Question about Bushnell BANNER RIFLE SCOPEPower: 3-9X40 / Reticle: Green/Red Illuminated
What are the adjustment knobs on the windage position for? Is it to adjust sighting or to focus the scope? Why are they not covered like most scopes are
  • 2,100 Answers
The adj knobs on there are for windage on the right and elevation on the top, if they are not covered, they are turret knobs for target shooting, not for hunting. The focus knob is the rear lens, it spins in and out to fit your eyesight. It usually focus on the crosshairs and the distance for most shooters, some will not be able to get it right because of their eyes. 98% will. Hope this helps.
Posted on Aug 04, 2010
I have a Simmons Model ATV 4515 rifle scope. other
Your scope has 5 adjustments:
1. Eye piece focus - used to focus on the reticle.
2. windage adjustment - should be on the R side of the scope, adjusts lateral impact point.
3. Vertical adjustment - the top turret. Adjusts vertical point of impact.
4. Power ring - adjusts the magnification of the scope.
5. AO ring - Parralax adjustment - used to focus the scope at specific distances. Most markings are not exact, you should set it at the range you are shooting and fine tune focus when you look through the scope.
Sep 06, 2013 | Optics
I'm sure this will sound stupid, I just bought a rifle with a Tasco red dot scope on it and have no idea how to activate the scope. Any help would greatly be appreciated. Thanks
No, that doesn't sound stupid. It's always a good idea to get all the information before using firearms and their accessories, and I'm happy to help:
The large knob on top of the scope is the rheostat, which is used to turn on the red dot, and adjust the brightness. It can be adjusted from "1" (dimmest) to "11" (brightest). You'll have to be looking straight down the scope to see the red dot, since it is only visible when you're aiming. If you turn on the scope to the brightest setting, and you look through like you are aiming, and the red dot is still not there (or very dim) then you probably need to replace the battery. It uses a 3 Volt coin-style lithium battery, type 2032. Unscrew the battery compartment on top of the rheostat and put the new battery "+" side up. Then replace the battery cover, and you should be good to go. Turn off the scope when you're done to save the batteries.
Since you bought the rifle with the scope already installed, it's probably already sighted in, or pretty close to being sighted in. Adjusting the windage and elevation on the red dot scope works just like other rifle scopes. The knob on top moves the point of impact up/down, and the knob on the side moves left/right. For this model, each click of adjustment moves the point fo impact by 1/2" at 100 yds, 1/4" at 50 yds, or 1/8" at 25 yds.
Be safe, and have fun!
Jan 24, 2011 | Tasco 1x30 Red Dot Sight BKRD3022
Haveing problem with the windage adjust and elavation adjustment it is working backwards.
If your point of impact needs to move up, turn the knob the direction that says up. If it needs to move left, turn the windage knob the direction that says left.
Jan 21, 2011 | Optics
How do i sight this scope in, say for 100 yds what are all the sighting knobs for...?
You sight it in by firing at a target. Place the target at 100 yds distance if that is where you want it set for. Then you use the knobs to adjust the aiming point so the bullets strike where you place the crosshairs. This can involve a lot of shooting, and it is best to use a bench so you don't get confused by inaccurate handheld shots. Once sighted in, there may be other knobs to adjust for different distances or windage. These should be set to a central or neutral position while doing the initial siting, or maybe set to the distance you are siting in. My sights don't have such luxuries, so I am not sure how they work.
Oct 20, 2010 | Barska Optics BARSKA 156X42 IR Huntmaster...
Cannot get to the bull's eye. rifle shoots 2" to right of bull's eye. after two full turns left on windage - nothing happened. I',m ready to return to the store. Any help???
continue to adjust the wind-age. If your problem persists I would suggest turning both to a random point and re-start sighting the gun. If that does not fix the problem return the sight because this most likely means the wind-age is disconnected.
Aug 17, 2010 | Bushnell .22 Rimfire 3-9x32 Rifle Scope...
I have an older Bausch and Lomb scope and have lost one of the screw on covers for the windage adjustment. where can i find a replacement
I have seen covers in the Midway catalog and Brownells, both have replacement covers and turret knobs. Hope this helps.
May 12, 2010 | Bausch and Lomb Bausch & Lomb Hunting...
Windage fully clockwise "In" and not quite there at 100 yds.
remount the scope using millett angle lock rings that allow you to adjust for windage. bring the scope as close to hitting bulls eye as possible then use the scopes adjustments for the fine tuning. before remounting you will want to recenter the reticule.
Mar 14, 2010 | Bushnell ® Elite® 3200 3 - 9x40 mm...
The reticle adjustment knob is turned all the way out (counter clockwise) and still hasn't moved the point of impact to the right enough.
If you have Leupold/redfield style windage adjustable baes you just need to move the windage adjustments. If you don't have these, I would recommend you take your rifle to a qualified gunsmith and have him remount and boresight your scope with this style scope base(s) which should run you about $80.00
hope this helps, Mark the Gunsmith
Oct 22, 2009 | Optics
Windage and elevation adjustment all over the place
Sounds like you want to "re-sight" in your rifle. Make sure mounts are okay and tight. Look down barrel and then thru scope and eyeball windage and elevation adjustments so the scope seems to be fairly in line.
Clean barrel if it needs it.
For basic sight in, start at 25 yards with a large(3 to 4 feet) cardboard or wood backdrop around target (bullseye). Fire at target. Once done, look through scope and position rifle such that the shot mark you created is dead zero. Hold rifle very steady and you or buddy move windage and elevation adjustments until scope moves dead zero back toward original target (bullseye). Fine tune from there. Air cool rifle between rounds. Once dead eye, fire another round or two to check grouping. Check your ballistics (sometimes on ammo box) to see how height at 25 yards affects your desired dead on target (100 yards, 150 yards, 250 yards etc.). Adjust accordingly. Example: you may need to sight in at an inch high at 25 yards, depending on your dead on target distance..
Always remove sling from barrel when sighting in.
Try to sight in at similar temperature as you intended shooting temperatures, if possible.
If not black powder, avoid cleaning barrel between sight in and hunt/competition unless you note bad buildup inside.
If you change ammo, understand that that may affect performance. Once a preferred ammo is found, some even try to buy a decent quantity with the same lot number on the boxes if storage allows for such.
May 02, 2009 | Optics
Zeroing scope adjustment
First, adjust wind-age and elevation to center or zero position. Remove your scope from the gun and make sure that the scope mounts are aligned, this is critical. Purchase an alignment tool is necessary. Then remount the scope. The scope should seat in the mounts without binding. If it does bind, the mounts are not aligned.
Start sighting in at close range,10 to 30 yards, then move out to 100 yards.
Jan 03, 2009 | Tasco 3-9x40 World Class Riflescope 30/30...
Bushnell BANNER RIFLE SCOPEPower: 3-9X40 / Reticle: Green/Red Illuminated Logo
292 people viewed this question
Top Bushnell Optics Experts
Marvin
Marvin
George Merkley
George Merkley
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
