Question about Whirlpool LER4634PQ Electric Dryer
Dryer dose not get hot whirlpool model ler4634pq0
Benimur
  • 6966 Answers
SOURCE: Whirlpool Dryer Model#GEQ9800LW0 will not get hot
Hi and welcome to FixYa,
If I may add with the indulgence of trystakarm, other components that may and can cause this fault could be:
  • thermal fuse, once off would have to be replaced;
  • thermal cutoff, automatically resets itself when temp goes down;
  • relay, that actually does the switching on/off of the heater element;
  • logic controller board, that controls the relay based on triggers from other sensors.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 11, 2008
  • 659 Answers
SOURCE: whirlpool dryer not blowing hot air
The element is at the bottom of the unit. Usually they are located on the right bottom but when you take the housing off, you will be able to see it.
Posted on Apr 11, 2009
breddi2
  • 126 Answers
SOURCE: Elkectric dryer won't start
to put it kindly depending on way you connected wires unit could be damaged,replace pigtail with three wire and outlet to original.outlet wires should be black,red and white. turn breaker off attach white to middle and red,black to sides,"either side is fine".Attach dryer pigtail in same manner with white on white and if plug in and turn breaker on.If there is no operation at this point dryer possibly damaged from previous wiring.Just remember be safe when working with electrical and ask before trying to change things that aren't the same.
Posted on Apr 20, 2009
  • 512 Answers
SOURCE: whirlpool dryer model number lgr7648kq1 won't get
Sounds like one of the cavity switches is bad. Open back of dryer, you will see wires that attach to little clip next to each other. Try jumping wire from one side to the other, do one switch at a time and try dryer to see if heats, if you get heat replace that switch. These switches burn out if dryer gets to hot, usually from to much lint in duct work. Also vacuum out duct work in wall and on back of dryer.
Posted on Jun 14, 2009
  • 1531 Answers
SOURCE: Whirlpool electric dryer LER4634PQ0 blows
There is a chance that the heating element is grounding out on the cabinet it may even be intact but still grounding out on the cabinet or element can.you will nee to check all the wiring harness and make sure there is not wire that are fused to gether causing a direct short.
Posted on Dec 21, 2010
NEED WIRING DIAGRAM FOR LER4634PQ0
YOU MAY WANT TO TALK TO WHIRLPOOL. PRITORITY PART
Dec 09, 2015 | Whirlpool Dryers
How do I access the lint trap of a Whirlpool model LER4634PQ0 dryer? A water hose nozzle fell into the lint trap. PLEASE HELP!
Pull the dryer away from the wall, disconnect it electrically and remove the vent hose (4" diameter hose clamp) and fish out the components that have made their way down the wrong location
May 20, 2014 | Dryers
Whirlpool LER4634PQ
This is what I believe to be your problem, but as always, check your breakler first to make sure it hasn't tripped.
http://www.partselect.com/PS345113-Whirlpool-3392519-Thermal-Fuse.htm?SourceCode=1&SearchTerm=LER4634PQ0&ModelNum=LER4634PQ0
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Sep 05, 2012 | Dryers
I have a whirlpool model# Ler4634pq0 electric dryer. Heats ok, takes 3 cycles to dry clothes. Cleaned vent hose, cleaned internal duct system, cleaned lent screen, and holes inside drum. Any ideas?
If you 've done all of that and it still doesn't dry properly, you may have a faulty limit switch. These limits switches are usually down by the burner assembly and not much bigger than a quarter with generally 2 wires going to them. Very easy to replace once you find it. Unplug the dryer before you work on it.
Apr 12, 2011 | Whirlpool Dryers
I have a Whirlpool electric dryer Model #LER4634PQ0 and for the life of me cannot figure out what heating element that I need to buy for it. Please help before I lose my mind.
Call your parts house and give them the model number. They can tell you exactly which one to buy. Are you sure its the heating element? I ask because there are several things that can prevent it from heating. I dont want you to waste money changing parts.
Jun 24, 2010 | Dryers
How do I put a heating element in a dryer?
there are a few differant styles, give me your model number and i will see which one you have.
why do you think it needs an element? if its not getting hot you may have a cheaper and quicker repair than an element
Dec 10, 2009 | Whirlpool LER4634J Electric Dryer
Apr 20, 2009 | Whirlpool LER5636P Electric Dryer
LER4634PQ0
no put a ohm meter on it to make sure its not open, it could be your thermostat.
Aug 03, 2008 | Whirlpool LER4634J Electric Dryer
Whirlpool LER4634PQ Electric Dryer Logo
55 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
