Here's the log operations :
Reading phone`s ID ...
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
productData saved.
Restarting phone ...
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 24E0000D70D27D5657572DFFD11A84578F44242B
ASIC MODE ID: 00
 SecondaryBoot: rap3gv3_2nd.fg [BB5]  version: 9.11.1 revision: 0.0 size: 0x3C00
 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982  - 0000 8A31 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM]  version: 9.50.0 revision: 0.0 size: 0x23010
 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0
TransmissionMode: DDR&TX2
Reading RAP NPC (0x168 bytes).
Reading RAP VARIANT (0x0 bytes).
Reading RAP CCC (0x160 bytes).
Reading RAP HWC (0xD4 bytes).
Flash Imei: 35422303116811
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
SIMLOCK_DATA saved OK
SIMLOCK_KEY_DATA saved OK
SUPERDONGLE_KEY_DATA saved OK
CMLA_KEY_DATA saved OK
WMDRM_PD_DATA saved OK
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
LOCK120_DATA saved OK
BB_DATA saved OK
RPL saved to "C:mobileEx.4dataackupRPLBB5_35xxxxxxxxx_BACK.rpl"
Library version: 1.0.0.8955(29-09-2010), 1.0.0.14639(29-09-2010)
Processing file: rm495__07.97.mcusw as MCU
 [BB5,BB5 ALGORITHM]  size: 18.20 MB
 Supported RAP Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable,Battery back to device.
Insert Charger or Press phone's power button
Waiting for USB device ...
[ADL] Pooling for ADL device
[ADL] Device found: nmwcdnsucNokia USB Flashing Generic, ID: 1FB998E3
RAP SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
RAP EM0 ID: 00000296
RAP EM1 ID: 00000B22
RAP PUBLIC ID: 24E0000D70D27D5657572DFFD11A84578F44242B
RAP ASIC MODE ID: 00
RAP ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
RAP ROM ID: 273F6D55DFAAF68F
[ADL] Flashing CMT Update Server Data, ULO: 0x3900 bytes
[ADL] Update Server code succesfully sent to phone.
[ADL] Flashing CMT Update Server Data, UPDAPP: 0x4B340 bytes
[ADL] Flashing CMT Update Server Data, PASUBTOC: 0x59940 bytes
[ADL] Device found: nmwcdnsucNokia BB5 ADL Loader USB Generic, ID: 8572D57
[ADL] Verifying communication to device OK.
Erase size: 21.00 MB
CMT NOR area [00000000-000006BF] erased in 0.500 s
CMT NOR area [000006C0-0001FFFF] erased in 0.515 s
CMT NOR area [00040000-000BFFFF] erased in 2.172 s
CMT NOR area [000C0000-0013FFFF] erased in 2.094 s
CMT NOR area [00140000-0137FFFF] erased in 1 min 17.812 s
CMT NOR area [01380000-0151FFFF] erased in 6.954 s
Flash programming ...
CMT PAPUBKEYS: 0C917F11196FDB7378C18EF7260698CA4489DCA0 (RAP Certificate 164 v.1) written.
Programming completed in 1 min 5.172 s
Processing file: rm495__07.97.ppm_x as PPM
 [BB5,BB5 ALGORITHM]  size: 7.72 MB
Erase size: 8.62 MB
CMT NOR area [01520000-01DBFFFF] erased in 37.188 s
Programming completed in 26.469 s
Processing file: rm495__07.97.image_x_red as CNT
 [BB5,BB5 ALGORITHM] page size: 128 K size: 12.89 MB
Erase size: 34.00 MB
CMT NOR area [01DC0000-0215FFFF] erased in 22.829 s
CMT NOR area [02160000-03FBFFFF] erased in 3 min 12.922 s
Programming completed in 45.125 s
[ADL] Restarting phone ...
[ADL] Device found: nmwcdcNokia 5130 XPressMusic USB Generic, ID: 1878DB02
Flashing completed in 9 min 5.000 s
Phone Type: RM-495 (Nokia 5130c-2)
SW Version: V 07.97 13-09-10 RM-495 (c) Nokia
Imei plain: 3542xxxxxxxxxxx
Product Code: 0578115
Language Pack:
- not available.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
SUPERDONGLE_KEY seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 354xxxxxxxxxxx
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Total time to process is 9 min 8.922 s
Jan 24, 2011 | Nokia 5130 Cellular Phone
I cannot get the high end to stop cracling i got this cam for the porpose of doin live vedio feed.. i do webcast rap battles on my website and it crackles and pops no matter hwat i do to resolve it
Call the manufacturer tomorrow.
That means, even if you're young and speedy and whatever, calm yourself down, get ready for the ride, speak kindly to everyone you talk to on the phone, and NEVER GIVE UP UNTIL THEY GUIDE YOU TO THE ANSWER OR SEND YOU A BRAND NEW UNIT.
Sep 30, 2010 | Logitech QuickCam Pro 9000 Web Cam
Sunroof will not work
Power is supplied to the Power windows and sunroof through the power window circuit breaker. That circuit breaker is supplied power through the RAP (retained accessory power) Relay, the RAP relay also supplies power to the radio. The RAP relay is also fuse protected by the RAP fuse in the under hood fuse block. The RAP relay is energized by the BCM body control module.
The RAP relay is responsible for the radio and windows working after the igntion is turned off.
The first place to check would be the RAP fuse in the under hood fuse block and then the RAP relay in the Body fuse block.
A list of the BODY relay block located on the left side of the dash to the right of the interior fuse block is below:
(1) Park Lamp Relay (2) Courtesy Lamp Relay (3) Retained Accessory Power (RAP) Relay (4) Power Seats Circuit Breaker (5) Power Windows Circuit Breaker (6) Inadvertent Power Relay (7) Door Lock Relay (8) Headlamp Ground Relay (9) Driver Door Unlock Relay (10) Door Unlock Relay(1) Park Lamp Relay
(7) Door Lock Relay
(1) Park Lamp Relay (2) Courtesy Lamp Relay (3) Retained Accessory Power (RAP) Relay (4) Power Seats Circuit Breaker (5) Power Windows Circuit Breaker (6) Inadvertent Power Relay (7) Door Lock Relay (8) Headlamp Ground Relay (9) Driver Door Unlock Relay (10) Door Unlock Relay (1) Park Lamp Relay (2) Courtesy Lamp Relay (3) Retained Accessory Power (RAP) Relay (4) Power Seats Circuit Breaker (5) Power Windows Circuit Breaker (6) Inadvertent Power Relay (7) Door Lock Relay (8) Headlamp Ground Relay (9) Driver Door Unlock Relay (10) Door Unlock Relay
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jul 10, 2010 | 2000 Chevrolet Blazer
Gear Head WC535I Webcam Logo
455 people viewed this question
Top Gear Head Computers & Internet Experts
micky dee
Laxman Bisht
Laxman Bisht
Are you a Gear Head Computer and Internet Expert? Answer questions, earn points and help others
